[GeoNode-users] [GeoNode-devel] Problem with saving styles "there was an error saving the style back to the server" on 2.4b25 on trusty / Vagrant VM
Rainer Lissewski r.lissewski at aplikate.eu
Tue May 12 09:04:24 PDT 2015
Hm I tried it and it helped. But does this make sense ? Styles arent
uploaded to this directory but sent to geoserver via http request afaik?
_____________________________________
*A P L I K @ T E . E U <http://www.aplikate.eu/>*
Linux, GIS and database developer team
Wittmannsdorfer Str. 4
12053 Berlin
Germany / Allemagne
Tel.: +49 (0) 30 28 45 40 71
Mobil: +49 (0) 163 681 77 34
Fax: +49 (0)30 / 48 49 81 286
2015-05-12 17:05 GMT+02:00 Ariel Nunez <ingenieroariel at gmail.com>:
> The fix is:
> sudo chown -R /var/www/geonode/uploaded www-data:www-data
> On Tue, May 12, 2015 at 10:01 AM, Rainer Lissewski <
> rainerlissewski at gmail.com> wrote:
>> Hi I get an  "there was an error saving the style back to the server" msg
>> on trying to save styles. Eventually it (partially works, but the error
>> comes up very frequent. It is a layer that has been added from another
>> postgis datastore along the lines  of
>> http://geonode.readthedocs.org/en/latest/tutorials/admin/commands.html#updatelayers
>> Stacktrace:
>> [Tue May 12 09:52:27.968168 2015] [:error] [pid 30225:tid
>> 139984521770752] Internal Server Error:
>> /gs/rest/styles/HVTgeom2_9b5c1e56.xml
>> [Tue May 12 09:52:27.968289 2015] [:error] [pid 30225:tid
>> 139984521770752] Traceback (most recent call last):
>> [Tue May 12 09:52:27.968356 2015] [:error] [pid 30225:tid
>> 139984521770752]   File
>> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112,
>> in get_response
>> [Tue May 12 09:52:27.968386 2015] [:error] [pid 30225:tid
>> 139984521770752]     response = wrapped_callback(request, *callback_args,
>> **callback_kwargs)
>> [Tue May 12 09:52:27.968475 2015] [:error] [pid 30225:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/views.py", line
>> 339, in geoserver_rest_proxy
>> [Tue May 12 09:52:27.968545 2015] [:error] [pid 30225:tid
>> 139984521770752]     style_update(request, url)
>> [Tue May 12 09:52:27.968573 2015] [:error] [pid 30225:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>> 1481, in style_update
>> [Tue May 12 09:52:27.968715 2015] [:error] [pid 30225:tid
>> 139984521770752]     layer.save()
>> [Tue May 12 09:52:27.968732 2015] [:error] [pid 30225:tid
>> "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line
>> 90, in save
>> [Tue May 12 09:52:27.968742 2015] [:error] [pid 30225:tid
>> 139984521770752]     return super(PolymorphicModel, self).save(*args,
>> **kwargs)
>> [Tue May 12 09:52:27.968751 2015] [:error] [pid 30225:tid
>> "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in
>> save
>> [Tue May 12 09:52:27.968761 2015] [:error] [pid 30225:tid
>> 139984521770752]     force_update=force_update, update_fields=update_fields)
>> [Tue May 12 09:52:27.968770 2015] [:error] [pid 30225:tid
>> "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 582, in
>> save_base
>> [Tue May 12 09:52:27.968779 2015] [:error] [pid 30225:tid
>> 139984521770752]     update_fields=update_fields, raw=raw, using=using)
>> [Tue May 12 09:52:27.968801 2015] [:error] [pid 30225:tid
>> "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
>> in send
>> [Tue May 12 09:52:27.968839 2015] [:error] [pid 30225:tid
>> 139984521770752]     response = receiver(signal=self, sender=sender,
>> **named)
>> [Tue May 12 09:52:27.968865 2015] [:error] [pid 30225:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
>> 390, in geoserver_post_save
>> [Tue May 12 09:52:27.968931 2015] [:error] [pid 30225:tid
>> 139984521770752]     create_thumbnail(instance, thumbnail_remote_url,
>> thumbnail_create_url, ogc_client=http_client)
>> [Tue May 12 09:52:27.968959 2015] [:error] [pid 30225:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py", line 592,
>> in create_thumbnail
>> [Tue May 12 09:52:27.969019 2015] [:error] [pid 30225:tid
>> 139984521770752]     instance.save_thumbnail(filename, image=image)
>> [Tue May 12 09:52:27.969048 2015] [:error] [pid 30225:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/base/models.py", line 559,
>> in save_thumbnail
>> [Tue May 12 09:52:27.969075 2015] [:error] [pid 30225:tid
>> 139984521770752]     with open(os.path.join(upload_path, filename), 'w') as
>> f:
>> [Tue May 12 09:52:27.969106 2015] [:error] [pid 30225:tid
>> 139984521770752] IOError: [Errno 13] Permission denied:
>> u'/var/www/geonode/uploaded/thumbs/layer-efe85a37-9a78-41ce-9692-cd0920486afd-thumb.png'
>> [Tue May 12 09:52:27.988412 2015] [:error] [pid 30225:tid
>> 139984521770752] [remote 10.0.2.2:15799] mod_wsgi (pid=30225): Exception
>> occurred processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/09487a2d/attachment.html>
More information about the geonode-users mailing list
