[GeoNode-users] Problems to change Geonode database name
Davi Custodio davicustodio at gmail.com
Wed May 27 05:57:42 PDT 2015
Simone, how do I force Django to respect the new local_settings settings?
On Wed, May 27, 2015 at 9:56 AM, Davi Custodio <davicustodio at gmail.com>
wrote:
> I forgot to put the setting of my local_settings.py:
> DATABASE_ENGINE = 'postgresql_psycopg2'
> DATABASE_NAME = 'cnpm_geonode'
> DATABASE_USER = 'geonode'
> DATABASE_PASSWORD = '*****'
> DATABASE_HOST = 'jatoba.cnpm.embrapa.br'
> DATABASE_PORT = '5432'
> DATABASES = {
>     'default': {
>         'ENGINE': 'django.db.backends.postgresql_psycopg2',
>         'NAME': DATABASE_NAME,
>         'USER': DATABASE_USER,
>         'PASSWORD': DATABASE_PASSWORD,
>         'HOST': DATABASE_HOST,
>         'PORT': DATABASE_PORT,
>     'datastore': {
>         'ENGINE': 'django.contrib.gis.db.backends.postgis',
>         'NAME': 'cnpm_geonode_data',
> On Wed, May 27, 2015 at 9:50 AM, Davi Custodio <davicustodio at gmail.com>
> wrote:
>> Hello. I have problem in GeoNode 2.4 to rename the GeoNode database. I
>> need to change the names of "GeoNode" and "geonode_data" because I am
>> centralizing the databases of various GeoNode servers in the same instance
>> of PostgreSQL.
>> I changed the names in local_settings.py, and then restarted the apache,
>> and I received an error to Django still trying to find a database with old
>> name "GeoNode".
>> Besides local_settings.py, there is another location that I should change
>> the database name?
>> Below the full log.
>> Davi.
>> OperationalError at /
>> FATAL:  database "geonode" does not exist
>> Request Method:GETRequest URL:http://muchita.cnpm.embrapa.br/Django
>> Version:1.6.1Exception Type:OperationalErrorException Value:
>> Exception Location:/usr/lib/python2.7/dist-packages/psycopg2/__init__.py
>> in connect, line 179Python Executable:/usr/bin/pythonPython Version:2.7.6Python
>> Path:
>> ['/usr/lib/python2.7',
>>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>  '/usr/lib/python2.7/lib-tk',
>>  '/usr/lib/python2.7/lib-old',
>>  '/usr/lib/python2.7/lib-dynload',
>>  '/usr/local/lib/python2.7/dist-packages',
>>  '/usr/lib/python2.7/dist-packages',
>>  '/usr/lib/python2.7/dist-packages/PILcompat',
>>  '/usr/lib/pymodules/python2.7',
>>  '/var/www']
>> Server time:Qua, 27 Mai 2015 07:36:18 -0500
>> Traceback Switch to copy-and-paste view
>> <http://muchita.cnpm.embrapa.br/#>
>>    - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>>    get_response
>>    1.
>>                       response = response.render()
>>    ▶ Local vars <http://muchita.cnpm.embrapa.br/#>
>>    - /usr/lib/python2.7/dist-packages/django/template/response.py in
>>    render
>>    1.
>>                   self.content = self.rendered_content
>>    rendered_content
>>    1.
>>               context = self.resolve_context(self.context_data)
>>    resolve_context
>>    1.
>>               return RequestContext(self._request, context, current_app=self._current_app)
>>    - /usr/lib/python2.7/dist-packages/django/template/context.py in
>>    __init__
>>    1.
>>                   self.update(processor(request))
>>    - /usr/local/lib/python2.7/dist-packages/geonode/context_processors.py
>>     in resource_urls
>>    1.
>>           site = Site.objects.get_current()
>>    - /usr/lib/python2.7/dist-packages/django/contrib/sites/models.py in
>>    get_current
>>    1.
>>                   current_site = self.get(pk=sid)
>>    - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in get
>>    1.
>>               return self.get_queryset().get(*args, **kwargs)
>>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in get
>>    1.
>>               num = len(clone)
>>    __len__
>>    1.
>>               self._fetch_all()
>>    _fetch_all
>>    1.
>>                   self._result_cache = list(self.iterator())
>>    iterator
>>    1.
>>               for row in compiler.results_iter():
>>    - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>     in results_iter
>>    1.
>>               for rows in self.execute_sql(MULTI):
>>     in execute_sql
>>    1.
>>               cursor = self.connection.cursor()
>>    - /usr/lib/python2.7/dist-packages/django/db/backends/__init__.py in
>>    cursor
>>    1.
>>                   cursor = self.make_debug_cursor(self._cursor())
>>    _cursor
>>    1.
>>               self.ensure_connection()
>>    ensure_connection
>>    1.
>>                       self.connect()
>>    - /usr/lib/python2.7/dist-packages/django/db/utils.py in __exit__
>>    1.
>>                       six.reraise(dj_exc_type, dj_exc_value, traceback)
>>    ensure_connection
>>    1.
>>                       self.connect()
>>    connect
>>    1.
>>               self.connection = self.get_new_connection(conn_params)
>>    /usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>     in get_new_connection
>>    1.
>>               return Database.connect(**conn_params)
>>    - /usr/lib/python2.7/dist-packages/psycopg2/__init__.py in connect
>>    1.
>>               connection_factory=connection_factory, async=async)
>> Request informationGET
>> No GET data
>> POST
>> No POST data
>> FILES
>> No FILES data
>> COOKIESVariableValue__utmz
>> '128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)'
>> ys-user
>> 'o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>> _ga
>> 'GA1.2.1150756117.1398259583'
>> __gads
>> 'ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ'
>> csrftoken
>> 'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>> s_getNewRepeat
>> '1423508214723-Repeat'
>> ys-alreadyShowMessage
>> 'b%3A1'
>> __utma
>> '128008848.1150756117.1398259583.1432729377.1432729377.1'
>> __utmb
>> '128008848.1.10.1432729377'
>> __utmc
>> '128008848'
>> s_fid
>> '691159BDD05014BE-21BD7FC62185D9C7'
>> METAVariableValuemod_wsgi.listener_port
>> '80'
>> HTTP_COOKIE
>> '__gads=ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ; __utmz=237664978.1423046483.18.3.utmccn=(referral)|utmcsr=google.com.br|utmcct=/|utmcmd=referral; __utma=237664978.1207420118.1398169929.1423046483.1423244128.19; s_fid=691159BDD05014BE-21BD7FC62185D9C7; s_getNewRepeat=1423508214723-Repeat; __utma=218996109.1150756117.1398259583.1432299746.1432304989.52; __utmz=218996109.1432304989.52.23.utmcsr=chorao.cnpm.embrapa.br:9081|utmccn=(referral)|utmcmd=referral|utmcct=/; _ga=GA1.2.1150756117.1398259583; csrftoken=GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb; __utma=128008848.1150756117.1398259583.1432729377.1432729377.1; __utmb=128008848.1.10.1432729377; __utmc=128008848; __utmz=128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); ys-alreadyShowMessage=b%3A1; ys-user=o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>> mod_wsgi.listener_host
>> CONTEXT_DOCUMENT_ROOT
>> '/var/www'
>> SERVER_SOFTWARE
>> 'Apache/2.4.7 (Ubuntu)'
>> SCRIPT_NAME
>> u''
>> mod_wsgi.enable_sendfile
>> '0'
>> mod_wsgi.handler_script
>> SERVER_SIGNATURE
>> '<address>Apache/2.4.7 (Ubuntu) Server at muchita.cnpm.embrapa.br Port 80</address>\n'
>> REQUEST_METHOD
>> 'GET'
>> PATH_INFO
>> u'/'
>> SERVER_PROTOCOL
>> 'HTTP/1.1'
>> QUERY_STRING
>> HTTP_USER_AGENT
