[GeoNode-users] Problems to change Geonode database name
Ariel Nunez ingenieroariel at gmail.com
Wed May 27 06:53:10 PDT 2015
Also, make sure to look for a local_settings.py symlink in the folder where
geonode is installed (you can find this folder by doing: python -c "import
geonode;print geonode.__file__" )
-a
On Wed, May 27, 2015 at 8:01 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> There could be two reasons for this:
> - the local_settings contain a syntax error and geonode is ignoring them
> - the local_settings are not readable by geonode, but if you installed it
> with apt-get (and you are editing /etc/geonode/local_settings.py) then is
> not the case
> 2015-05-27 14:57 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
>> Simone, how do I force Django to respect the new local_settings settings?
>> On Wed, May 27, 2015 at 9:56 AM, Davi Custodio <davicustodio at gmail.com>
>> wrote:
>>> I forgot to put the setting of my local_settings.py:
>>> DATABASE_ENGINE = 'postgresql_psycopg2'
>>> DATABASE_NAME = 'cnpm_geonode'
>>> DATABASE_USER = 'geonode'
>>> DATABASE_PASSWORD = '*****'
>>> DATABASE_HOST = 'jatoba.cnpm.embrapa.br'
>>> DATABASE_PORT = '5432'
>>> DATABASES = {
>>>     'default': {
>>>         'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>>         'NAME': DATABASE_NAME,
>>>         'USER': DATABASE_USER,
>>>         'PASSWORD': DATABASE_PASSWORD,
>>>         'HOST': DATABASE_HOST,
>>>         'PORT': DATABASE_PORT,
>>>     'datastore': {
>>>         'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>>         'NAME': 'cnpm_geonode_data',
>>> On Wed, May 27, 2015 at 9:50 AM, Davi Custodio <davicustodio at gmail.com>
>>> wrote:
>>>> Hello. I have problem in GeoNode 2.4 to rename the GeoNode database. I
>>>> need to change the names of "GeoNode" and "geonode_data" because I am
>>>> centralizing the databases of various GeoNode servers in the same instance
>>>> of PostgreSQL.
>>>> I changed the names in local_settings.py, and then restarted the
>>>> apache, and I received an error to Django still trying to find a database
>>>> with old name "GeoNode".
>>>> Besides local_settings.py, there is another location that I should
>>>> change the database name?
>>>> Below the full log.
>>>> Davi.
>>>> OperationalError at /
>>>> FATAL:  database "geonode" does not exist
>>>> Request Method:GETRequest URL:http://muchita.cnpm.embrapa.br/Django
>>>> Version:1.6.1Exception Type:OperationalErrorException Value:
>>>> Exception Location:/usr/lib/python2.7/dist-packages/psycopg2/__init__.py
>>>> in connect, line 179Python Executable:/usr/bin/pythonPython Version:
>>>> 2.7.6Python Path:
>>>> ['/usr/lib/python2.7',
>>>>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>>  '/usr/lib/python2.7/lib-tk',
>>>>  '/usr/lib/python2.7/lib-old',
>>>>  '/usr/lib/python2.7/lib-dynload',
>>>>  '/usr/local/lib/python2.7/dist-packages',
>>>>  '/usr/lib/python2.7/dist-packages',
>>>>  '/usr/lib/python2.7/dist-packages/PILcompat',
>>>>  '/usr/lib/pymodules/python2.7',
>>>>  '/var/www']
>>>> Server time:Qua, 27 Mai 2015 07:36:18 -0500
>>>> Traceback Switch to copy-and-paste view
>>>> <http://muchita.cnpm.embrapa.br/#>
>>>>    - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>>>>    get_response
>>>>    1.
>>>>                       response = response.render()
>>>>    ▶ Local vars <http://muchita.cnpm.embrapa.br/#>
>>>>    - /usr/lib/python2.7/dist-packages/django/template/response.py in
>>>>    render
>>>>    1.
>>>>                   self.content = self.rendered_content
>>>>    rendered_content
>>>>    1.
>>>>               context = self.resolve_context(self.context_data)
>>>>    resolve_context
>>>>    1.
>>>>               return RequestContext(self._request, context, current_app=self._current_app)
>>>>    - /usr/lib/python2.7/dist-packages/django/template/context.py in
>>>>    __init__
>>>>    1.
>>>>                   self.update(processor(request))
>>>>    /usr/local/lib/python2.7/dist-packages/geonode/context_processors.py
>>>>     in resource_urls
>>>>    1.
>>>>           site = Site.objects.get_current()
>>>>    - /usr/lib/python2.7/dist-packages/django/contrib/sites/models.py
>>>>     in get_current
>>>>    1.
>>>>                   current_site = self.get(pk=sid)
>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in
>>>>    get
>>>>    1.
>>>>               return self.get_queryset().get(*args, **kwargs)
>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in get
>>>>    1.
>>>>               num = len(clone)
>>>>    __len__
>>>>    1.
>>>>               self._fetch_all()
>>>>    _fetch_all
>>>>    1.
>>>>                   self._result_cache = list(self.iterator())
>>>>    iterator
>>>>    1.
>>>>               for row in compiler.results_iter():
>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>>>     in results_iter
>>>>    1.
>>>>               for rows in self.execute_sql(MULTI):
>>>>     in execute_sql
>>>>    1.
>>>>               cursor = self.connection.cursor()
>>>>    - /usr/lib/python2.7/dist-packages/django/db/backends/__init__.py
>>>>     in cursor
>>>>    1.
>>>>                   cursor = self.make_debug_cursor(self._cursor())
>>>>     in _cursor
>>>>    1.
>>>>               self.ensure_connection()
>>>>     in ensure_connection
>>>>    1.
>>>>                       self.connect()
>>>>    - /usr/lib/python2.7/dist-packages/django/db/utils.py in __exit__
>>>>    1.
>>>>                       six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>>    1.
>>>>                       self.connect()
>>>>     in connect
>>>>    1.
>>>>               self.connection = self.get_new_connection(conn_params)
>>>>    /usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>>>     in get_new_connection
>>>>    1.
>>>>               return Database.connect(**conn_params)
>>>>    - /usr/lib/python2.7/dist-packages/psycopg2/__init__.py in connect
>>>>    1.
