[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Simone Dalmasso
simone.dalmasso at gmail.com
Tue May 12 02:55:32 PDT 2015
that is indeed strange, it doesn't look at a permission bug. They ones with
no (none) might have a space instead. Do you have more information on how
you created those styles?
2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> okay I found a pattern now:
> in /admin/layers/style/
> [image: Inline-Bild 1]
> -The styles that have "(None)" entry in the Workspace column can be
> edited via geonode style editor
> -The styles that have no "(None)" entry entry in the Workspace column
> canot be edited via geonode style editor
> How ever if i open a particular style in /admin/layers/style/ , the
> workspace field is empty for all stlyes, wether they have a "(None)" entry
> in the Workspace column or not.
> Is this a bug with the django permissions system?
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> I have unticked the option "Automatic caching for non-standard styles" in
>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>> That resolved the issue for a number of layers but not for all. The style
>> for one point layer n my installation is still only editable in geoserver
>> via SLD, not via geonode gui.
>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> hmm. The only difference I can see is that, here, the problem occurs
>>> with a point layer
>>> 12053 Berlin
>>> Germany / Allemagne
>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Rainer, I'm testing this here
>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>> replicate.
>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>
>>>>> Open a layer, edit layer, edit style. In the popup, select rule and
>>>>> edit. Change color and/or opacity. Save and close. Repeat process, the rule
>>>>> has reverted back to its original style.
>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/1b00bf1b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/1b00bf1b/attachment-0001.png>
More information about the geonode-users