>> 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.65 Safari/537.36'
>> HTTP_CONNECTION
>> 'keep-alive'
>> SERVER_NAME
>> 'muchita.cnpm.embrapa.br'
>> REMOTE_ADDR
>> '10.157.20.55'
>> mod_wsgi.queue_start
>> '1432730176843671'
>> mod_wsgi.request_handler
>> 'wsgi-script'
>> wsgi.url_scheme
>> 'http'
>> PATH_TRANSLATED
>> '/var/www/geonode/wsgi/geonode.wsgi/'
>> SERVER_PORT
>> '80'
>> wsgi.multiprocess
>> True
>> mod_wsgi.input_chunked
>> '0'
>> SERVER_ADDR
>> '192.168.10.10'
>> DOCUMENT_ROOT
>> '/var/www'
>> mod_wsgi.process_group
>> 'geonode'
>> HTTP_PRAGMA
>> 'no-cache'
>> SCRIPT_FILENAME
>> '/var/www/geonode/wsgi/geonode.wsgi'
>> SERVER_ADMIN
>> 'webmaster at localhost'
>> wsgi.input
>> <mod_wsgi.Input object at 0x7fe089acf530>
>> HTTP_HOST
>> CONTEXT_PREFIX
>> wsgi.multithread
>> True
>> mod_wsgi.callable_object
>> 'application'
>> HTTP_CACHE_CONTROL
>> 'no-cache'
>> REQUEST_URI
>> HTTP_ACCEPT
>> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
>> wsgi.version
>> (1, 0)
>> GATEWAY_INTERFACE
>> 'CGI/1.1'
>> wsgi.run_once
>> False
>> wsgi.errors
>> <mod_wsgi.Log object at 0x7fe0899a1f70>
>> REMOTE_PORT
>> '51799'
>> HTTP_ACCEPT_LANGUAGE
>> 'pt-PT,pt;q=0.8,pt-BR;q=0.6,en-US;q=0.4,en;q=0.2'
>> REQUEST_SCHEME
>> 'http'
>> mod_wsgi.version
>> (3, 4)
>> mod_wsgi.application_group
>> 'aguai.cnpm.embrapa.br|'
>> mod_wsgi.script_reloading
>> '1'
>> wsgi.file_wrapper
>> CSRF_COOKIE
>> u'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>> HTTP_ACCEPT_ENCODING
>> 'gzip, deflate, sdch'
>> SettingsUsing settings module geonode.settingsSettingValue
>> CASCADE_WORKSPACE
>> 'geonode'
>> ACCOUNT_USER_DISPLAY
>> DATABASES
>> {'datastore': {'ATOMIC_REQUESTS': False,
>>                'AUTOCOMMIT': True,
>>                'CONN_MAX_AGE': 0,
>>                'HOST': 'jatoba.cnpm.embrapa.br',
>>                'NAME': 'geonode_data',
>>                'OPTIONS': {},
>>                'PASSWORD': u'********************',
>>                'PORT': '5432',
>>                'TEST_CHARSET': None,
>>                'TEST_COLLATION': None,
>>                'TEST_MIRROR': None,
>>                'TEST_NAME': None,
>>                'TIME_ZONE': 'America/Chicago',
>>                'USER': 'geonode'},
>>  'default': {'ATOMIC_REQUESTS': False,
>>              'AUTOCOMMIT': True,
>>              'CONN_MAX_AGE': 0,
>>              'NAME': 'geonode',
>>              'OPTIONS': {},
>>              'PORT': '5432',
>>              'TEST_NAME': None,
>>              'USER': 'geonode'}}
>> GOOGLE_API_KEY
>> CELERY_CREATE_MISSING_QUEUES
>> True
>> CSRF_COOKIE_SECURE
>> False
>> CELERY_DEFAULT_QUEUE
>> 'default'
>> UPLOADER
>> {'BACKEND': 'geonode.rest',
>>  'OPTIONS': {'GEOGIG_ENABLED': False, 'TIME_ENABLED': False}}
>> LANGUAGE_CODE
>> 'pt-br'
>> LICENSES
>> {'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
>> MANAGERS
>> DOWNLOAD_FORMATS_METADATA
>> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
>> BROKER_URL
>> 'django://'
>> DEFAULT_CHARSET
>> 'utf-8'
>> IGNORABLE_404_URLS
>> CELERY_DEFAULT_EXCHANGE_TYPE
>> 'direct'
>> SESSION_SERIALIZER
>> 'django.contrib.sessions.serializers.PickleSerializer'
>> DEFAULT_MAP_CENTER
>> (0, 0)
>> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
>> 3
>> USE_THOUSAND_SEPARATOR
>> False
>> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
>> None
>> ACCOUNT_INVITE_USER_URL
>> u'account_invite_user'
>> REGISTRATION_OPEN
>> False
>> ALLOWED_HOSTS
>> ['muchita.cnpm.embrapa.br', 'localhost']
>> EMAIL_HOST
>> 'localhost'
>> DOWNLOAD_FORMATS_RASTER
>> ['JPEG',
>>  'PDF',
>>  'PNG',
>>  'ArcGrid',
>>  'GeoTIFF',
>>  'Gtopo30',
>>  'ImageMosaic',
>>  'KML',
>>  'View in Google Earth',
>>  'Tiles']
>> AUTH_EXEMPT_URLS
>> WSGI_APPLICATION
>> None
>> EMAIL_SUBJECT_PREFIX
>> '[Django] '
>> SEND_BROKEN_LINK_EMAILS
>> False
>> TEMPLATE_STRING_IF_INVALID
>> STATICFILES_FINDERS
>> ('django.contrib.staticfiles.finders.FileSystemFinder',
>>  'django.contrib.staticfiles.finders.AppDirectoriesFinder')
>> NOTIFICATION_QUEUE_ALL
>> False
>> SESSION_CACHE_ALIAS
>> 'default'
>> CELERY_IMPORTS
>> ('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
>> SESSION_COOKIE_DOMAIN
>> None
>> SESSION_COOKIE_NAME
>> 'sessionid'
>> ADMIN_FOR
>> TIME_INPUT_FORMATS
>> ('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
>> ACCOUNT_USE_AUTH_AUTHENTICATE
>> False
>> X_FRAME_OPTIONS
>> 'SAMEORIGIN'
>> FILE_UPLOAD_PERMISSIONS
>> None
>> ACCOUNT_TIMEZONES
>> [('Africa/Abidjan', 'Africa/Abidjan'),
>>  ('Africa/Accra', 'Africa/Accra'),
>>  ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>>  ('Africa/Algiers', 'Africa/Algiers'),
>>  ('Africa/Asmara', 'Africa/Asmara'),
>>  ('Africa/Asmera', 'Africa/Asmera'),
>>  ('Africa/Bamako', 'Africa/Bamako'),
>>  ('Africa/Bangui', 'Africa/Bangui'),
>>  ('Africa/Banjul', 'Africa/Banjul'),
>>  ('Africa/Bissau', 'Africa/Bissau'),
>>  ('Africa/Blantyre', 'Africa/Blantyre'),
>>  ('Africa/Brazzaville', 'Africa/Brazzaville'),
>>  ('Africa/Bujumbura', 'Africa/Bujumbura'),
>>  ('Africa/Cairo', 'Africa/Cairo'),
>>  ('Africa/Casablanca', 'Africa/Casablanca'),
>>  ('Africa/Ceuta', 'Africa/Ceuta'),
>>  ('Africa/Conakry', 'Africa/Conakry'),
>>  ('Africa/Dakar', 'Africa/Dakar'),
>>  ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>>  ('Africa/Djibouti', 'Africa/Djibouti'),
>>  ('Africa/Douala', 'Africa/Douala'),
>>  ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>>  ('Africa/Freetown', 'Africa/Freetown'),
>>  ('Africa/Gaborone', 'Africa/Gaborone'),
>>  ('Africa/Harare', 'Africa/Harare'),
>>  ('Africa/Johannesburg', 'Africa/Johannesburg'),
>>  ('Africa/Juba', 'Africa/Juba'),
>>  ('Africa/Kampala', 'Africa/Kampala'),
>>  ('Africa/Khartoum', 'Africa/Khartoum'),
>>  ('Africa/Kigali', 'Africa/Kigali'),
>>  ('Africa/Kinshasa', 'Africa/Kinshasa'),
>>  ('Africa/Lagos', 'Africa/Lagos'),
>>  ('Africa/Libreville', 'Africa/Libreville'),
>>  ('Africa/Lome', 'Africa/Lome'),
>>  ('Africa/Luanda', 'Africa/Luanda'),
>>  ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>>  ('Africa/Lusaka', 'Africa/Lusaka'),
>>  ('Africa/Malabo', 'Africa/Malabo'),
>>  ('Africa/Maputo', 'Africa/Maputo'),
>>  ('Africa/Maseru', 'Africa/Maseru'),
>>  ('Africa/Mbabane', 'Africa/Mbabane'),
>>  ('Africa/Mogadishu', 'Africa/Mogadishu'),
>>  ('Africa/Monrovia', 'Africa/Monrovia'),
>>  ('Africa/Nairobi', 'Africa/Nairobi'),
>>  ('Africa/Ndjamena', 'Africa/Ndjamena'),
>>  ('Africa/Niamey', 'Africa/Niamey'),
>>  ('Africa/Nouakchott', 'Africa/Nouakchott'),
>>  ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>>  ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>>  ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>>  ('Africa/Timbuktu', 'Africa/Timbuktu'),
>>  ('Africa/Tripoli', 'Africa/Tripoli'),
>>  ('Africa/Tunis', 'Africa/Tunis'),
>>  ('Africa/Windhoek', 'Africa/Windhoek'),
>>  ('America/Adak', 'America/Adak'),
>>  ('America/Anchorage', 'America/Anchorage'),
>>  ('America/Anguilla', 'America/Anguilla'),
>>  ('America/Antigua', 'America/Antigua'),
>>  ('America/Araguaina', 'America/Araguaina'),