>>>>               connection_factory=connection_factory, async=async)
>>>> Request informationGET
>>>> No GET data
>>>> POST
>>>> No POST data
>>>> FILES
>>>> No FILES data
>>>> COOKIESVariableValue__utmz
>>>> '128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)'
>>>> ys-user
>>>> 'o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>>>> _ga
>>>> 'GA1.2.1150756117.1398259583'
>>>> __gads
>>>> 'ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ'
>>>> csrftoken
>>>> 'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>>>> s_getNewRepeat
>>>> '1423508214723-Repeat'
>>>> ys-alreadyShowMessage
>>>> 'b%3A1'
>>>> __utma
>>>> '128008848.1150756117.1398259583.1432729377.1432729377.1'
>>>> __utmb
>>>> '128008848.1.10.1432729377'
>>>> __utmc
>>>> '128008848'
>>>> s_fid
>>>> '691159BDD05014BE-21BD7FC62185D9C7'
>>>> METAVariableValuemod_wsgi.listener_port
>>>> '80'
>>>> HTTP_COOKIE
>>>> '__gads=ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ; __utmz=237664978.1423046483.18.3.utmccn=(referral)|utmcsr=google.com.br|utmcct=/|utmcmd=referral; __utma=237664978.1207420118.1398169929.1423046483.1423244128.19; s_fid=691159BDD05014BE-21BD7FC62185D9C7; s_getNewRepeat=1423508214723-Repeat; __utma=218996109.1150756117.1398259583.1432299746.1432304989.52; __utmz=218996109.1432304989.52.23.utmcsr=chorao.cnpm.embrapa.br:9081|utmccn=(referral)|utmcmd=referral|utmcct=/; _ga=GA1.2.1150756117.1398259583; csrftoken=GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb; __utma=128008848.1150756117.1398259583.1432729377.1432729377.1; __utmb=128008848.1.10.1432729377; __utmc=128008848; __utmz=128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); ys-alreadyShowMessage=b%3A1; ys-user=o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>>>> mod_wsgi.listener_host
>>>> CONTEXT_DOCUMENT_ROOT
>>>> '/var/www'
>>>> SERVER_SOFTWARE
>>>> 'Apache/2.4.7 (Ubuntu)'
>>>> SCRIPT_NAME
>>>> u''
>>>> mod_wsgi.enable_sendfile
>>>> '0'
>>>> mod_wsgi.handler_script
>>>> SERVER_SIGNATURE
>>>> '<address>Apache/2.4.7 (Ubuntu) Server at muchita.cnpm.embrapa.br Port 80</address>\n'
>>>> REQUEST_METHOD
>>>> 'GET'
>>>> PATH_INFO
>>>> u'/'
>>>> SERVER_PROTOCOL
>>>> 'HTTP/1.1'
>>>> QUERY_STRING
>>>> HTTP_USER_AGENT
>>>> 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.65 Safari/537.36'
>>>> HTTP_CONNECTION
>>>> 'keep-alive'
>>>> SERVER_NAME
>>>> 'muchita.cnpm.embrapa.br'
>>>> REMOTE_ADDR
>>>> '10.157.20.55'
>>>> mod_wsgi.queue_start
>>>> '1432730176843671'
>>>> mod_wsgi.request_handler
>>>> 'wsgi-script'
>>>> wsgi.url_scheme
>>>> 'http'
>>>> PATH_TRANSLATED
>>>> '/var/www/geonode/wsgi/geonode.wsgi/'
>>>> SERVER_PORT
>>>> '80'
>>>> wsgi.multiprocess
>>>> True
>>>> mod_wsgi.input_chunked
>>>> '0'
>>>> SERVER_ADDR
>>>> '192.168.10.10'
>>>> DOCUMENT_ROOT
>>>> '/var/www'
>>>> mod_wsgi.process_group
>>>> 'geonode'
>>>> HTTP_PRAGMA
>>>> 'no-cache'
>>>> SCRIPT_FILENAME
>>>> '/var/www/geonode/wsgi/geonode.wsgi'
>>>> SERVER_ADMIN
>>>> 'webmaster at localhost'
>>>> wsgi.input
>>>> <mod_wsgi.Input object at 0x7fe089acf530>
>>>> HTTP_HOST
>>>> CONTEXT_PREFIX
>>>> wsgi.multithread
>>>> True
>>>> mod_wsgi.callable_object
>>>> 'application'
>>>> HTTP_CACHE_CONTROL
>>>> 'no-cache'
>>>> REQUEST_URI
>>>> HTTP_ACCEPT
>>>> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
>>>> wsgi.version
>>>> (1, 0)
>>>> GATEWAY_INTERFACE
>>>> 'CGI/1.1'
>>>> wsgi.run_once
>>>> False
>>>> wsgi.errors
>>>> <mod_wsgi.Log object at 0x7fe0899a1f70>
>>>> REMOTE_PORT
>>>> '51799'
>>>> HTTP_ACCEPT_LANGUAGE
>>>> 'pt-PT,pt;q=0.8,pt-BR;q=0.6,en-US;q=0.4,en;q=0.2'
>>>> REQUEST_SCHEME
>>>> 'http'
>>>> mod_wsgi.version
>>>> (3, 4)
>>>> mod_wsgi.application_group
>>>> 'aguai.cnpm.embrapa.br|'
>>>> mod_wsgi.script_reloading
>>>> '1'
>>>> wsgi.file_wrapper
>>>> CSRF_COOKIE
>>>> u'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>>>> HTTP_ACCEPT_ENCODING
>>>> 'gzip, deflate, sdch'
>>>> SettingsUsing settings module geonode.settingsSettingValue
>>>> CASCADE_WORKSPACE
>>>> 'geonode'
>>>> ACCOUNT_USER_DISPLAY
>>>> DATABASES
>>>> {'datastore': {'ATOMIC_REQUESTS': False,
>>>>                'AUTOCOMMIT': True,
>>>>                'CONN_MAX_AGE': 0,
>>>>                'HOST': 'jatoba.cnpm.embrapa.br',
>>>>                'NAME': 'geonode_data',
>>>>                'OPTIONS': {},
>>>>                'PASSWORD': u'********************',
>>>>                'PORT': '5432',
>>>>                'TEST_CHARSET': None,
>>>>                'TEST_COLLATION': None,
>>>>                'TEST_MIRROR': None,
>>>>                'TEST_NAME': None,
>>>>                'TIME_ZONE': 'America/Chicago',
>>>>                'USER': 'geonode'},
>>>>  'default': {'ATOMIC_REQUESTS': False,
>>>>              'AUTOCOMMIT': True,
>>>>              'CONN_MAX_AGE': 0,
>>>>              'NAME': 'geonode',
>>>>              'OPTIONS': {},
>>>>              'PORT': '5432',
>>>>              'TEST_NAME': None,
>>>>              'USER': 'geonode'}}
>>>> GOOGLE_API_KEY
>>>> CELERY_CREATE_MISSING_QUEUES
>>>> True
>>>> CSRF_COOKIE_SECURE
>>>> False
>>>> CELERY_DEFAULT_QUEUE
>>>> 'default'
>>>> UPLOADER
>>>> {'BACKEND': 'geonode.rest',
>>>>  'OPTIONS': {'GEOGIG_ENABLED': False, 'TIME_ENABLED': False}}
>>>> LANGUAGE_CODE
>>>> 'pt-br'
>>>> LICENSES
>>>> {'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
>>>> MANAGERS
>>>> DOWNLOAD_FORMATS_METADATA
>>>> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
>>>> BROKER_URL
>>>> 'django://'
>>>> DEFAULT_CHARSET
>>>> 'utf-8'
>>>> IGNORABLE_404_URLS
>>>> CELERY_DEFAULT_EXCHANGE_TYPE
>>>> 'direct'
>>>> SESSION_SERIALIZER
>>>> 'django.contrib.sessions.serializers.PickleSerializer'
>>>> DEFAULT_MAP_CENTER
>>>> (0, 0)
>>>> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
>>>> 3
>>>> USE_THOUSAND_SEPARATOR
>>>> False
>>>> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
>>>> None
>>>> ACCOUNT_INVITE_USER_URL
>>>> u'account_invite_user'
>>>> REGISTRATION_OPEN
