[GeoNode-users] translation of map tools
Jeffrey Johnson
ortelius at gmail.com
Fri May 15 11:00:07 PDT 2015
Not sure we can get boundless to pull. Maybe bart can help.
Making the necessary changes on the geonode side should not be a problem.
On Fri, May 15, 2015 at 10:59 AM, Francesco Bartoli
<xbartolone at gmail.com> wrote:
> Hi Jeffrey,
> I created a PR for the Italian translation of geoexplorer sometime ago that
> has been merged by @bartvde into master and currently OpenGeo Suite ships
> GeoExplorer with such supported language. Anyway I see that
> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js
> doesn’t inherit the original as submodule so that work cannot be exploited
> automatically. Porting would impact just two files though.
> Francesco
> Il giorno 15/mag/2015, alle ore 15:26, Jeffrey Johnson <ortelius at gmail.com>
> ha scritto:
> I think we can use this setting here
> http://suite.opengeo.org/4.1/webapps/gxp/viewer/locale.html
> in here
> https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js
> Can you give that a try and see if it works?
> On Fri, May 15, 2015 at 6:04 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
> Hi all,
> Tools on GeoExplorer are labeled in English. there are some settings to
> translate them? I've already set language = Italian and geonode correctly
> translate many texts, but non all. In the map, not at all.
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users