>>  ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>>  ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>>  ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>>  ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>>  ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>>  ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>>  ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>>  ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>>  ('America/Argentina/Salta', 'America/Argentina/Salta'),
>>  ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>>  ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>>  ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>>  ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>>  ('America/Aruba', 'America/Aruba'),
>>  ('America/Asuncion', 'America/Asuncion'),
>>  ('America/Atikokan', 'America/Atikokan'),
>>  ('America/Atka', 'America/Atka'),
>>  ('America/Bahia', 'America/Bahia'),
>>  ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>>  ('America/Barbados', 'America/Barbados'),
>>  ('America/Belem', 'America/Belem'),
>>  ('America/Belize', 'America/Belize'),
>>  ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>>  ('America/Boa_Vista', 'America/Boa_Vista'),
>>  ('America/Bogota', 'America/Bogota'),
>>  ('America/Boise', 'America/Boise'),
>>  ('America/Buenos_Aires', 'America/Buenos_Aires'),
>>  ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>>  ('America/Campo_Grande', 'America/Campo_Grande'),
>>  ('America/Cancun', 'America/Cancun'),
>>  ('America/Caracas', 'America/Caracas'),
>>  ('America/Catamarca', 'America/Catamarca'),
>>  ('America/Cayenne', 'America/Cayenne'),
>>  ('America/Cayman', 'America/Cayman'),
>>  ('America/Chicago', 'America/Chicago'),
>>  ('America/Chihuahua', 'America/Chihuahua'),
>>  ('America/Coral_Harbour', 'America/Coral_Harbour'),
>>  ('America/Cordoba', 'America/Cordoba'),
>>  ('America/Costa_Rica', 'America/Costa_Rica'),
>>  ('America/Creston', 'America/Creston'),
>>  ('America/Cuiaba', 'America/Cuiaba'),
>>  ('America/Curacao', 'America/Curacao'),
>>  ('America/Danmarkshavn', 'America/Danmarkshavn'),
>>  ('America/Dawson', 'America/Dawson'),
>>  ('America/Dawson_Creek', 'America/Dawson_Creek'),
>>  ('America/Denver', 'America/Denver'),
>>  ('America/Detroit', 'America/Detroit'),
>>  ('America/Dominica', 'America/Dominica'),
>>  ('America/Edmonton', 'America/Edmonton'),
>>  ('America/Eirunepe', 'America/Eirunepe'),
>>  ('America/El_Salvador', 'America/El_Salvador'),
>>  ('America/Ensenada', 'America/Ensenada'),
>>  ('America/Fort_Wayne', 'America/Fort_Wayne'),
>>  ('America/Fortaleza', 'America/Fortaleza'),
>>  ('America/Glace_Bay', 'America/Glace_Bay'),
>>  ('America/Godthab', 'America/Godthab'),
>>  ('America/Goose_Bay', 'America/Goose_Bay'),
>>  ('America/Grand_Turk', 'America/Grand_Turk'),
>>  ('America/Grenada', 'America/Grenada'),
>>  ('America/Guadeloupe', 'America/Guadeloupe'),
>>  ('America/Guatemala', 'America/Guatemala'),
>>  ('America/Guayaquil', 'America/Guayaquil'),
>>  ('America/Guyana', 'America/Guyana'),
>>  ('America/Halifax', 'America/Halifax'),
>>  ('America/Havana', 'America/Havana'),
>>  ('America/Hermosillo', 'America/Hermosillo'),
>>  ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>>  ('America/Indiana/Knox', 'America/Indiana/Knox'),
>>  ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>>  ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>>  ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>>  ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>>  ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>>  ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>>  ('America/Indianapolis', 'America/Indianapolis'),
>>  ('America/Inuvik', 'America/Inuvik'),
>>  ('America/Iqaluit', 'America/Iqaluit'),
>>  ('America/Jamaica', 'America/Jamaica'),
>>  ('America/Jujuy', 'America/Jujuy'),
>>  ('America/Juneau', 'America/Juneau'),
>>  ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>>  ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>>  ('America/Knox_IN', 'America/Knox_IN'),
>>  ('America/Kralendijk', 'America/Kralendijk'),
>>  ('America/La_Paz', 'America/La_Paz'),
>>  ('America/Lima', 'America/Lima'),
>>  ('America/Los_Angeles', 'America/Los_Angeles'),
>>  ('America/Louisville', 'America/Louisville'),
>>  ('America/Lower_Princes', 'America/Lower_Princes'),
>>  ('America/Maceio', 'America/Maceio'),
>>  ('America/Managua', 'America/Managua'),
>>  ('America/Manaus', 'America/Manaus'),
>>  ('America/Marigot', 'America/Marigot'),
>>  ('America/Martinique', 'America/Martinique'),
>>  ('America/Matamoros', 'America/Matamoros'),
>>  ('America/Mazatlan', 'America/Mazatlan'),
>>  ('America/Mendoza', 'America/Mendoza'),
>>  ('America/Menominee', 'America/Menominee'),
>>  ('America/Merida', 'America/Merida'),
>>  ('America/Metlakatla', 'America/Metlakatla'),
>>  ('America/Mexico_City', 'America/Mexico_City'),
>>  ('America/Miquelon', 'America/Miquelon'),
>>  ('America/Moncton', 'America/Moncton'),
>>  ('America/Monterrey', 'America/Monterrey'),
>>  ('America/Montevideo', 'America/Montevideo'),
>>  ('America/Montreal', 'America/Montreal'),
>>  ('America/Montserrat', 'America/Montserrat'),
>>  ('America/Nassau', 'America/Nassau'),
>>  ('America/New_York', 'America/New_York'),
>>  ('America/Nipigon', 'America/Nipigon'),
>>  ('America/Nome', 'America/Nome'),
>>  ('America/Noronha', 'America/Noronha'),
>>  ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>>  ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>>  ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>>  ('America/Ojinaga', 'America/Ojinaga'),
>>  ('America/Panama', 'America/Panama'),
>>  ('America/Pangnirtung', 'America/Pangnirtung'),
>>  ('America/Paramaribo', 'America/Paramaribo'),
>>  ('America/Phoenix', 'America/Phoenix'),
>>  ('America/Port-au-Prince', 'America/Port-au-Prince'),
>>  ('America/Port_of_Spain', 'America/Port_of_Spain'),
>>  ('America/Porto_Acre', 'America/Porto_Acre'),
>>  ('America/Porto_Velho', 'America/Porto_Velho'),
>>  ('America/Puerto_Rico', 'America/Puerto_Rico'),
>>  ('America/Rainy_River', 'America/Rainy_River'),
>>  ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>>  ('America/Recife', 'America/Recife'),
>>  ('America/Regina', 'America/Regina'),
>>  ('America/Resolute', 'America/Resolute'),
>>  ('America/Rio_Branco', 'America/Rio_Branco'),
>>  ('America/Rosario', 'America/Rosario'),
>>  ('America/Santa_Isabel', 'America/Santa_Isabel'),
>>  ('America/Santarem', 'America/Santarem'),
>>  ('America/Santiago', 'America/Santiago'),
>>  ('America/Santo_Domingo', 'America/Santo_Domingo'),
>>  ('America/Sao_Paulo', 'America/Sao_Paulo'),
>>  ('America/Scoresbysund', 'America/Scoresbysund'),
>>  ('America/Shiprock', 'America/Shiprock'),
>>  ('America/Sitka', 'America/Sitka'),
>>  ('America/St_Barthelemy', 'America/St_Barthelemy'),
>>  ('America/St_Johns', 'America/St_Johns'),
>>  ('America/St_Kitts', 'America/St_Kitts'),
>>  ('America/St_Lucia', 'America/St_Lucia'),
>>  ('America/St_Thomas', 'America/St_Thomas'),
>>  ('America/St_Vincent', 'America/St_Vincent'),
>>  ('America/Swift_Current', 'America/Swift_Current'),
>>  ('America/Tegucigalpa', 'America/Tegucigalpa'),
