[GeoNode-users] ppa:geonode/testing install issue
Simone Dalmasso simone.dalmasso at gmail.com
Fri May 8 04:52:34 PDT 2015
You should not change the admin password but use the commands listed here
http://docs.geonode.org/en/master/tutorials/admin/install/quick_install.html at
step 3.
$ geonode createsuperuser
$ geonode-updateip
Then use the created user to login.
Thanks for the feedback about the java issue.
2015-05-08 13:49 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
> On Fri, May 8, 2015 at 3:48 AM, i wrote:
>> I went ahead and provisioned a normal 14.04 server and the installation
>> of ppa:geonode/testing is working
> But the username/password = admin/admin did not work ... it was necessary
> to do this:
> root at geonode:~# geonode shell
> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
> [GCC 4.8.2] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> (InteractiveConsole)
> >>> import geonode
> >>> geonode.people.models.Profile.objects.all()[1]
> <Profile: admin>
> [<Profile: AnonymousUser>, <Profile: admin>]
> <Profile: admin>
> >>> a=geonode.people.models.Profile.objects.all()[1]
> >>> a.set_password("mypassword")
> >>> a.save()
>> In fact I now found that the rpi 14.04 install also fails on startx after
>> installing xubuntu-desktop as per the same instructions
>> <https://wiki.ubuntu.com/ARM/RaspberryPi>.
> Although this point is not directly related to geonode, I did manage to
> get the xubuntu-desktop running by editing config.txt (the rpi's text-file
> bios) according to the defaults suggested here
> <https://www.raspberrypi.org/documentation/configuration/config-txt.md>,
> here <https://www.raspberrypi.org/forums/viewtopic.php?f=26&t=5851> and
> here <https://forums.gentoo.org/viewtopic-p-7244624.html>.   It took
> about 20 minutes to reboot directly into X with blankscreen and no feedback
> during.  Once booted run "top" in a terminal and watch for load avgs to
> settle down.  Eventually, after about 30 minutes, the x-desktop is
> responsive.
> The architecture of the raspberry-pi is ARM rather than i86, and the
> geoserver stuff is all java, if i'm not mistaken, so the problem with the
> goenode-geoserver part of the ppa:geonode/testing installation (i.e. that
> it failed to install) is likely a Java-ARM issue ... IMLIC (if my logic is
> correct)
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150508/d293a6cc/attachment.html>
More information about the geonode-users mailing list