>>>> False
>>>> ALLOWED_HOSTS
>>>> ['muchita.cnpm.embrapa.br', 'localhost']
>>>> EMAIL_HOST
>>>> 'localhost'
>>>> DOWNLOAD_FORMATS_RASTER
>>>> ['JPEG',
>>>>  'PDF',
>>>>  'PNG',
>>>>  'ArcGrid',
>>>>  'GeoTIFF',
>>>>  'Gtopo30',
>>>>  'ImageMosaic',
>>>>  'KML',
>>>>  'View in Google Earth',
>>>>  'Tiles']
>>>> AUTH_EXEMPT_URLS
>>>> WSGI_APPLICATION
>>>> None
>>>> EMAIL_SUBJECT_PREFIX
>>>> '[Django] '
>>>> SEND_BROKEN_LINK_EMAILS
>>>> False
>>>> TEMPLATE_STRING_IF_INVALID
>>>> STATICFILES_FINDERS
>>>> ('django.contrib.staticfiles.finders.FileSystemFinder',
>>>>  'django.contrib.staticfiles.finders.AppDirectoriesFinder')
>>>> NOTIFICATION_QUEUE_ALL
>>>> False
>>>> SESSION_CACHE_ALIAS
>>>> 'default'
>>>> CELERY_IMPORTS
>>>> ('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
>>>> SESSION_COOKIE_DOMAIN
>>>> None
>>>> SESSION_COOKIE_NAME
>>>> 'sessionid'
>>>> ADMIN_FOR
>>>> TIME_INPUT_FORMATS
>>>> ('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
>>>> ACCOUNT_USE_AUTH_AUTHENTICATE
>>>> False
>>>> X_FRAME_OPTIONS
>>>> 'SAMEORIGIN'
>>>> FILE_UPLOAD_PERMISSIONS
>>>> None
>>>> ACCOUNT_TIMEZONES
>>>> [('Africa/Abidjan', 'Africa/Abidjan'),
>>>>  ('Africa/Accra', 'Africa/Accra'),
>>>>  ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>>>>  ('Africa/Algiers', 'Africa/Algiers'),
>>>>  ('Africa/Asmara', 'Africa/Asmara'),
>>>>  ('Africa/Asmera', 'Africa/Asmera'),
>>>>  ('Africa/Bamako', 'Africa/Bamako'),
>>>>  ('Africa/Bangui', 'Africa/Bangui'),
>>>>  ('Africa/Banjul', 'Africa/Banjul'),
>>>>  ('Africa/Bissau', 'Africa/Bissau'),
>>>>  ('Africa/Blantyre', 'Africa/Blantyre'),
>>>>  ('Africa/Brazzaville', 'Africa/Brazzaville'),
>>>>  ('Africa/Bujumbura', 'Africa/Bujumbura'),
>>>>  ('Africa/Cairo', 'Africa/Cairo'),
>>>>  ('Africa/Casablanca', 'Africa/Casablanca'),
>>>>  ('Africa/Ceuta', 'Africa/Ceuta'),
>>>>  ('Africa/Conakry', 'Africa/Conakry'),
>>>>  ('Africa/Dakar', 'Africa/Dakar'),
>>>>  ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>>>>  ('Africa/Djibouti', 'Africa/Djibouti'),
>>>>  ('Africa/Douala', 'Africa/Douala'),
>>>>  ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>>>>  ('Africa/Freetown', 'Africa/Freetown'),
>>>>  ('Africa/Gaborone', 'Africa/Gaborone'),
>>>>  ('Africa/Harare', 'Africa/Harare'),
>>>>  ('Africa/Johannesburg', 'Africa/Johannesburg'),
>>>>  ('Africa/Juba', 'Africa/Juba'),
>>>>  ('Africa/Kampala', 'Africa/Kampala'),
>>>>  ('Africa/Khartoum', 'Africa/Khartoum'),
>>>>  ('Africa/Kigali', 'Africa/Kigali'),
>>>>  ('Africa/Kinshasa', 'Africa/Kinshasa'),
>>>>  ('Africa/Lagos', 'Africa/Lagos'),
>>>>  ('Africa/Libreville', 'Africa/Libreville'),
>>>>  ('Africa/Lome', 'Africa/Lome'),
>>>>  ('Africa/Luanda', 'Africa/Luanda'),
>>>>  ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>>>>  ('Africa/Lusaka', 'Africa/Lusaka'),
>>>>  ('Africa/Malabo', 'Africa/Malabo'),
>>>>  ('Africa/Maputo', 'Africa/Maputo'),
>>>>  ('Africa/Maseru', 'Africa/Maseru'),
>>>>  ('Africa/Mbabane', 'Africa/Mbabane'),
>>>>  ('Africa/Mogadishu', 'Africa/Mogadishu'),
>>>>  ('Africa/Monrovia', 'Africa/Monrovia'),
>>>>  ('Africa/Nairobi', 'Africa/Nairobi'),
>>>>  ('Africa/Ndjamena', 'Africa/Ndjamena'),
>>>>  ('Africa/Niamey', 'Africa/Niamey'),
>>>>  ('Africa/Nouakchott', 'Africa/Nouakchott'),
>>>>  ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>>>>  ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>>>>  ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>>>>  ('Africa/Timbuktu', 'Africa/Timbuktu'),
>>>>  ('Africa/Tripoli', 'Africa/Tripoli'),
>>>>  ('Africa/Tunis', 'Africa/Tunis'),
>>>>  ('Africa/Windhoek', 'Africa/Windhoek'),
>>>>  ('America/Adak', 'America/Adak'),
>>>>  ('America/Anchorage', 'America/Anchorage'),
>>>>  ('America/Anguilla', 'America/Anguilla'),
>>>>  ('America/Antigua', 'America/Antigua'),
>>>>  ('America/Araguaina', 'America/Araguaina'),
>>>>  ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>>>>  ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>>>>  ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>>>>  ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>>>>  ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>>>>  ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>>>>  ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>>>>  ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>>>>  ('America/Argentina/Salta', 'America/Argentina/Salta'),
>>>>  ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>>>>  ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>>>>  ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>>>>  ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>>>>  ('America/Aruba', 'America/Aruba'),
>>>>  ('America/Asuncion', 'America/Asuncion'),
>>>>  ('America/Atikokan', 'America/Atikokan'),
>>>>  ('America/Atka', 'America/Atka'),
>>>>  ('America/Bahia', 'America/Bahia'),
>>>>  ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>>>>  ('America/Barbados', 'America/Barbados'),
>>>>  ('America/Belem', 'America/Belem'),
>>>>  ('America/Belize', 'America/Belize'),
>>>>  ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>>>>  ('America/Boa_Vista', 'America/Boa_Vista'),
>>>>  ('America/Bogota', 'America/Bogota'),
>>>>  ('America/Boise', 'America/Boise'),
>>>>  ('America/Buenos_Aires', 'America/Buenos_Aires'),
>>>>  ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>>>>  ('America/Campo_Grande', 'America/Campo_Grande'),
>>>>  ('America/Cancun', 'America/Cancun'),
>>>>  ('America/Caracas', 'America/Caracas'),
>>>>  ('America/Catamarca', 'America/Catamarca'),
>>>>  ('America/Cayenne', 'America/Cayenne'),
>>>>  ('America/Cayman', 'America/Cayman'),
>>>>  ('America/Chicago', 'America/Chicago'),
>>>>  ('America/Chihuahua', 'America/Chihuahua'),
>>>>  ('America/Coral_Harbour', 'America/Coral_Harbour'),
>>>>  ('America/Cordoba', 'America/Cordoba'),
>>>>  ('America/Costa_Rica', 'America/Costa_Rica'),