>>  ('America/Thule', 'America/Thule'),
>>  ('America/Thunder_Bay', 'America/Thunder_Bay'),
>>  ('America/Tijuana', 'America/Tijuana'),
>>  ('America/Toronto', 'America/Toronto'),
>>  ('America/Tortola', 'America/Tortola'),
>>  ('America/Vancouver', 'America/Vancouver'),
>>  ('America/Virgin', 'America/Virgin'),
>>  ('America/Whitehorse', 'America/Whitehorse'),
>>  ('America/Winnipeg', 'America/Winnipeg'),
>>  ('America/Yakutat', 'America/Yakutat'),
>>  ('America/Yellowknife', 'America/Yellowknife'),
>>  ('Antarctica/Casey', 'Antarctica/Casey'),
>>  ('Antarctica/Davis', 'Antarctica/Davis'),
>>  ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>>  ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>>  ('Antarctica/Mawson', 'Antarctica/Mawson'),
>>  ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>>  ('Antarctica/Palmer', 'Antarctica/Palmer'),
>>  ('Antarctica/Rothera', 'Antarctica/Rothera'),
>>  ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>>  ('Antarctica/Syowa', 'Antarctica/Syowa'),
>>  ('Antarctica/Vostok', 'Antarctica/Vostok'),
>>  ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>>  ('Asia/Aden', 'Asia/Aden'),
>>  ('Asia/Almaty', 'Asia/Almaty'),
>>  ('Asia/Amman', 'Asia/Amman'),
>>  ('Asia/Anadyr', 'Asia/Anadyr'),
>>  ('Asia/Aqtau', 'Asia/Aqtau'),
>>  ('Asia/Aqtobe', 'Asia/Aqtobe'),
>>  ('Asia/Ashgabat', 'Asia/Ashgabat'),
>>  ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>>  ('Asia/Baghdad', 'Asia/Baghdad'),
>>  ('Asia/Bahrain', 'Asia/Bahrain'),
>>  ('Asia/Baku', 'Asia/Baku'),
>>  ('Asia/Bangkok', 'Asia/Bangkok'),
>>  ('Asia/Beirut', 'Asia/Beirut'),
>>  ('Asia/Bishkek', 'Asia/Bishkek'),
>>  ('Asia/Brunei', 'Asia/Brunei'),
>>  ('Asia/Calcutta', 'Asia/Calcutta'),
>>  ('Asia/Choibalsan', 'Asia/Choibalsan'),
>>  ('Asia/Chongqing', 'Asia/Chongqing'),
>>  ('Asia/Chungking', 'Asia/Chungking'),
>>  ('Asia/Colombo', 'Asia/Colombo'),
>>  ('Asia/Dacca', 'Asia/Dacca'),
>>  ('Asia/Damascus', 'Asia/Damascus'),
>>  ('Asia/Dhaka', 'Asia/Dhaka'),
>>  ('Asia/Dili', 'Asia/Dili'),
>>  ('Asia/Dubai', 'Asia/Dubai'),
>>  ('Asia/Dushanbe', 'Asia/Dushanbe'),
>>  ('Asia/Gaza', 'Asia/Gaza'),
>>  ('Asia/Harbin', 'Asia/Harbin'),
>>  ('Asia/Hebron', 'Asia/Hebron'),
>>  ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>>  ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>>  ('Asia/Hovd', 'Asia/Hovd'),
>>  ('Asia/Irkutsk', 'Asia/Irkutsk'),
>>  ('Asia/Istanbul', 'Asia/Istanbul'),
>>  ('Asia/Jakarta', 'Asia/Jakarta'),
>>  ('Asia/Jayapura', 'Asia/Jayapura'),
>>  ('Asia/Jerusalem', 'Asia/Jerusalem'),
>>  ('Asia/Kabul', 'Asia/Kabul'),
>>  ('Asia/Kamchatka', 'Asia/Kamchatka'),
>>  ('Asia/Karachi', 'Asia/Karachi'),
>>  ('Asia/Kashgar', 'Asia/Kashgar'),
>>  ('Asia/Kathmandu', 'Asia/Kathmandu'),
>>  ('Asia/Katmandu', 'Asia/Katmandu'),
>>  ('Asia/Kolkata', 'Asia/Kolkata'),
>>  ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>>  ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>>  ('Asia/Kuching', 'Asia/Kuching'),
>>  ('Asia/Kuwait', 'Asia/Kuwait'),
>>  ('Asia/Macao', 'Asia/Macao'),
>>  ('Asia/Macau', 'Asia/Macau'),
>>  ('Asia/Magadan', 'Asia/Magadan'),
>>  ('Asia/Makassar', 'Asia/Makassar'),
>>  ('Asia/Manila', 'Asia/Manila'),
>>  ('Asia/Muscat', 'Asia/Muscat'),
>>  ('Asia/Nicosia', 'Asia/Nicosia'),
>>  ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>>  ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>>  ('Asia/Omsk', 'Asia/Omsk'),
>>  ('Asia/Oral', 'Asia/Oral'),
>>  ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>>  ('Asia/Pontianak', 'Asia/Pontianak'),
>>  ('Asia/Pyongyang', 'Asia/Pyongyang'),
>>  ('Asia/Qatar', 'Asia/Qatar'),
>>  ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>>  ('Asia/Rangoon', 'Asia/Rangoon'),
>>  ('Asia/Riyadh', 'Asia/Riyadh'),
>>  ('Asia/Saigon', 'Asia/Saigon'),
>>  ('Asia/Sakhalin', 'Asia/Sakhalin'),
>>  ('Asia/Samarkand', 'Asia/Samarkand'),
>>  ('Asia/Seoul', 'Asia/Seoul'),
>>  ('Asia/Shanghai', 'Asia/Shanghai'),
>>  ('Asia/Singapore', 'Asia/Singapore'),
>>  ('Asia/Taipei', 'Asia/Taipei'),
>>  ('Asia/Tashkent', 'Asia/Tashkent'),
>>  ('Asia/Tbilisi', 'Asia/Tbilisi'),
>>  ('Asia/Tehran', 'Asia/Tehran'),
>>  ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>>  ('Asia/Thimbu', 'Asia/Thimbu'),
>>  ('Asia/Thimphu', 'Asia/Thimphu'),
>>  ('Asia/Tokyo', 'Asia/Tokyo'),
>>  ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>>  ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>>  ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>>  ('Asia/Urumqi', 'Asia/Urumqi'),
>>  ('Asia/Vientiane', 'Asia/Vientiane'),
>>  ('Asia/Vladivostok', 'Asia/Vladivostok'),
>>  ('Asia/Yakutsk', 'Asia/Yakutsk'),
>>  ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>>  ('Asia/Yerevan', 'Asia/Yerevan'),
>>  ('Atlantic/Azores', 'Atlantic/Azores'),
>>  ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>>  ('Atlantic/Canary', 'Atlantic/Canary'),
>>  ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>>  ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>>  ('Atlantic/Faroe', 'Atlantic/Faroe'),
>>  ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>>  ('Atlantic/Madeira', 'Atlantic/Madeira'),
>>  ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>>  ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>>  ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>>  ('Atlantic/Stanley', 'Atlantic/Stanley'),
>>  ('Australia/ACT', 'Australia/ACT'),
>>  ('Australia/Adelaide', 'Australia/Adelaide'),
>>  ('Australia/Brisbane', 'Australia/Brisbane'),
>>  ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>>  ('Australia/Canberra', 'Australia/Canberra'),
>>  ('Australia/Currie', 'Australia/Currie'),
>>  ('Australia/Darwin', 'Australia/Darwin'),
>>  ('Australia/Eucla', 'Australia/Eucla'),
>>  ('Australia/Hobart', 'Australia/Hobart'),
>>  ('Australia/LHI', 'Australia/LHI'),
>>  ('Australia/Lindeman', 'Australia/Lindeman'),
>>  ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>>  ('Australia/Melbourne', 'Australia/Melbourne'),
>>  ('Australia/NSW', 'Australia/NSW'),
>>  ('Australia/North', 'Australia/North'),
>>  ('Australia/Perth', 'Australia/Perth'),
>>  ('Australia/Queensland', 'Australia/Queensland'),
>>  ('Australia/South', 'Australia/South'),
>>  ('Australia/Sydney', 'Australia/Sydney'),
>>  ('Australia/Tasmania', 'Australia/Tasmania'),
>>  ('Australia/Victoria', 'Australia/Victoria'),
>>  ('Australia/West', 'Australia/West'),
>>  ('Australia/Yancowinna', 'Australia/Yancowinna'),
>>  ('Brazil/Acre', 'Brazil/Acre'),
>>  ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>>  ('Brazil/East', 'Brazil/East'),
>>  ('Brazil/West', 'Brazil/West'),
>>  ('CET', 'CET'),
>>  ('CST6CDT', 'CST6CDT'),
>>  ('Canada/Atlantic', 'Canada/Atlantic'),
>>  ('Canada/Central', 'Canada/Central'),
>>  ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>>  ('Canada/Eastern', 'Canada/Eastern'),
>>  ('Canada/Mountain', 'Canada/Mountain'),
>>  ('Canada/Newfoundland', 'Canada/Newfoundland'),
>>  ('Canada/Pacific', 'Canada/Pacific'),
>>  ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>>  ('Canada/Yukon', 'Canada/Yukon'),
>>  ('Chile/Continental', 'Chile/Continental'),
