[GeoNode-users] Geocoding
Annalisa Schiavon annalisa.schiavon at gmail.com
Wed May 6 06:36:28 PDT 2015
I've created and deployed a geonode project, but with admin tutorial [2].
I've the project structure [3]
<http://geonode.readthedocs.org/en/latest/tutorials/admin/customize_admin/setup_admin.html#project-structure>
but
I don't create repository on Github. I have to create the repository to
"download" and customize  my geonode/maps/templates/maps/map_geoexplorer.js
I haven't experience with Github.
Or I must reinstall as developer?
Thanks
[2]
[3]
2015-05-06 12:06 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> The best practice if you need to customize things is to create and
> deploy a GeoNode project [1].
> Alternatively you may modify the code on the server, but this is not
> recommended as it will be difficult to keep your changes under git and
> to sync from the geonode master.
> p
> [1]
> http://geonode.readthedocs.org/en/latest/tutorials/devel/projects/index.html#customize-projects
> On Wed, May 6, 2015 at 11:49 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
> > But I need to install Geonode in "developer mode"? I've already installed
> > geonode using apt-get install, refer to testing ver.
> > 2015-05-06 11:31 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> >> Look how @ndufrane did it here for the layer searcher, you may use the
> >> same approach:
> >> https://github.com/GeoNode/geonode/pull/2107/files
> >> cheers
> >> p
> >> On Wed, May 6, 2015 at 11:27 AM, Annalisa Schiavon
> >> > Sorry, but I didn't understand where to customize in map template ...
> >> > The tutorial [1] says: "Navigate to the src/app/app.js in the myviewer
> >> > directory"
> >> > In a geonode installation (2.4b22 - I've created my template from
> >> > https://github.com/GeoNode/geonode-project/archive/testing.zip )
> where
> >> > is
> >> > the code? Or how can I override this script?
> >> > In general, I've to customize Geoexplorer, but I haven't already found
> >> > where!
> >> > Annalisa
> >> > 2015-05-05 12:58 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> >> >> Hi Annalisa
> >> >> I don't think anything was done in this regards. Not even sure how
> >> >> easy would be to implement it, as we would need to recursively scan
> >> >> all of the records of each GeoNode layer (maybe a search engine could
> >> >> be used at this regard?)
> >> >> If instead you need just to geocode a location and zoom to the
> >> >> corresponding point in the map, you could add the geocoder tool [1]
> in
> >> >> your map template.
> >> >> cheers
> >> >> p
> >> >> [1] http://suite.opengeo.org/4.1/webapps/gxp/viewer/geocoder.html
> >> >> On Tue, May 5, 2015 at 10:01 AM, Annalisa Schiavon
> >> >> > Hi list!
> >> >> > It is planned to implement geocoding functionality in geonode? I
> see
> >> >> > this
> >> >> > issue: https://github.com/GeoNode/geonode/issues/1810, I think it
> >> >> > would
> >> >> > be
> >> >> > very useful.
> >> >> > Someone has already added this functionality, any ideas, examples?
> >> >> > Thanks a lot
> >> >> > Annalisa
> >> >> > _______________________________________________
> >> >> > geonode-users mailing list
> >> >> > geonode-users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> >> >> Paolo Corti
> >> >> Geospatial software developer
> >> >> web: http://www.paolocorti.net
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150506/74b0a015/attachment-0001.html>
More information about the geonode-users mailing list
