[GeoNode-users] Exists a project template for smartphone collection and upload?
Francesco Bartoli
xbartolone at gmail.com
Mon May 11 08:31:03 PDT 2015
Hi Simone,
a look at shareabouts and its API would be worth.
Ciao
Francesco
Il giorno 11/mag/2015, alle ore 14:59, Simone Dalmasso <simone.dalmasso at gmail.com> ha scritto:
> Hi Charles,
> at the moment there's no such working tool (apart from a very draft I made some years ago that uses formhub + epicollect + geonode) but the interest around it is increasing and I'm sure there are other people in the list that are willing to work on this.
> We encourage potential stakeholders to come in!
> About your questions:
> - you can add google as an optional background in the settings here https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L617 using this doc http://gxp.opengeo.org/master/doc/lib/plugins/GoogleSource.html
> - you will have to customize the code of the mapping library which is based on Geoexplorer http://suite.opengeo.org/opengeo-docs/geoexplorer/. But here others may help you more than me. :)
> Ciao
> 2015-05-11 13:32 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
> Hi All,
> I am getting up-to-speed with GeoNode and GIS in general. I need to implement the same general workflow model in several different contexts. The workflow is:
> offline collection of arbitrary data via smartphone (tracks, photos, notes, forms)
> sync arbitrary, serialized blob data to server
> handle and store arbitrary serialized blob data in GeoNode (some sub-app)
> webapp interface template to explore / utilize data
> This seems like it would make a good project template ... pull everything into a django-app under your geonode instance, including the smartphone app template code, and just customize from there.
> Does such a project already exist? If not, then would it be a good thing?
> I like these apps from MISIN, but they don't allow for use outside of a hard-coded range. Otherwise, that's exactly the system / workflow I'm after. I haven't checked if their code is free. ArcGIS Collector would be the similar Esri product.
> I have a couple other questions while here:
> why google earth but no google maps?
> what is best way (api?) to capture map clicks?
> Thanks!
> Charles
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150511/d8f4941c/attachment.html>
More information about the geonode-users