>>  ('Chile/EasterIsland', 'Chile/EasterIsland'),
>>  ('Cuba', 'Cuba'),
>>  ('EET', 'EET'),
>>  ('EST', 'EST'),
>>  ('EST5EDT', 'EST5EDT'),
>>  ('Egypt', 'Egypt'),
>>  ('Eire', 'Eire'),
>>  ('Etc/GMT', 'Etc/GMT'),
>>  ('Etc/GMT+0', 'Etc/GMT+0'),
>>  ('Etc/GMT+1', 'Etc/GMT+1'),
>>  ('Etc/GMT+10', 'Etc/GMT+10'),
>>  ('Etc/GMT+11', 'Etc/GMT+11'),
>>  ('Etc/GMT+12', 'Etc/GMT+12'),
>>  ('Etc/GMT+2', 'Etc/GMT+2'),
>>  ('Etc/GMT+3', 'Etc/GMT+3'),
>>  ('Etc/GMT+4', 'Etc/GMT+4'),
>>  ('Etc/GMT+5', 'Etc/GMT+5'),
>>  ('Etc/GMT+6', 'Etc/GMT+6'),
>>  ('Etc/GMT+7', 'Etc/GMT+7'),
>>  ('Etc/GMT+8', 'Etc/GMT+8'),
>>  ('Etc/GMT+9', 'Etc/GMT+9'),
>>  ('Etc/GMT-0', 'Etc/GMT-0'),
>>  ('Etc/GMT-1', 'Etc/GMT-1'),
>>  ('Etc/GMT-10', 'Etc/GMT-10'),
>>  ('Etc/GMT-11', 'Etc/GMT-11'),
>>  ('Etc/GMT-12', 'Etc/GMT-12'),
>>  ('Etc/GMT-13', 'Etc/GMT-13'),
>>  ('Etc/GMT-14', 'Etc/GMT-14'),
>>  ('Etc/GMT-2', 'Etc/GMT-2'),
>>  ('Etc/GMT-3', 'Etc/GMT-3'),
>>  ('Etc/GMT-4', 'Etc/GMT-4'),
>>  ('Etc/GMT-5', 'Etc/GMT-5'),
>>  ('Etc/GMT-6', 'Etc/GMT-6'),
>>  ('Etc/GMT-7', 'Etc/GMT-7'),
>>  ('Etc/GMT-8', 'Etc/GMT-8'),
>>  ('Etc/GMT-9', 'Etc/GMT-9'),
>>  ('Etc/GMT0', 'Etc/GMT0'),
>>  ('Etc/Greenwich', 'Etc/Greenwich'),
>>  ('Etc/UCT', 'Etc/UCT'),
>>  ('Etc/UTC', 'Etc/UTC'),
>>  ('Etc/Universal', 'Etc/Universal'),
>>  ('Etc/Zulu', 'Etc/Zulu'),
>>  ('Europe/Amsterdam', 'Europe/Amsterdam'),
>>  ('Europe/Andorra', 'Europe/Andorra'),
>>  ('Europe/Athens', 'Europe/Athens'),
>>  ('Europe/Belfast', 'Europe/Belfast'),
>>  ('Europe/Belgrade', 'Europe/Belgrade'),
>>  ('Europe/Berlin', 'Europe/Berlin'),
>>  ('Europe/Bratislava', 'Europe/Bratislava'),
>>  ('Europe/Brussels', 'Europe/Brussels'),
>>  ('Europe/Bucharest', 'Europe/Bucharest'),
>>  ('Europe/Budapest', 'Europe/Budapest'),
>>  ('Europe/Chisinau', 'Europe/Chisinau'),
>>  ('Europe/Copenhagen', 'Europe/Copenhagen'),
>>  ('Europe/Dublin', 'Europe/Dublin'),
>>  ('Europe/Gibraltar', 'Europe/Gibraltar'),
>>  ('Europe/Guernsey', 'Europe/Guernsey'),
>>  ('Europe/Helsinki', 'Europe/Helsinki'),
>>  ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>>  ('Europe/Istanbul', 'Europe/Istanbul'),
>>  ('Europe/Jersey', 'Europe/Jersey'),
>>  ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>>  ('Europe/Kiev', 'Europe/Kiev'),
>>  ('Europe/Lisbon', 'Europe/Lisbon'),
>>  ('Europe/Ljubljana', 'Europe/Ljubljana'),
>>  ('Europe/London', 'Europe/London'),
>>  ('Europe/Luxembourg', 'Europe/Luxembourg'),
>>  ('Europe/Madrid', 'Europe/Madrid'),
>>  ('Europe/Malta', 'Europe/Malta'),
>>  ('Europe/Mariehamn', 'Europe/Mariehamn'),
>>  ('Europe/Minsk', 'Europe/Minsk'),
>>  ('Europe/Monaco', 'Europe/Monaco'),
>>  ('Europe/Moscow', 'Europe/Moscow'),
>>  ('Europe/Nicosia', 'Europe/Nicosia'),
>>  ('Europe/Oslo', 'Europe/Oslo'),
>>  ('Europe/Paris', 'Europe/Paris'),
>>  ('Europe/Podgorica', 'Europe/Podgorica'),
>>  ('Europe/Prague', 'Europe/Prague'),
>>  ('Europe/Riga', 'Europe/Riga'),
>>  ('Europe/Rome', 'Europe/Rome'),
>>  ('Europe/Samara', 'Europe/Samara'),
>>  ('Europe/San_Marino', 'Europe/San_Marino'),
>>  ('Europe/Sarajevo', 'Europe/Sarajevo'),
>>  ('Europe/Simferopol', 'Europe/Simferopol'),
>>  ('Europe/Skopje', 'Europe/Skopje'),
>>  ('Europe/Sofia', 'Europe/Sofia'),
>>  ('Europe/Stockholm', 'Europe/Stockholm'),
>>  ('Europe/Tallinn', 'Europe/Tallinn'),
>>  ('Europe/Tirane', 'Europe/Tirane'),
>>  ('Europe/Tiraspol', 'Europe/Tiraspol'),
>>  ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>>  ('Europe/Vaduz', 'Europe/Vaduz'),
>>  ('Europe/Vatican', 'Europe/Vatican'),
>>  ('Europe/Vienna', 'Europe/Vienna'),
>>  ('Europe/Vilnius', 'Europe/Vilnius'),
>>  ('Europe/Volgograd', 'Europe/Volgograd'),
>>  ('Europe/Warsaw', 'Europe/Warsaw'),
>>  ('Europe/Zagreb', 'Europe/Zagreb'),
>>  ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>>  ('Europe/Zurich', 'Europe/Zurich'),
>>  ('GB', 'GB'),
>>  ('GB-Eire', 'GB-Eire'),
>>  ('GMT', 'GMT'),
>>  ('GMT+0', 'GMT+0'),
>>  ('GMT-0', 'GMT-0'),
>>  ('GMT0', 'GMT0'),
>>  ('Greenwich', 'Greenwich'),
>>  ('HST', 'HST'),
>>  ('Hongkong', 'Hongkong'),
>>  ('Iceland', 'Iceland'),
>>  ('Indian/Antananarivo', 'Indian/Antananarivo'),
>>  ('Indian/Chagos', 'Indian/Chagos'),
>>  ('Indian/Christmas', 'Indian/Christmas'),
>>  ('Indian/Cocos', 'Indian/Cocos'),
>>  ('Indian/Comoro', 'Indian/Comoro'),
>>  ('Indian/Kerguelen', 'Indian/Kerguelen'),
>>  ('Indian/Mahe', 'Indian/Mahe'),
>>  ('Indian/Maldives', 'Indian/Maldives'),
>>  ('Indian/Mauritius', 'Indian/Mauritius'),
>>  ('Indian/Mayotte', 'Indian/Mayotte'),
>>  ('Indian/Reunion', 'Indian/Reunion'),
>>  ('Iran', 'Iran'),
>>  ('Israel', 'Israel'),
>>  ('Jamaica', 'Jamaica'),
>>  ('Japan', 'Japan'),
>>  ('Kwajalein', 'Kwajalein'),
>>  ('Libya', 'Libya'),
>>  ('MET', 'MET'),
>>  ('MST', 'MST'),
>>  ('MST7MDT', 'MST7MDT'),
>>  ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>>  ('Mexico/BajaSur', 'Mexico/BajaSur'),
>>  ('Mexico/General', 'Mexico/General'),
>>  ('NZ', 'NZ'),
>>  ('NZ-CHAT', 'NZ-CHAT'),
>>  ('Navajo', 'Navajo'),
>>  ('PRC', 'PRC'),
>>  ('PST8PDT', 'PST8PDT'),
>>  ('Pacific/Apia', 'Pacific/Apia'),
>>  ('Pacific/Auckland', 'Pacific/Auckland'),
>>  ('Pacific/Chatham', 'Pacific/Chatham'),
>>  ('Pacific/Chuuk', 'Pacific/Chuuk'),
>>  ('Pacific/Easter', 'Pacific/Easter'),
>>  ('Pacific/Efate', 'Pacific/Efate'),
>>  ('Pacific/Enderbury', 'Pacific/Enderbury'),
>>  ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>>  ('Pacific/Fiji', 'Pacific/Fiji'),
>>  ('Pacific/Funafuti', 'Pacific/Funafuti'),
>>  ('Pacific/Galapagos', 'Pacific/Galapagos'),
>>  ('Pacific/Gambier', 'Pacific/Gambier'),
>>  ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>>  ('Pacific/Guam', 'Pacific/Guam'),
>>  ('Pacific/Honolulu', 'Pacific/Honolulu'),
>>  ('Pacific/Johnston', 'Pacific/Johnston'),
>>  ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>>  ('Pacific/Kosrae', 'Pacific/Kosrae'),
>>  ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>>  ('Pacific/Majuro', 'Pacific/Majuro'),
>>  ('Pacific/Marquesas', 'Pacific/Marquesas'),
>>  ('Pacific/Midway', 'Pacific/Midway'),
>>  ('Pacific/Nauru', 'Pacific/Nauru'),
>>  ('Pacific/Niue', 'Pacific/Niue'),
>>  ('Pacific/Norfolk', 'Pacific/Norfolk'),
>>  ('Pacific/Noumea', 'Pacific/Noumea'),
>>  ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>>  ('Pacific/Palau', 'Pacific/Palau'),
>>  ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>>  ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>>  ('Pacific/Ponape', 'Pacific/Ponape'),
>>  ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>>  ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>>  ('Pacific/Saipan', 'Pacific/Saipan'),
>>  ('Pacific/Samoa', 'Pacific/Samoa'),
>>  ('Pacific/Tahiti', 'Pacific/Tahiti'),
>>  ('Pacific/Tarawa', 'Pacific/Tarawa'),
>>  ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>>  ('Pacific/Truk', 'Pacific/Truk'),
>>  ('Pacific/Wake', 'Pacific/Wake'),
>>  ('Pacific/Wallis', 'Pacific/Wallis'),
>>  ('Pacific/Yap', 'Pacific/Yap'),
>>  ('Poland', 'Poland'),
>>  ('Portugal', 'Portugal'),
>>  ('ROC', 'ROC'),
>>  ('ROK', 'ROK'),
>>  ('Singapore', 'Singapore'),
>>  ('Turkey', 'Turkey'),
>>  ('UCT', 'UCT'),
>>  ('US/Alaska', 'US/Alaska'),