>>>>  ('America/Creston', 'America/Creston'),
>>>>  ('America/Cuiaba', 'America/Cuiaba'),
>>>>  ('America/Curacao', 'America/Curacao'),
>>>>  ('America/Danmarkshavn', 'America/Danmarkshavn'),
>>>>  ('America/Dawson', 'America/Dawson'),
>>>>  ('America/Dawson_Creek', 'America/Dawson_Creek'),
>>>>  ('America/Denver', 'America/Denver'),
>>>>  ('America/Detroit', 'America/Detroit'),
>>>>  ('America/Dominica', 'America/Dominica'),
>>>>  ('America/Edmonton', 'America/Edmonton'),
>>>>  ('America/Eirunepe', 'America/Eirunepe'),
>>>>  ('America/El_Salvador', 'America/El_Salvador'),
>>>>  ('America/Ensenada', 'America/Ensenada'),
>>>>  ('America/Fort_Wayne', 'America/Fort_Wayne'),
>>>>  ('America/Fortaleza', 'America/Fortaleza'),
>>>>  ('America/Glace_Bay', 'America/Glace_Bay'),
>>>>  ('America/Godthab', 'America/Godthab'),
>>>>  ('America/Goose_Bay', 'America/Goose_Bay'),
>>>>  ('America/Grand_Turk', 'America/Grand_Turk'),
>>>>  ('America/Grenada', 'America/Grenada'),
>>>>  ('America/Guadeloupe', 'America/Guadeloupe'),
>>>>  ('America/Guatemala', 'America/Guatemala'),
>>>>  ('America/Guayaquil', 'America/Guayaquil'),
>>>>  ('America/Guyana', 'America/Guyana'),
>>>>  ('America/Halifax', 'America/Halifax'),
>>>>  ('America/Havana', 'America/Havana'),
>>>>  ('America/Hermosillo', 'America/Hermosillo'),
>>>>  ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>>>>  ('America/Indiana/Knox', 'America/Indiana/Knox'),
>>>>  ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>>>>  ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>>>>  ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>>>>  ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>>>>  ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>>>>  ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>>>>  ('America/Indianapolis', 'America/Indianapolis'),
>>>>  ('America/Inuvik', 'America/Inuvik'),
>>>>  ('America/Iqaluit', 'America/Iqaluit'),
>>>>  ('America/Jamaica', 'America/Jamaica'),
>>>>  ('America/Jujuy', 'America/Jujuy'),
>>>>  ('America/Juneau', 'America/Juneau'),
>>>>  ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>>>>  ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>>>>  ('America/Knox_IN', 'America/Knox_IN'),
>>>>  ('America/Kralendijk', 'America/Kralendijk'),
>>>>  ('America/La_Paz', 'America/La_Paz'),
>>>>  ('America/Lima', 'America/Lima'),
>>>>  ('America/Los_Angeles', 'America/Los_Angeles'),
>>>>  ('America/Louisville', 'America/Louisville'),
>>>>  ('America/Lower_Princes', 'America/Lower_Princes'),
>>>>  ('America/Maceio', 'America/Maceio'),
>>>>  ('America/Managua', 'America/Managua'),
>>>>  ('America/Manaus', 'America/Manaus'),
>>>>  ('America/Marigot', 'America/Marigot'),
>>>>  ('America/Martinique', 'America/Martinique'),
>>>>  ('America/Matamoros', 'America/Matamoros'),
>>>>  ('America/Mazatlan', 'America/Mazatlan'),
>>>>  ('America/Mendoza', 'America/Mendoza'),
>>>>  ('America/Menominee', 'America/Menominee'),
>>>>  ('America/Merida', 'America/Merida'),
>>>>  ('America/Metlakatla', 'America/Metlakatla'),
>>>>  ('America/Mexico_City', 'America/Mexico_City'),
>>>>  ('America/Miquelon', 'America/Miquelon'),
>>>>  ('America/Moncton', 'America/Moncton'),
>>>>  ('America/Monterrey', 'America/Monterrey'),
>>>>  ('America/Montevideo', 'America/Montevideo'),
>>>>  ('America/Montreal', 'America/Montreal'),
>>>>  ('America/Montserrat', 'America/Montserrat'),
>>>>  ('America/Nassau', 'America/Nassau'),
>>>>  ('America/New_York', 'America/New_York'),
>>>>  ('America/Nipigon', 'America/Nipigon'),
>>>>  ('America/Nome', 'America/Nome'),
>>>>  ('America/Noronha', 'America/Noronha'),
>>>>  ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>>>>  ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>>>>  ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>>>>  ('America/Ojinaga', 'America/Ojinaga'),
>>>>  ('America/Panama', 'America/Panama'),
>>>>  ('America/Pangnirtung', 'America/Pangnirtung'),
>>>>  ('America/Paramaribo', 'America/Paramaribo'),
>>>>  ('America/Phoenix', 'America/Phoenix'),
>>>>  ('America/Port-au-Prince', 'America/Port-au-Prince'),
>>>>  ('America/Port_of_Spain', 'America/Port_of_Spain'),
>>>>  ('America/Porto_Acre', 'America/Porto_Acre'),
>>>>  ('America/Porto_Velho', 'America/Porto_Velho'),
>>>>  ('America/Puerto_Rico', 'America/Puerto_Rico'),
>>>>  ('America/Rainy_River', 'America/Rainy_River'),
>>>>  ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>>>>  ('America/Recife', 'America/Recife'),
>>>>  ('America/Regina', 'America/Regina'),
>>>>  ('America/Resolute', 'America/Resolute'),
>>>>  ('America/Rio_Branco', 'America/Rio_Branco'),
>>>>  ('America/Rosario', 'America/Rosario'),
>>>>  ('America/Santa_Isabel', 'America/Santa_Isabel'),
>>>>  ('America/Santarem', 'America/Santarem'),
>>>>  ('America/Santiago', 'America/Santiago'),
>>>>  ('America/Santo_Domingo', 'America/Santo_Domingo'),
>>>>  ('America/Sao_Paulo', 'America/Sao_Paulo'),
>>>>  ('America/Scoresbysund', 'America/Scoresbysund'),
>>>>  ('America/Shiprock', 'America/Shiprock'),
>>>>  ('America/Sitka', 'America/Sitka'),
>>>>  ('America/St_Barthelemy', 'America/St_Barthelemy'),
>>>>  ('America/St_Johns', 'America/St_Johns'),
>>>>  ('America/St_Kitts', 'America/St_Kitts'),
>>>>  ('America/St_Lucia', 'America/St_Lucia'),
>>>>  ('America/St_Thomas', 'America/St_Thomas'),
>>>>  ('America/St_Vincent', 'America/St_Vincent'),
>>>>  ('America/Swift_Current', 'America/Swift_Current'),
>>>>  ('America/Tegucigalpa', 'America/Tegucigalpa'),
>>>>  ('America/Thule', 'America/Thule'),
>>>>  ('America/Thunder_Bay', 'America/Thunder_Bay'),
>>>>  ('America/Tijuana', 'America/Tijuana'),
>>>>  ('America/Toronto', 'America/Toronto'),
>>>>  ('America/Tortola', 'America/Tortola'),
>>>>  ('America/Vancouver', 'America/Vancouver'),
>>>>  ('America/Virgin', 'America/Virgin'),
>>>>  ('America/Whitehorse', 'America/Whitehorse'),
>>>>  ('America/Winnipeg', 'America/Winnipeg'),
