[GeoNode-users] Geocoding
Annalisa Schiavon
annalisa.schiavon at gmail.com
Wed May 6 02:49:44 PDT 2015
But I need to install Geonode in "developer mode"? I've already installed
geonode using apt-get install, refer to testing ver.
2015-05-06 11:31 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> Look how @ndufrane did it here for the layer searcher, you may use the
> same approach:
> https://github.com/GeoNode/geonode/pull/2107/files
> cheers
> p
> On Wed, May 6, 2015 at 11:27 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
> > Sorry, but I didn't understand where to customize in map template ...
> > The tutorial [1] says: "Navigate to the src/app/app.js in the myviewer
> > directory"
> > In a geonode installation (2.4b22 - I've created my template from
> > https://github.com/GeoNode/geonode-project/archive/testing.zip ) where
> is
> > the code? Or how can I override this script?
> > In general, I've to customize Geoexplorer, but I haven't already found
> > where!
> > Annalisa
> > 2015-05-05 12:58 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> >> Hi Annalisa
> >> I don't think anything was done in this regards. Not even sure how
> >> easy would be to implement it, as we would need to recursively scan
> >> all of the records of each GeoNode layer (maybe a search engine could
> >> be used at this regard?)
> >> If instead you need just to geocode a location and zoom to the
> >> corresponding point in the map, you could add the geocoder tool [1] in
> >> your map template.
> >> cheers
> >> p
> >> [1] http://suite.opengeo.org/4.1/webapps/gxp/viewer/geocoder.html
> >> On Tue, May 5, 2015 at 10:01 AM, Annalisa Schiavon
> >> > Hi list!
> >> > It is planned to implement geocoding functionality in geonode? I see
> >> > this
> >> > issue: https://github.com/GeoNode/geonode/issues/1810, I think it
> would
> >> > be
> >> > very useful.
> >> > Someone has already added this functionality, any ideas, examples?
> >> > Thanks a lot
> >> > Annalisa
> >> > _______________________________________________
> >> > geonode-users mailing list
> >> > geonode-users at lists.osgeo.org
> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150506/ce94b96b/attachment.html>
More information about the geonode-users