>>  ('US/Aleutian', 'US/Aleutian'),
>>  ('US/Arizona', 'US/Arizona'),
>>  ('US/Central', 'US/Central'),
>>  ('US/East-Indiana', 'US/East-Indiana'),
>>  ('US/Eastern', 'US/Eastern'),
>>  ('US/Hawaii', 'US/Hawaii'),
>>  ('US/Indiana-Starke', 'US/Indiana-Starke'),
>>  ('US/Michigan', 'US/Michigan'),
>>  ('US/Mountain', 'US/Mountain'),
>>  ('US/Pacific', 'US/Pacific'),
>>  ('US/Pacific-New', 'US/Pacific-New'),
>>  ('US/Samoa', 'US/Samoa'),
>>  ('UTC', 'UTC'),
>>  ('Universal', 'Universal'),
>>  ('W-SU', 'W-SU'),
>>  ('WET', 'WET'),
>>  ('Zulu', 'Zulu')]
>> FILE_UPLOAD_HANDLERS
>> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>>  'django.core.files.uploadhandler.TemporaryFileUploadHandler')
>> DEFAULT_CONTENT_TYPE
>> 'text/html'
>> DEBUG_STATIC
>> False
>> ACCOUNT_APPROVAL_REQUIRED
>> False
>> APPEND_SLASH
>> True
>> FIRST_DAY_OF_WEEK
>> 0
>> DATABASE_ROUTERS
>> DEFAULT_TABLESPACE
>> YEAR_MONTH_FORMAT
>> 'F Y'
>> STATICFILES_STORAGE
>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>> CACHES
>> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
>> True
>> CKAN_ORIGINS
>> [{'css_class': 'hdx',
>>   'label': 'Humanitarian Data Exchange (HDX)',
>>   'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
>> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
>> False
>> SERVER_EMAIL
>> 'root at localhost'
>> SESSION_COOKIE_PATH
>> USE_X_FORWARDED_HOST
>> False
>> ACCOUNT_OPEN_SIGNUP
>> True
>> ROOT_URLCONF
>> 'geonode.urls'
>> CATALOGUE
>> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>>              'URL': 'http://muchita.cnpm.embrapa.br/catalogue/csw'}}
>> MISSING_THUMBNAIL
>> 'geonode/img/missing_thumb.png'
>> FILE_UPLOAD_TEMP_DIR
>> None
>> MIDDLEWARE_CLASSES
>> ('django.middleware.common.CommonMiddleware',
>>  'django.contrib.sessions.middleware.SessionMiddleware',
>>  'django.contrib.messages.middleware.MessageMiddleware',
>>  'django.middleware.locale.LocaleMiddleware',
>>  'pagination.middleware.PaginationMiddleware',
>>  'django.middleware.csrf.CsrfViewMiddleware',
>>  'django.contrib.auth.middleware.AuthenticationMiddleware',
>>  'django.middleware.clickjacking.XFrameOptionsMiddleware')
>> USE_I18N
>> True
>> THOUSAND_SEPARATOR
>> SECRET_KEY
>> MODELTRANSLATION_FALLBACK_LANGUAGES
>> ('en',)
>> LANGUAGE_COOKIE_NAME
>> 'django_language'
>> ACCOUNT_REMEMBER_ME_EXPIRY
>> 315360000
>> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
>> ACCOUNT_EMAIL_UNIQUE
>> True
>> TRANSACTIONS_MANAGED
>> False
>> LOGGING_CONFIG
>> 'django.utils.log.dictConfig'
>> TEMPLATE_LOADERS
>> ('django.template.loaders.filesystem.Loader',
>>  'django.template.loaders.app_directories.Loader')
>> FORCE_SCRIPT_NAME
>> None
>> TASTYPIE_DEFAULT_FORMATS
>> ['json']
>> TEMPLATE_DEBUG
>> True
>> AUTO_GENERATE_AVATAR_SIZES
>> (20, 32, 80, 100, 140, 200)
>> CSRF_COOKIE_NAME
>> 'csrftoken'
>> 'default'
>> CELERY_DEFAULT_ROUTING_KEY
>> ACCOUNT_LOGIN_REDIRECT_URL
>> u'/'
>> CELERY_ALWAYS_EAGER
>> True
>> MODIFY_TOPICCATEGORY
>> False
>> SIGNING_BACKEND
>> 'django.core.signing.TimestampSigner'
>> SESSION_COOKIE_SECURE
>> False
>> ACCOUNT_LOGIN_URL
>> u'account_login'
>> CACHE_TIME
>> 0
>> PYCSW
>> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>>                                         'contact_email': 'Email Address',
>>                                         'contact_name': 'Organization Name',
>>                                         'date': 'YYYY-MM-DD',
>>                                         'default_language': 'eng',
>>                                         'enabled': 'true',
>>                                         'gemet_keywords': 'Utility and governmental services',
>>                                         'languages_supported': 'eng,gre',
>>                                         'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>>                    'metadata:main': {'contact_address': 'Mailing Address',
>>                                      'contact_city': 'City',
>>                                      'contact_country': 'Country',
>>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>>                                      'contact_hours': 'Hours of Service',
>>                                      'contact_instructions': 'During hours of service. Off on weekends.',
>>                                      'contact_name': 'Lastname, Firstname',
>>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>>                                      'contact_position': 'Position Title',
>>                                      'contact_postalcode': 'Zip or Postal Code',
>>                                      'contact_role': 'pointOfContact',
>>                                      'contact_stateorprovince': 'Administrative Area',
>>                                      'contact_url': 'Contact URL',
>>                                      'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing,              and collaborative use of geospatial data',
>>                                      'identification_accessconstraints': 'None',
>>                                      'identification_fees': 'None',
>>                                      'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>>                                      'identification_keywords_type': 'theme',
>>                                      'identification_title': 'GeoNode Catalogue',
>>                                      'provider_name': 'Organization Name',
>>                                      'provider_url': 'http://localhost:8000/'}}}
>> CSRF_COOKIE_DOMAIN
>> None
>> FILE_CHARSET
>> 'utf-8'
>> DEBUG
>> True
>> SESSION_FILE_PATH
>> None
>> DEFAULT_FILE_STORAGE
>> 'django.core.files.storage.FileSystemStorage'
>> INSTALLED_APPS
>> ('django.contrib.auth',
>>  'django.contrib.contenttypes',
>>  'django.contrib.sessions',
>>  'django.contrib.sites',
>>  'django.contrib.admin',
>>  'django.contrib.sitemaps',
>>  'django.contrib.staticfiles',
>>  'django.contrib.messages',
>>  'django.contrib.humanize',
>>  'django.contrib.gis',
>>  'pagination',
>>  'taggit',
>>  'friendlytagloader',
>>  'geoexplorer',
>>  'leaflet',
>>  'django_extensions',
>>  'autocomplete_light',
>>  'mptt',
>>  'modeltranslation',
>>  'djcelery',
>>  'pinax_theme_bootstrap_account',
>>  'pinax_theme_bootstrap',
>>  'django_forms_bootstrap',
>>  'account',
>>  'avatar',
>>  'dialogos',
>>  'agon_ratings',
>>  'announcements',
>>  'actstream',
>>  'user_messages',
>>  'tastypie',
>>  'polymorphic',
>>  'guardian',
>>  'geonode.people',
>>  'geonode.base',
>>  'geonode.layers',
>>  'geonode.maps',
>>  'geonode.proxy',
>>  'geonode.security',
>>  'geonode.social',
>>  'geonode.catalogue',
>>  'geonode.documents',
>>  'geonode.api',
>>  'geonode.groups',
>>  'geonode.services',
>>  'geonode.geoserver',
>>  'geonode.upload',
>>  'geonode.tasks')
>> LANGUAGES_BIDI
>> ('he', 'ar', 'fa', 'ur')
>> USE_L10N
>> False
>> DATABASE_ENGINE
>> STATIC_ROOT
>> '/var/www/geonode/static/'
>> STATICFILES_DIRS
>> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
>> DATABASE_NAME
>> 'geonode'
>> LEAFLET_CONFIG
>> {'PLUGINS': {u'ALL': {u'css': [u'/static/leaflet/draw/leaflet.draw.css',