>>>>  ('America/Yakutat', 'America/Yakutat'),
>>>>  ('America/Yellowknife', 'America/Yellowknife'),
>>>>  ('Antarctica/Casey', 'Antarctica/Casey'),
>>>>  ('Antarctica/Davis', 'Antarctica/Davis'),
>>>>  ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>>>>  ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>>>>  ('Antarctica/Mawson', 'Antarctica/Mawson'),
>>>>  ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>>>>  ('Antarctica/Palmer', 'Antarctica/Palmer'),
>>>>  ('Antarctica/Rothera', 'Antarctica/Rothera'),
>>>>  ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>>>>  ('Antarctica/Syowa', 'Antarctica/Syowa'),
>>>>  ('Antarctica/Vostok', 'Antarctica/Vostok'),
>>>>  ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>>>>  ('Asia/Aden', 'Asia/Aden'),
>>>>  ('Asia/Almaty', 'Asia/Almaty'),
>>>>  ('Asia/Amman', 'Asia/Amman'),
>>>>  ('Asia/Anadyr', 'Asia/Anadyr'),
>>>>  ('Asia/Aqtau', 'Asia/Aqtau'),
>>>>  ('Asia/Aqtobe', 'Asia/Aqtobe'),
>>>>  ('Asia/Ashgabat', 'Asia/Ashgabat'),
>>>>  ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>>>>  ('Asia/Baghdad', 'Asia/Baghdad'),
>>>>  ('Asia/Bahrain', 'Asia/Bahrain'),
>>>>  ('Asia/Baku', 'Asia/Baku'),
>>>>  ('Asia/Bangkok', 'Asia/Bangkok'),
>>>>  ('Asia/Beirut', 'Asia/Beirut'),
>>>>  ('Asia/Bishkek', 'Asia/Bishkek'),
>>>>  ('Asia/Brunei', 'Asia/Brunei'),
>>>>  ('Asia/Calcutta', 'Asia/Calcutta'),
>>>>  ('Asia/Choibalsan', 'Asia/Choibalsan'),
>>>>  ('Asia/Chongqing', 'Asia/Chongqing'),
>>>>  ('Asia/Chungking', 'Asia/Chungking'),
>>>>  ('Asia/Colombo', 'Asia/Colombo'),
>>>>  ('Asia/Dacca', 'Asia/Dacca'),
>>>>  ('Asia/Damascus', 'Asia/Damascus'),
>>>>  ('Asia/Dhaka', 'Asia/Dhaka'),
>>>>  ('Asia/Dili', 'Asia/Dili'),
>>>>  ('Asia/Dubai', 'Asia/Dubai'),
>>>>  ('Asia/Dushanbe', 'Asia/Dushanbe'),
>>>>  ('Asia/Gaza', 'Asia/Gaza'),
>>>>  ('Asia/Harbin', 'Asia/Harbin'),
>>>>  ('Asia/Hebron', 'Asia/Hebron'),
>>>>  ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>>>>  ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>>>>  ('Asia/Hovd', 'Asia/Hovd'),
>>>>  ('Asia/Irkutsk', 'Asia/Irkutsk'),
>>>>  ('Asia/Istanbul', 'Asia/Istanbul'),
>>>>  ('Asia/Jakarta', 'Asia/Jakarta'),
>>>>  ('Asia/Jayapura', 'Asia/Jayapura'),
>>>>  ('Asia/Jerusalem', 'Asia/Jerusalem'),
>>>>  ('Asia/Kabul', 'Asia/Kabul'),
>>>>  ('Asia/Kamchatka', 'Asia/Kamchatka'),
>>>>  ('Asia/Karachi', 'Asia/Karachi'),
>>>>  ('Asia/Kashgar', 'Asia/Kashgar'),
>>>>  ('Asia/Kathmandu', 'Asia/Kathmandu'),
>>>>  ('Asia/Katmandu', 'Asia/Katmandu'),
>>>>  ('Asia/Kolkata', 'Asia/Kolkata'),
>>>>  ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>>>>  ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>>>>  ('Asia/Kuching', 'Asia/Kuching'),
>>>>  ('Asia/Kuwait', 'Asia/Kuwait'),
>>>>  ('Asia/Macao', 'Asia/Macao'),
>>>>  ('Asia/Macau', 'Asia/Macau'),
>>>>  ('Asia/Magadan', 'Asia/Magadan'),
>>>>  ('Asia/Makassar', 'Asia/Makassar'),
>>>>  ('Asia/Manila', 'Asia/Manila'),
>>>>  ('Asia/Muscat', 'Asia/Muscat'),
>>>>  ('Asia/Nicosia', 'Asia/Nicosia'),
>>>>  ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>>>>  ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>>>>  ('Asia/Omsk', 'Asia/Omsk'),
>>>>  ('Asia/Oral', 'Asia/Oral'),
>>>>  ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>>>>  ('Asia/Pontianak', 'Asia/Pontianak'),
>>>>  ('Asia/Pyongyang', 'Asia/Pyongyang'),
>>>>  ('Asia/Qatar', 'Asia/Qatar'),
>>>>  ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>>>>  ('Asia/Rangoon', 'Asia/Rangoon'),
>>>>  ('Asia/Riyadh', 'Asia/Riyadh'),
>>>>  ('Asia/Saigon', 'Asia/Saigon'),
>>>>  ('Asia/Sakhalin', 'Asia/Sakhalin'),
>>>>  ('Asia/Samarkand', 'Asia/Samarkand'),
>>>>  ('Asia/Seoul', 'Asia/Seoul'),
>>>>  ('Asia/Shanghai', 'Asia/Shanghai'),
>>>>  ('Asia/Singapore', 'Asia/Singapore'),
>>>>  ('Asia/Taipei', 'Asia/Taipei'),
>>>>  ('Asia/Tashkent', 'Asia/Tashkent'),
>>>>  ('Asia/Tbilisi', 'Asia/Tbilisi'),
>>>>  ('Asia/Tehran', 'Asia/Tehran'),
>>>>  ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>>>>  ('Asia/Thimbu', 'Asia/Thimbu'),
>>>>  ('Asia/Thimphu', 'Asia/Thimphu'),
>>>>  ('Asia/Tokyo', 'Asia/Tokyo'),
>>>>  ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>>>>  ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>>>>  ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>>>>  ('Asia/Urumqi', 'Asia/Urumqi'),
>>>>  ('Asia/Vientiane', 'Asia/Vientiane'),
>>>>  ('Asia/Vladivostok', 'Asia/Vladivostok'),
>>>>  ('Asia/Yakutsk', 'Asia/Yakutsk'),
>>>>  ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>>>>  ('Asia/Yerevan', 'Asia/Yerevan'),
>>>>  ('Atlantic/Azores', 'Atlantic/Azores'),
>>>>  ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>>>>  ('Atlantic/Canary', 'Atlantic/Canary'),
>>>>  ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>>>>  ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>>>>  ('Atlantic/Faroe', 'Atlantic/Faroe'),
>>>>  ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>>>>  ('Atlantic/Madeira', 'Atlantic/Madeira'),
>>>>  ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>>>>  ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>>>>  ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>>>>  ('Atlantic/Stanley', 'Atlantic/Stanley'),
>>>>  ('Australia/ACT', 'Australia/ACT'),
>>>>  ('Australia/Adelaide', 'Australia/Adelaide'),
>>>>  ('Australia/Brisbane', 'Australia/Brisbane'),
>>>>  ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>>>>  ('Australia/Canberra', 'Australia/Canberra'),
>>>>  ('Australia/Currie', 'Australia/Currie'),
>>>>  ('Australia/Darwin', 'Australia/Darwin'),
>>>>  ('Australia/Eucla', 'Australia/Eucla'),
>>>>  ('Australia/Hobart', 'Australia/Hobart'),
>>>>  ('Australia/LHI', 'Australia/LHI'),
>>>>  ('Australia/Lindeman', 'Australia/Lindeman'),
>>>>  ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>>>>  ('Australia/Melbourne', 'Australia/Melbourne'),
>>>>  ('Australia/NSW', 'Australia/NSW'),
