[GeoNode-users] Postgis extension on geonode DB
Renata Binotto rbinotto at arpa.veneto.it
Tue May 12 03:21:19 PDT 2015
Hi all,
we have a DB and a postgresql schema (call it ourSchema) with some
layers and some tables and we want to edit the tables using Django Admin
facilities (with server_ipaddress/admin). We wrote in local_settings in
/etc/geonode the connection strings for this DB (ex: ourDB, in the same
server with geonode) but after some tests we understood that:
-- creating a new app (with python manage.py startapp ...), a models.py
with our tables and using python manage.py syncdb --database=ourDB,
Geonode re-create all django tables + our tables in the _public_ schema
of ourDB ('cause there's no info in local_settings about what schema is
connected ourDB);
-- but these new tables in ourDB/public are not seen by
server_ipaddress/admin, but they are seen only if we create them in the
schema geonode(=default)/public;
-- so we thought we could put ourSchema inside geonodeDB or all its
tables/layers in the geonode/public schema (even if we don't like this
solution too much...), but ourSchema contains layers and geonodeDB has
no postgis extensions so we couldn't.
At the end, some desperate questions:
-- is it possible to connect django server_ipaddress/admin to tables in
a different DB (putting some connection string in the app directly, for
example);
-- is it possible to install postgis extension on geonodeDB?
Thanks!
Renata.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/eb35f0b7/attachment.html>
More information about the geonode-users mailing list
