[GeoNode-users] Unable to change Geoserver admin password
Simone Dalmasso simone.dalmasso at gmail.com
Thu May 21 00:37:51 PDT 2015
Pietro, I just tested on demo.geonode.org, here what i did:
- set the password in /etc/geonode/local_settings.py (this is the place
where to change settings because they override the default geonode ones.
- change the admin user password through geoserver security users pane
- restart apache and tomcat
And everything works, the login admin/geoserver is no longer valid.
Can you try this?
2015-05-21 9:25 GMT+02:00 Pietro Blu Giandonato <p.giandonato at gmail.com>:
> Hi all,
> no way to fix this issue.
> 1. tried to modify 'admin' password within GeoServer user panel, but
> password is still the default one
> 2. manually
> modified /usr/local/lib/python2.7/dist-packages/geonode/settings.py
> changing the password with a new one
> 3. restarted Tomcat (and even server)
> Problem still persists.
> Pietro Blu Giandonato, PhD
> Work http://it.linkedin.com/in/pietroblu
> About me http://about.me/pietroblu
> Socially https://www.rebelmouse.com/pietroblu/
> On 20 May 2015 at 23:04, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi Pietro
>> Try to restart tomcat.
>> Cheers
>> P
>> On May 20, 2015 8:14 PM, "Pietro Blu Giandonato" <p.giandonato at gmail.com>
>> wrote:
>>> Hi list,
>>> I'm not able to change the default 'admin' user password for security
>>> purposes, as suggested after GeoNode installation.
>>> I've tried to do it through the user panel, but even after changing it,
>>> the password for 'admin' user still remains the default one 'geoserver'.
>>> The GeoNode administrator user has another name, but it seems that the
>>> 'admin' one persists.
>>> In what I'm wrong?
>>> Regards.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150521/7e8fb059/attachment.html>
More information about the geonode-users mailing list