>>>>  ('Australia/North', 'Australia/North'),
>>>>  ('Australia/Perth', 'Australia/Perth'),
>>>>  ('Australia/Queensland', 'Australia/Queensland'),
>>>>  ('Australia/South', 'Australia/South'),
>>>>  ('Australia/Sydney', 'Australia/Sydney'),
>>>>  ('Australia/Tasmania', 'Australia/Tasmania'),
>>>>  ('Australia/Victoria', 'Australia/Victoria'),
>>>>  ('Australia/West', 'Australia/West'),
>>>>  ('Australia/Yancowinna', 'Australia/Yancowinna'),
>>>>  ('Brazil/Acre', 'Brazil/Acre'),
>>>>  ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>>>>  ('Brazil/East', 'Brazil/East'),
>>>>  ('Brazil/West', 'Brazil/West'),
>>>>  ('CET', 'CET'),
>>>>  ('CST6CDT', 'CST6CDT'),
>>>>  ('Canada/Atlantic', 'Canada/Atlantic'),
>>>>  ('Canada/Central', 'Canada/Central'),
>>>>  ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>>>>  ('Canada/Eastern', 'Canada/Eastern'),
>>>>  ('Canada/Mountain', 'Canada/Mountain'),
>>>>  ('Canada/Newfoundland', 'Canada/Newfoundland'),
>>>>  ('Canada/Pacific', 'Canada/Pacific'),
>>>>  ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>>>>  ('Canada/Yukon', 'Canada/Yukon'),
>>>>  ('Chile/Continental', 'Chile/Continental'),
>>>>  ('Chile/EasterIsland', 'Chile/EasterIsland'),
>>>>  ('Cuba', 'Cuba'),
>>>>  ('EET', 'EET'),
>>>>  ('EST', 'EST'),
>>>>  ('EST5EDT', 'EST5EDT'),
>>>>  ('Egypt', 'Egypt'),
>>>>  ('Eire', 'Eire'),
>>>>  ('Etc/GMT', 'Etc/GMT'),
>>>>  ('Etc/GMT+0', 'Etc/GMT+0'),
>>>>  ('Etc/GMT+1', 'Etc/GMT+1'),
>>>>  ('Etc/GMT+10', 'Etc/GMT+10'),
>>>>  ('Etc/GMT+11', 'Etc/GMT+11'),
>>>>  ('Etc/GMT+12', 'Etc/GMT+12'),
>>>>  ('Etc/GMT+2', 'Etc/GMT+2'),
>>>>  ('Etc/GMT+3', 'Etc/GMT+3'),
>>>>  ('Etc/GMT+4', 'Etc/GMT+4'),
>>>>  ('Etc/GMT+5', 'Etc/GMT+5'),
>>>>  ('Etc/GMT+6', 'Etc/GMT+6'),
>>>>  ('Etc/GMT+7', 'Etc/GMT+7'),
>>>>  ('Etc/GMT+8', 'Etc/GMT+8'),
>>>>  ('Etc/GMT+9', 'Etc/GMT+9'),
>>>>  ('Etc/GMT-0', 'Etc/GMT-0'),
>>>>  ('Etc/GMT-1', 'Etc/GMT-1'),
>>>>  ('Etc/GMT-10', 'Etc/GMT-10'),
>>>>  ('Etc/GMT-11', 'Etc/GMT-11'),
>>>>  ('Etc/GMT-12', 'Etc/GMT-12'),
>>>>  ('Etc/GMT-13', 'Etc/GMT-13'),
>>>>  ('Etc/GMT-14', 'Etc/GMT-14'),
>>>>  ('Etc/GMT-2', 'Etc/GMT-2'),
>>>>  ('Etc/GMT-3', 'Etc/GMT-3'),
>>>>  ('Etc/GMT-4', 'Etc/GMT-4'),
>>>>  ('Etc/GMT-5', 'Etc/GMT-5'),
>>>>  ('Etc/GMT-6', 'Etc/GMT-6'),
>>>>  ('Etc/GMT-7', 'Etc/GMT-7'),
>>>>  ('Etc/GMT-8', 'Etc/GMT-8'),
>>>>  ('Etc/GMT-9', 'Etc/GMT-9'),
>>>>  ('Etc/GMT0', 'Etc/GMT0'),
>>>>  ('Etc/Greenwich', 'Etc/Greenwich'),
>>>>  ('Etc/UCT', 'Etc/UCT'),
>>>>  ('Etc/UTC', 'Etc/UTC'),
>>>>  ('Etc/Universal', 'Etc/Universal'),
>>>>  ('Etc/Zulu', 'Etc/Zulu'),
>>>>  ('Europe/Amsterdam', 'Europe/Amsterdam'),
>>>>  ('Europe/Andorra', 'Europe/Andorra'),
>>>>  ('Europe/Athens', 'Europe/Athens'),
>>>>  ('Europe/Belfast', 'Europe/Belfast'),
>>>>  ('Europe/Belgrade', 'Europe/Belgrade'),
>>>>  ('Europe/Berlin', 'Europe/Berlin'),
>>>>  ('Europe/Bratislava', 'Europe/Bratislava'),
>>>>  ('Europe/Brussels', 'Europe/Brussels'),
>>>>  ('Europe/Bucharest', 'Europe/Bucharest'),
>>>>  ('Europe/Budapest', 'Europe/Budapest'),
>>>>  ('Europe/Chisinau', 'Europe/Chisinau'),
>>>>  ('Europe/Copenhagen', 'Europe/Copenhagen'),
>>>>  ('Europe/Dublin', 'Europe/Dublin'),
>>>>  ('Europe/Gibraltar', 'Europe/Gibraltar'),
>>>>  ('Europe/Guernsey', 'Europe/Guernsey'),
>>>>  ('Europe/Helsinki', 'Europe/Helsinki'),
>>>>  ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>>>>  ('Europe/Istanbul', 'Europe/Istanbul'),
>>>>  ('Europe/Jersey', 'Europe/Jersey'),
>>>>  ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>>>>  ('Europe/Kiev', 'Europe/Kiev'),
>>>>  ('Europe/Lisbon', 'Europe/Lisbon'),
>>>>  ('Europe/Ljubljana', 'Europe/Ljubljana'),
>>>>  ('Europe/London', 'Europe/London'),
>>>>  ('Europe/Luxembourg', 'Europe/Luxembourg'),
>>>>  ('Europe/Madrid', 'Europe/Madrid'),
>>>>  ('Europe/Malta', 'Europe/Malta'),
>>>>  ('Europe/Mariehamn', 'Europe/Mariehamn'),
>>>>  ('Europe/Minsk', 'Europe/Minsk'),
>>>>  ('Europe/Monaco', 'Europe/Monaco'),
>>>>  ('Europe/Moscow', 'Europe/Moscow'),
>>>>  ('Europe/Nicosia', 'Europe/Nicosia'),
>>>>  ('Europe/Oslo', 'Europe/Oslo'),
>>>>  ('Europe/Paris', 'Europe/Paris'),
>>>>  ('Europe/Podgorica', 'Europe/Podgorica'),
>>>>  ('Europe/Prague', 'Europe/Prague'),
>>>>  ('Europe/Riga', 'Europe/Riga'),
>>>>  ('Europe/Rome', 'Europe/Rome'),
>>>>  ('Europe/Samara', 'Europe/Samara'),
>>>>  ('Europe/San_Marino', 'Europe/San_Marino'),
>>>>  ('Europe/Sarajevo', 'Europe/Sarajevo'),
>>>>  ('Europe/Simferopol', 'Europe/Simferopol'),
>>>>  ('Europe/Skopje', 'Europe/Skopje'),
>>>>  ('Europe/Sofia', 'Europe/Sofia'),
>>>>  ('Europe/Stockholm', 'Europe/Stockholm'),
>>>>  ('Europe/Tallinn', 'Europe/Tallinn'),
>>>>  ('Europe/Tirane', 'Europe/Tirane'),
>>>>  ('Europe/Tiraspol', 'Europe/Tiraspol'),
>>>>  ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>>>>  ('Europe/Vaduz', 'Europe/Vaduz'),
>>>>  ('Europe/Vatican', 'Europe/Vatican'),
>>>>  ('Europe/Vienna', 'Europe/Vienna'),
>>>>  ('Europe/Vilnius', 'Europe/Vilnius'),
>>>>  ('Europe/Volgograd', 'Europe/Volgograd'),
>>>>  ('Europe/Warsaw', 'Europe/Warsaw'),
>>>>  ('Europe/Zagreb', 'Europe/Zagreb'),
>>>>  ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>>>>  ('Europe/Zurich', 'Europe/Zurich'),
>>>>  ('GB', 'GB'),
>>>>  ('GB-Eire', 'GB-Eire'),
>>>>  ('GMT', 'GMT'),
>>>>  ('GMT+0', 'GMT+0'),
>>>>  ('GMT-0', 'GMT-0'),
>>>>  ('GMT0', 'GMT0'),
>>>>  ('Greenwich', 'Greenwich'),
>>>>  ('HST', 'HST'),
>>>>  ('Hongkong', 'Hongkong'),
>>>>  ('Iceland', 'Iceland'),
>>>>  ('Indian/Antananarivo', 'Indian/Antananarivo'),
>>>>  ('Indian/Chagos', 'Indian/Chagos'),
>>>>  ('Indian/Christmas', 'Indian/Christmas'),
>>>>  ('Indian/Cocos', 'Indian/Cocos'),
>>>>  ('Indian/Comoro', 'Indian/Comoro'),
>>>>  ('Indian/Kerguelen', 'Indian/Kerguelen'),
>>>>  ('Indian/Mahe', 'Indian/Mahe'),
>>>>  ('Indian/Maldives', 'Indian/Maldives'),
>>>>  ('Indian/Mauritius', 'Indian/Mauritius'),
>>>>  ('Indian/Mayotte', 'Indian/Mayotte'),
