[GeoNode-users] translation of map tools
Annalisa Schiavon
annalisa.schiavon at gmail.com
Wed May 20 02:28:35 PDT 2015
Should I open an issue?
How can I include those js in my project?
2015-05-18 16:20 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> From Bart.
> On Mon, May 18, 2015 at 6:55 AM, Bart van den Eijnden <
> bartvde at boundlessgeo.com> wrote:
>> There is Italian in GXP and GeoExplorer so “it” should work. However
>> maybe Ariel's package is outdated?
>> https://github.com/boundlessgeo/gxp/blob/master/src/script/locale/it.js
>> https://github.com/boundlessgeo/suite/blob/master/geoexplorer/app/static/script/app/locale/app/it.js
>> Best regards,
>> Bart
>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>> 1-877-673-6436 <917-460-7207>
>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>> <http://boundlessgeo.com>
>> On 18 May 2015, at 15:51, Jeffrey Johnson <ortelius at gmail.com> wrote:
>> Any ideas on this one?
>> ---------- Forwarded message ----------
>> From: Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Date: Mon, May 18, 2015 at 1:53 AM
>> Subject: Re: [GeoNode-users] translation of map tools
>> To: Jeffrey Johnson <ortelius at gmail.com>
>> Cc: Francesco Bartoli <xbartolone at gmail.com>, geonode-users
>> <geonode-users at lists.osgeo.org>
>> Thank you all.
>> Jeffrey you mean geonode team to make the necessary changes or me in my
>> project?
>> I see now
>> https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js#L12
>> that set GeoExt.Lang.set("{{ LANGUAGE_CODE }}"); like described here
>> http://suite.opengeo.org/4.1/webapps/gxp/viewer/locale.html
>> In my settings LANGUAGE_CODE is = "it - IT".
>> I've just try to set LANGUAGE_CODE = "it", but nothing has changed.
>> What else would I change?
>> Thanks
>> 2015-05-15 20:00 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>> Not sure we can get boundless to pull. Maybe bart can help.
>> Making the necessary changes on the geonode side should not be a problem.
>> On Fri, May 15, 2015 at 10:59 AM, Francesco Bartoli
>> <xbartolone at gmail.com> wrote:
>> Hi Jeffrey,
>> I created a PR for the Italian translation of geoexplorer sometime ago
>> that
>> has been merged by @bartvde into master and currently OpenGeo Suite ships
>> GeoExplorer with such supported language. Anyway I see that
>> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js
>> doesn’t inherit the original as submodule so that work cannot be exploited
>> automatically. Porting would impact just two files though.
>> Francesco
>> Il giorno 15/mag/2015, alle ore 15:26, Jeffrey Johnson <
>> ha scritto:
>> I think we can use this setting here
>> in here
>> Can you give that a try and see if it works?
>> On Fri, May 15, 2015 at 6:04 AM, Annalisa Schiavon
>> <annalisa.schiavon at gmail.com> wrote:
>> Hi all,
>> Tools on GeoExplorer are labeled in English. there are some settings to
>> translate them? I've already set language = Italian and geonode correctly
>> translate many texts, but non all. In the map, not at all.
>> Thanks
>> geonode-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150520/7e41251b/attachment-0001.html>
More information about the geonode-users