>>                                '/static/lib/css/leaflet.fullscreen.css'],
>>                       u'js': [u'/static/leaflet/draw/leaflet.draw.js',
>>                               u'/static/leaflet/leaflet.extras.js',
>>                               u'/static/leaflet/leaflet.forms.js',
>>                               '/static/lib/js/Leaflet.fullscreen.min.js',
>>                               '/static/lib/js/esri-leaflet.js']},
>>              u'__default__': {u'css': ['/static/lib/css/leaflet.fullscreen.css'],
>>                               u'js': ['/static/lib/js/Leaflet.fullscreen.min.js',
>>              u'__is_normalized__': True,
>>              'esri-leaflet': {'auto-include': True,
>>                               u'css': [],
>>                               'js': ['/static/lib/js/esri-leaflet.js']},
>>              u'forms': {u'auto-include': False,
>>                         u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
>>                                 u'/static/leaflet/leaflet.forms.js']},
>>              'leaflet-fullscreen': {'auto-include': True,
>>                                     'js': ['/static/lib/js/Leaflet.fullscreen.min.js']}},
>>  'TILES': [('Watercolor',
>>             'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
>>            ('Toner Lite',
>>             'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>')]}
>> DOWNLOAD_FORMATS_VECTOR
>> ['JPEG',
>>  'PDF',
>>  'PNG',
>>  'Zipped Shapefile',
>>  'GML 2.0',
>>  'GML 3.1.1',
>>  'CSV',
>>  'Excel',
>>  'GeoJSON',
>>  'KML',
>>  'Tiles']
>> PREPEND_WWW
>> False
>> SECURE_PROXY_SSL_HEADER
>> None
>> SOCIAL_ORIGINS
>> [{'css_class': 'email',
>>   'label': 'Email',
>>   'url': 'mailto:?subject={name}&body={url}'},
>>  {'css_class': 'fb',
>>   'label': 'Facebook',
>>   'url': 'http://www.facebook.com/sharer.php?u={url}'},
>>  {'css_class': 'tw',
>>   'label': 'Twitter',
>>   'url': 'https://twitter.com/share?url={url}'},
>>  {'css_class': 'gp',
>>   'label': 'Google +',
>>   'url': 'https://plus.google.com/share?url={url}'}]
>> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
>> SESSION_COOKIE_HTTPONLY
>> True
>> DATABASE_PORT
>> '5432'
>> DEBUG_PROPAGATE_EXCEPTIONS
>> False
>> DEFAULT_ANONYMOUS_VIEW_PERMISSION
>> True
>> MEDIA_URL
>> '/uploaded/'
>> MONTH_DAY_FORMAT
>> 'F j'
>> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
>> u'account_login'
>> LOGIN_URL
>> '/account/login/'
>> SESSION_EXPIRE_AT_BROWSER_CLOSE
>> False
>> OGP_URL
>> 'http://geodata.tufts.edu/solr/select'
>> CELERY_EAGER_PROPAGATES_EXCEPTIONS
>> True
>> TIME_FORMAT
>> 'P'
>> CELERY_IGNORE_RESULT
>> True
>> SERVICE_UPDATE_INTERVAL
>> 0
>> AUTH_USER_MODEL
>> 'people.Profile'
>> DATE_INPUT_FORMATS
>> ('%Y-%m-%d',
>>  '%m/%d/%Y',
>>  '%m/%d/%y',
>>  '%b %d %Y',
>>  '%b %d, %Y',
>>  '%d %b %Y',
>>  '%d %b, %Y',
>>  '%B %d %Y',
>>  '%B %d, %Y',
>>  '%d %B %Y',
>>  '%d %B, %Y')
>> ACCOUNT_LOGOUT_REDIRECT_URL
>> u'/'
>> HAYSTACK_SEARCH
>> False
>> AUTHENTICATION_BACKENDS
>> ('django.contrib.auth.backends.ModelBackend',
>>  'guardian.backends.ObjectPermissionBackend')
>> EMAIL_HOST_PASSWORD
>> CELERY_DISABLE_RATE_LIMITS
>> True
>> PASSWORD_RESET_TIMEOUT_DAYS
>> CACHE_MIDDLEWARE_ALIAS
>> 'default'
>> SESSION_SAVE_EVERY_REQUEST
>> False
>> NUMBER_GROUPING
>> 0
>> SHORT_DATETIME_FORMAT
>> 'm/d/Y P'
>> SESSION_ENGINE
>> 'django.contrib.sessions.backends.db'
>> CELERY_RESULT_BACKEND
>> None
>> ACCOUNT_DELETION_MARK_CALLBACK
>> CSRF_COOKIE_PATH
>> LOGIN_REDIRECT_URL
>> '/accounts/profile/'
>> SITEURL
>> 'http://muchita.cnpm.embrapa.br/'
>> PROJECT_ROOT
>> '/usr/local/lib/python2.7/dist-packages/geonode'
>> ACCOUNT_DELETION_EXPUNGE_HOURS
>> 48
>> GEONODE_ROOT
>> DECIMAL_SEPARATOR
>> CSRF_FAILURE_VIEW
>> 'django.views.csrf.csrf_failure'
>> CELERY_SEND_EVENTS
>> False
>> NOSE_ARGS
>> ['--nocapture', '--detailed-errors']
>> LOCALE_PATHS
>> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
>> THEME_ACCOUNT_CONTACT_EMAIL
>> 'admin at example.com'
>> PASSWORD_HASHERS
>> PROXY_ALLOWED_HOSTS
>> MESSAGE_STORAGE
>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>> USE_QUEUE
>> False
>> COMMENTS_ALLOW_PROFANITIES
>> False
>> LOGOUT_URL
>> '/account/logout/'
>> MAP_BASELAYERS
>> [{'source': {'ptype': 'gxp_wmscsource',
>>              'restUrl': '/gs/rest',
>>              'url': 'http://muchita.cnpm.embrapa.br/geoserver/wms'}},
>>  {'args': ['No background'],
>>   'fixed': True,
>>   'group': 'background',
>>   'source': {'ptype': 'gxp_olsource'},
>>   'type': 'OpenLayers.Layer',
>>   'visibility': False},
>>  {'args': ['OpenStreetMap'],
>>   'fixed': True,
>>   'type': 'OpenLayers.Layer.OSM',
>>  {'group': 'background',
>>   'name': 'osm',
>>   'source': {'ptype': 'gxp_mapquestsource'},
>>   'visibility': True},
>>   'name': 'naip',
>>  {'fixed': True,
>>   'name': 'AerialWithLabels',
>>   'source': {'ptype': 'gxp_bingsource'},
>>  {'source': {'ptype': 'gxp_mapboxsource'}}]
>> EMAIL_USE_TLS
>> False
>> ACCOUNT_LANGUAGES
>> [('en', u'English'),
>>  ('es', u'espa\xf1ol'),
>>  ('it', u'italiano'),
>>  ('fr', u'fran\xe7ais'),
>>  ('de', u'Deutsch'),
>>  ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>>  ('id', u'Bahasa Indonesia'),
>>  ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
>>  ('ja', u'\u65e5\u672c\u8a9e'),
>>  ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
>>  ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
>>  ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
>>  ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
>>  ('sq', u'shqip'),
>>  ('af', u'Afrikaans'),
>>  ('sw', u'Kiswahili'),
>>  ('pt', u'Portugu\xeas'),
>>  ('pt-br', u'Portugu\xeas Brasileiro'),
>>  ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
>>  ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
>>  ('ko', u'\ud55c\uad6d\uc5b4'),
>>  ('am', 'Amharic'),
>>  ('km', u'Khmer'),
>>  ('pl', u'polski'),
>>  ('sv', u'svenska'),
>>  ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
>>  ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
>>  ('si', 'sinhala'),
>>  ('ta', u'tamil'),
>>  ('tl', 'tagalog')]
>> FIXTURE_DIRS
>> ABSOLUTE_URL_OVERRIDES
>> DATE_FORMAT
>> 'N j, Y'
>> OGC_SERVER
>> {'default': {'BACKEND': 'geonode.geoserver',
>>              'BACKEND_WRITE_ENABLED': True,
>>              'DATASTORE': 'datastore',
>>              'GEOGIG_DATASTORE_DIR': '',
>>              'GEONODE_SECURITY_ENABLED': True,
>>              'LOCATION': 'http://localhost:8080/geoserver/',
>>              'LOG_FILE': '/usr/share/geoserver/data/logs/geoserver.log',
>>              'MAPFISH_PRINT_ENABLED': True,
>>              'PRINT_NG_ENABLED': True,
>>              'PUBLIC_LOCATION': 'http://muchita.cnpm.embrapa.br/geoserver/',
>>              'USER': 'admin',
>>              'WMST_ENABLED': False,
>>              'WPS_ENABLED': True}}
>> SKIP_PERMS_FILTER
>> False
>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
>> MEDIA_ROOT
>> '/var/www/geonode/uploaded'
>> AGON_RATINGS_CATEGORY_CHOICES
>> {'documents.Document': {'document': 'How good is this document?'},
>>  'layers.Layer': {'layer': 'How good is this layer?'},