>>>>  ('Indian/Reunion', 'Indian/Reunion'),
>>>>  ('Iran', 'Iran'),
>>>>  ('Israel', 'Israel'),
>>>>  ('Jamaica', 'Jamaica'),
>>>>  ('Japan', 'Japan'),
>>>>  ('Kwajalein', 'Kwajalein'),
>>>>  ('Libya', 'Libya'),
>>>>  ('MET', 'MET'),
>>>>  ('MST', 'MST'),
>>>>  ('MST7MDT', 'MST7MDT'),
>>>>  ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>>>>  ('Mexico/BajaSur', 'Mexico/BajaSur'),
>>>>  ('Mexico/General', 'Mexico/General'),
>>>>  ('NZ', 'NZ'),
>>>>  ('NZ-CHAT', 'NZ-CHAT'),
>>>>  ('Navajo', 'Navajo'),
>>>>  ('PRC', 'PRC'),
>>>>  ('PST8PDT', 'PST8PDT'),
>>>>  ('Pacific/Apia', 'Pacific/Apia'),
>>>>  ('Pacific/Auckland', 'Pacific/Auckland'),
>>>>  ('Pacific/Chatham', 'Pacific/Chatham'),
>>>>  ('Pacific/Chuuk', 'Pacific/Chuuk'),
>>>>  ('Pacific/Easter', 'Pacific/Easter'),
>>>>  ('Pacific/Efate', 'Pacific/Efate'),
>>>>  ('Pacific/Enderbury', 'Pacific/Enderbury'),
>>>>  ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>>>>  ('Pacific/Fiji', 'Pacific/Fiji'),
>>>>  ('Pacific/Funafuti', 'Pacific/Funafuti'),
>>>>  ('Pacific/Galapagos', 'Pacific/Galapagos'),
>>>>  ('Pacific/Gambier', 'Pacific/Gambier'),
>>>>  ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>>>>  ('Pacific/Guam', 'Pacific/Guam'),
>>>>  ('Pacific/Honolulu', 'Pacific/Honolulu'),
>>>>  ('Pacific/Johnston', 'Pacific/Johnston'),
>>>>  ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>>>>  ('Pacific/Kosrae', 'Pacific/Kosrae'),
>>>>  ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>>>>  ('Pacific/Majuro', 'Pacific/Majuro'),
>>>>  ('Pacific/Marquesas', 'Pacific/Marquesas'),
>>>>  ('Pacific/Midway', 'Pacific/Midway'),
>>>>  ('Pacific/Nauru', 'Pacific/Nauru'),
>>>>  ('Pacific/Niue', 'Pacific/Niue'),
>>>>  ('Pacific/Norfolk', 'Pacific/Norfolk'),
>>>>  ('Pacific/Noumea', 'Pacific/Noumea'),
>>>>  ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>>>>  ('Pacific/Palau', 'Pacific/Palau'),
>>>>  ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>>>>  ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>>>>  ('Pacific/Ponape', 'Pacific/Ponape'),
>>>>  ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>>>>  ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>>>>  ('Pacific/Saipan', 'Pacific/Saipan'),
>>>>  ('Pacific/Samoa', 'Pacific/Samoa'),
>>>>  ('Pacific/Tahiti', 'Pacific/Tahiti'),
>>>>  ('Pacific/Tarawa', 'Pacific/Tarawa'),
>>>>  ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>>>>  ('Pacific/Truk', 'Pacific/Truk'),
>>>>  ('Pacific/Wake', 'Pacific/Wake'),
>>>>  ('Pacific/Wallis', 'Pacific/Wallis'),
>>>>  ('Pacific/Yap', 'Pacific/Yap'),
>>>>  ('Poland', 'Poland'),
>>>>  ('Portugal', 'Portugal'),
>>>>  ('ROC', 'ROC'),
>>>>  ('ROK', 'ROK'),
>>>>  ('Singapore', 'Singapore'),
>>>>  ('Turkey', 'Turkey'),
>>>>  ('UCT', 'UCT'),
>>>>  ('US/Alaska', 'US/Alaska'),
>>>>  ('US/Aleutian', 'US/Aleutian'),
>>>>  ('US/Arizona', 'US/Arizona'),
>>>>  ('US/Central', 'US/Central'),
>>>>  ('US/East-Indiana', 'US/East-Indiana'),
>>>>  ('US/Eastern', 'US/Eastern'),
>>>>  ('US/Hawaii', 'US/Hawaii'),
>>>>  ('US/Indiana-Starke', 'US/Indiana-Starke'),
>>>>  ('US/Michigan', 'US/Michigan'),
>>>>  ('US/Mountain', 'US/Mountain'),
>>>>  ('US/Pacific', 'US/Pacific'),
>>>>  ('US/Pacific-New', 'US/Pacific-New'),
>>>>  ('US/Samoa', 'US/Samoa'),
>>>>  ('UTC', 'UTC'),
>>>>  ('Universal', 'Universal'),
>>>>  ('W-SU', 'W-SU'),
>>>>  ('WET', 'WET'),
>>>>  ('Zulu', 'Zulu')]
>>>> FILE_UPLOAD_HANDLERS
>>>> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>>>>  'django.core.files.uploadhandler.TemporaryFileUploadHandler')
>>>> DEFAULT_CONTENT_TYPE
>>>> 'text/html'
>>>> DEBUG_STATIC
>>>> False
>>>> ACCOUNT_APPROVAL_REQUIRED
>>>> False
>>>> APPEND_SLASH
>>>> True
>>>> FIRST_DAY_OF_WEEK
>>>> 0
>>>> DATABASE_ROUTERS
>>>> DEFAULT_TABLESPACE
>>>> YEAR_MONTH_FORMAT
>>>> 'F Y'
>>>> STATICFILES_STORAGE
>>>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>>>> CACHES
>>>> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
>>>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
>>>> True
>>>> CKAN_ORIGINS
>>>> [{'css_class': 'hdx',
>>>>   'label': 'Humanitarian Data Exchange (HDX)',
>>>>   'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
>>>> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
>>>> False
>>>> SERVER_EMAIL
>>>> 'root at localhost'
>>>> SESSION_COOKIE_PATH
>>>> USE_X_FORWARDED_HOST
>>>> False
>>>> ACCOUNT_OPEN_SIGNUP
>>>> True
>>>> ROOT_URLCONF
>>>> 'geonode.urls'
>>>> CATALOGUE
>>>> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>>>>              'URL': 'http://muchita.cnpm.embrapa.br/catalogue/csw'}}
>>>> MISSING_THUMBNAIL
>>>> 'geonode/img/missing_thumb.png'
>>>> FILE_UPLOAD_TEMP_DIR
>>>> None
>>>> MIDDLEWARE_CLASSES
>>>> ('django.middleware.common.CommonMiddleware',
>>>>  'django.contrib.sessions.middleware.SessionMiddleware',
>>>>  'django.contrib.messages.middleware.MessageMiddleware',
>>>>  'django.middleware.locale.LocaleMiddleware',
>>>>  'pagination.middleware.PaginationMiddleware',
>>>>  'django.middleware.csrf.CsrfViewMiddleware',
>>>>  'django.contrib.auth.middleware.AuthenticationMiddleware',
>>>>  'django.middleware.clickjacking.XFrameOptionsMiddleware')
>>>> USE_I18N
>>>> True
>>>> THOUSAND_SEPARATOR
>>>> SECRET_KEY
>>>> MODELTRANSLATION_FALLBACK_LANGUAGES
>>>> ('en',)
>>>> LANGUAGE_COOKIE_NAME
>>>> 'django_language'
>>>> ACCOUNT_REMEMBER_ME_EXPIRY
>>>> 315360000
>>>> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
>>>> ACCOUNT_EMAIL_UNIQUE
>>>> True
>>>> TRANSACTIONS_MANAGED
>>>> False
>>>> LOGGING_CONFIG
>>>> 'django.utils.log.dictConfig'
>>>> TEMPLATE_LOADERS
>>>> ('django.template.loaders.filesystem.Loader',
>>>>  'django.template.loaders.app_directories.Loader')
>>>> FORCE_SCRIPT_NAME
>>>> None
>>>> TASTYPIE_DEFAULT_FORMATS
>>>> ['json']
>>>> TEMPLATE_DEBUG
>>>> True
>>>> AUTO_GENERATE_AVATAR_SIZES
>>>> (20, 32, 80, 100, 140, 200)
>>>> CSRF_COOKIE_NAME
>>>> 'csrftoken'
>>>> 'default'
>>>> CELERY_DEFAULT_ROUTING_KEY