>>  'maps.Map': {'map': 'How good is this map?'}}
>> DATABASE_HOST
>> DEFAULT_EXCEPTION_REPORTER_FILTER
>> 'django.views.debug.SafeExceptionReporterFilter'
>> ADMINS
>> FORMAT_MODULE_PATH
>> None
>> DEFAULT_FROM_EMAIL
>> GEONODE_APPS
>> ('geonode.people',
>>  'geonode.base',
>>  'geonode.layers',
>>  'geonode.maps',
>>  'geonode.proxy',
>>  'geonode.security',
>>  'geonode.social',
>>  'geonode.api',
>>  'geonode.groups',
>>  'geonode.services',
>>  'geonode.upload',
>>  'geonode.tasks')
>> GEOSERVER_URL
>> DATETIME_FORMAT
>> 'N j, Y, P'
>> TEMPLATE_DIRS
>> ('/etc/geonode/templates',
>>  '/usr/local/lib/python2.7/dist-packages/geonode/templates')
>> ALLOWED_DOCUMENT_TYPES
>> ['doc',
>>  'docx',
>>  'gif',
>>  'jpg',
>>  'jpeg',
>>  'ods',
>>  'odt',
>>  'odp',
>>  'pdf',
>>  'png',
>>  'ppt',
>>  'pptx',
>>  'rar',
>>  'tif',
>>  'tiff',
>>  'txt',
>>  'xls',
>>  'xlsx',
>>  'xml',
>>  'zip',
>>  'gz']
>> NOTIFICATION_LANGUAGE_MODULE
>> 'account.Account'
>> ACCOUNT_DELETION_EXPUNGE_CALLBACK
>> RESOURCE_PUBLISHING
>> False
>> ACCOUNT_HOOKSET
>> <account.hooks.AccountDefaultHookSet object at 0x7fe06f67d210>
>> PROXY_URL
>> '/proxy/?url='
>> SITE_ID
>> 1
>> DISALLOWED_USER_AGENTS
>> ALLOWED_INCLUDE_ROOTS
>> API_LIMIT_PER_PAGE
>> ACCOUNT_SETTINGS_REDIRECT_URL
>> u'account_settings'
>> EXTRA_LANG_INFO
>> {'am': {'bidi': False,
>>         'code': 'am',
>>         'name': 'Amharic',
>>         'name_local': 'Amharic'},
>>  'si': {'bidi': False,
>>         'code': 'si',
>>         'name': 'Sinhala',
>>         'name_local': 'sinhala'},
>>  'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
>>  'tl': {'bidi': False,
>>         'code': 'tl',
>>         'name': 'Tagalog',
>>         'name_local': 'tagalog'}}
>> LOGGING
>> {'disable_existing_loggers': True,
>>  'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>>  'formatters': {'simple': {'format': '%(message)s'},
>>                 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>>  'handlers': {'console': {'class': 'logging.StreamHandler',
>>                           'formatter': 'simple',
>>                           'level': 'ERROR'},
>>               'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>>                               'filters': ['require_debug_false'],
>>                               'level': 'ERROR'},
>>               'null': {'class': 'django.utils.log.NullHandler',
>>                        'level': 'ERROR'}},
>>  'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>>              'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
>>  'version': 1}
>> SHORT_DATE_FORMAT
>> 'm/d/Y'
>> DATABASE_USER
>> 'geonode'
>> TEST_RUNNER
>> 'django_nose.NoseTestSuiteRunner'
>> ACTSTREAM_SETTINGS
>> {'FETCH_RELATIONS': True,
>>  'GFK_FETCH_DEPTH': 1,
>>  'MODELS': ('people.Profile',
>>             'layers.layer',
>>             'maps.map',
>>             'dialogos.comment',
>>             'documents.document',
>>             'services.service'),
>>  'USE_JSONFIELD': True,
>>  'USE_PREFETCH': False}
>> MODELTRANSLATION_LANGUAGES
>> ['en']
>> HAYSTACK_FACET_COUNTS
>> False
>> CACHE_MIDDLEWARE_KEY_PREFIX
>> DEFAULT_WORKSPACE
>> 'geonode'
>> TIME_ZONE
>> 'America/Chicago'
>> FILE_UPLOAD_MAX_MEMORY_SIZE
>> 2621440
>> LOCAL_GEOSERVER
>> EMAIL_BACKEND
>> 'django.core.mail.backends.smtp.EmailBackend'
>> ANONYMOUS_USER_ID
>> -1
>> POSTGIS_VERSION
>> (2, 1, 0)
>> DEFAULT_MAP_ZOOM
>> 0
>> TEMPLATE_CONTEXT_PROCESSORS
>> ('django.contrib.auth.context_processors.auth',
>>  'django.core.context_processors.debug',
>>  'django.core.context_processors.i18n',
>>  'django.core.context_processors.tz',
>>  'django.core.context_processors.media',
>>  'django.core.context_processors.static',
>>  'django.core.context_processors.request',
>>  'django.contrib.messages.context_processors.messages',
>>  'account.context_processors.account',
>>  'geonode.context_processors.resource_urls',
>>  'geonode.geoserver.context_processors.geoserver_urls')
>> CELERY_QUEUES
>> [<unbound Queue 'default' -> <unbound Exchange ''(direct)> -> default>,
>>  <unbound Queue 'cleanup' -> <unbound Exchange ''(direct)> -> cleanup>,
>>  <unbound Queue 'update' -> <unbound Exchange ''(direct)> -> update>,
>>  <unbound Queue 'email' -> <unbound Exchange ''(direct)> -> email>]
>> LOCKDOWN_GEONODE
>> False
>> SESSION_COOKIE_AGE
>> 1209600
>> SETTINGS_MODULE
>> 'geonode.settings'
>> GUARDIAN_GET_INIT_ANONYMOUS_USER
>> 'geonode.people.models.get_anonymous_user_instance'
>> USE_ETAGS
>> False
>> SOCIAL_BUTTONS
>> True
>> LANGUAGES
>> (('en', 'English'),
>>  ('es', 'Espa\xc3\xb1ol'),
>>  ('it', 'Italiano'),
>>  ('fr', 'Fran\xc3\xa7ais'),
>>  ('de', 'Deutsch'),
>>  ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>>  ('id', 'Bahasa Indonesia'),
>>  ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
>>  ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
>>  ('fa', 'Persian'),
>>  ('ar', 'Arabic'),
>>  ('bn', 'Bengali'),
>>  ('ne', 'Nepali'),
>>  ('sq', 'Albanian'),
>>  ('af', 'Afrikaans'),
>>  ('sw', 'Swahili'),
>>  ('pt', 'Portuguese'),
>>  ('pt-br', 'Portugu\xc3\xaas Brasil'),
>>  ('ru', 'Russian'),
>>  ('vi', 'Vietnamese'),
>>  ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
>>  ('am', 'Amharic'),
>>  ('km', 'Khmer'),
>>  ('pl', 'Polish'),
>>  ('sv', 'Swedish'),
>>  ('th', 'Thai'),
>>  ('uk', 'Ukranian'),
>>  ('si', 'Sinhala'),
>>  ('ta', 'Tamil'),
>>  ('tl', 'Tagalog'))
>> CELERY_TASK_RESULT_EXPIRES
>> 1
>> DEFAULT_INDEX_TABLESPACE
>> INTERNAL_IPS
>> STATIC_URL
>> '/static/'
>> EMAIL_PORT
>> 25
>> LAYER_PREVIEW_LIBRARY
>> 'geoext'
>> USE_TZ
>> False
>> DEFAULT_SEARCH_SIZE
>> 10
>> CLIENT_RESULTS_LIMIT
>> 100
>> MODELTRANSLATION_DEFAULT_LANGUAGE
>> 'en'
>> ACCOUNT_SIGNUP_REDIRECT_URL
>> u'/'
>> DOCUMENT_TYPE_MAP
>> {'doc': 'text',
>>  'docx': 'text',
>>  'gif': 'image',
>>  'gz': 'archive',
>>  'jpeg': 'image',
>>  'jpg': 'image',
>>  'log': 'text',
>>  'odp': 'presentation',
>>  'ods': 'text',
>>  'odt': 'text',
>>  'pdf': 'presentation',
>>  'png': 'image',
>>  'ppt': 'presentation',
>>  'pptx': 'presentation',
>>  'rar': 'archive',
>>  'tif': 'image',
>>  'tiff': 'image',
>>  'txt': 'text',
>>  'xls': 'text',
>>  'xlsx': 'text',
>>  'xml': 'text',
>>  'zip': 'archive'}
>> CACHE_MIDDLEWARE_SECONDS
>> 600
>> SITENAME
>> 'GeoNode'
>> ACCOUNT_CREATE_ON_SAVE
>> True
>> CSRF_COOKIE_HTTPONLY
>> False
>> DATETIME_INPUT_FORMATS
>> ('%Y-%m-%d %H:%M:%S',
>>  '%Y-%m-%d %H:%M:%S.%f',
>>  '%Y-%m-%d %H:%M',
>>  '%Y-%m-%d',
>>  '%m/%d/%Y %H:%M:%S',
>>  '%m/%d/%Y %H:%M:%S.%f',
>>  '%m/%d/%Y %H:%M',
>>  '%m/%d/%Y',
>>  '%m/%d/%y %H:%M:%S',
>>  '%m/%d/%y %H:%M:%S.%f',
>>  '%m/%d/%y %H:%M',
>>  '%m/%d/%y')
>> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
>> False
>> DATABASE_PASSWORD
>> PROFANITIES_LIST
>> EMAIL_HOST_USER
>> MAX_DOCUMENT_SIZE
>> 2
>> You're seeing this error because you have DEBUG = True in your Django
>> settings file. Change that to False, and Django will display a standard
>> 500 page.
>> Davi de O. Custódio
> Davi de O. Custódio
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150527/161ec36c/attachment-0001.html>
More information about the geonode-users mailing list