>>>> ACCOUNT_LOGIN_REDIRECT_URL
>>>> u'/'
>>>> CELERY_ALWAYS_EAGER
>>>> True
>>>> MODIFY_TOPICCATEGORY
>>>> False
>>>> SIGNING_BACKEND
>>>> 'django.core.signing.TimestampSigner'
>>>> SESSION_COOKIE_SECURE
>>>> False
>>>> ACCOUNT_LOGIN_URL
>>>> u'account_login'
>>>> CACHE_TIME
>>>> 0
>>>> PYCSW
>>>> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>>>>                                         'contact_email': 'Email Address',
>>>>                                         'contact_name': 'Organization Name',
>>>>                                         'date': 'YYYY-MM-DD',
>>>>                                         'default_language': 'eng',
>>>>                                         'enabled': 'true',
>>>>                                         'gemet_keywords': 'Utility and governmental services',
>>>>                                         'languages_supported': 'eng,gre',
>>>>                                         'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>>>>                    'metadata:main': {'contact_address': 'Mailing Address',
>>>>                                      'contact_city': 'City',
>>>>                                      'contact_country': 'Country',
>>>>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>>>>                                      'contact_hours': 'Hours of Service',
>>>>                                      'contact_instructions': 'During hours of service. Off on weekends.',
>>>>                                      'contact_name': 'Lastname, Firstname',
>>>>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>>>>                                      'contact_position': 'Position Title',
>>>>                                      'contact_postalcode': 'Zip or Postal Code',
>>>>                                      'contact_role': 'pointOfContact',
>>>>                                      'contact_stateorprovince': 'Administrative Area',
>>>>                                      'contact_url': 'Contact URL',
>>>>                                      'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing,              and collaborative use of geospatial data',
>>>>                                      'identification_accessconstraints': 'None',
>>>>                                      'identification_fees': 'None',
>>>>                                      'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>>>>                                      'identification_keywords_type': 'theme',
>>>>                                      'identification_title': 'GeoNode Catalogue',
>>>>                                      'provider_name': 'Organization Name',
>>>>                                      'provider_url': 'http://localhost:8000/'}}}
>>>> CSRF_COOKIE_DOMAIN
>>>> None
>>>> FILE_CHARSET
>>>> 'utf-8'
>>>> DEBUG
>>>> True
>>>> SESSION_FILE_PATH
>>>> None
>>>> DEFAULT_FILE_STORAGE
>>>> 'django.core.files.storage.FileSystemStorage'
>>>> INSTALLED_APPS
>>>> ('django.contrib.auth',
>>>>  'django.contrib.contenttypes',
>>>>  'django.contrib.sessions',
>>>>  'django.contrib.sites',
>>>>  'django.contrib.admin',
>>>>  'django.contrib.sitemaps',
>>>>  'django.contrib.staticfiles',
>>>>  'django.contrib.messages',
>>>>  'django.contrib.humanize',
>>>>  'django.contrib.gis',
>>>>  'pagination',
>>>>  'taggit',
>>>>  'friendlytagloader',
>>>>  'geoexplorer',
>>>>  'leaflet',
>>>>  'django_extensions',
>>>>  'autocomplete_light',
>>>>  'mptt',
>>>>  'modeltranslation',
>>>>  'djcelery',
>>>>  'pinax_theme_bootstrap_account',
>>>>  'pinax_theme_bootstrap',
>>>>  'django_forms_bootstrap',
>>>>  'account',
>>>>  'avatar',
>>>>  'dialogos',
>>>>  'agon_ratings',
>>>>  'announcements',
>>>>  'actstream',
>>>>  'user_messages',
>>>>  'tastypie',
>>>>  'polymorphic',
>>>>  'guardian',
>>>>  'geonode.people',
>>>>  'geonode.base',
>>>>  'geonode.layers',
>>>>  'geonode.maps',
>>>>  'geonode.proxy',
>>>>  'geonode.security',
>>>>  'geonode.social',
>>>>  'geonode.catalogue',
>>>>  'geonode.documents',
>>>>  'geonode.api',
>>>>  'geonode.groups',
>>>>  'geonode.services',
>>>>  'geonode.geoserver',
>>>>  'geonode.upload',
>>>>  'geonode.tasks')
>>>> LANGUAGES_BIDI
>>>> ('he', 'ar', 'fa', 'ur')
>>>> USE_L10N
>>>> False
>>>> DATABASE_ENGINE
>>>> STATIC_ROOT
>>>> '/var/www/geonode/static/'
>>>> STATICFILES_DIRS
>>>> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
>>>> DATABASE_NAME
>>>> 'geonode'
>>>> LEAFLET_CONFIG
>>>> {'PLUGINS': {u'ALL': {u'css': [u'/static/leaflet/draw/leaflet.draw.css',
>>>>                                '/static/lib/css/leaflet.fullscreen.css'],
>>>>                       u'js': [u'/static/leaflet/draw/leaflet.draw.js',
>>>>                               u'/static/leaflet/leaflet.extras.js',
>>>>                               u'/static/leaflet/leaflet.forms.js',
>>>>                               '/static/lib/js/Leaflet.fullscreen.min.js',
>>>>                               '/static/lib/js/esri-leaflet.js']},
>>>>              u'__default__': {u'css': ['/static/lib/css/leaflet.fullscreen.css'],
>>>>                               u'js': ['/static/lib/js/Leaflet.fullscreen.min.js',
>>>>              u'__is_normalized__': True,
>>>>              'esri-leaflet': {'auto-include': True,
>>>>                               u'css': [],
>>>>                               'js': ['/static/lib/js/esri-leaflet.js']},
>>>>              u'forms': {u'auto-include': False,
>>>>                         u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
>>>>                                 u'/static/leaflet/leaflet.forms.js']},
>>>>              'leaflet-fullscreen': {'auto-include': True,
>>>>                                     'js': ['/static/lib/js/Leaflet.fullscreen.min.js']}},
>>>>  'TILES': [('Watercolor',
>>>>             'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
>>>>            ('Toner Lite',
>>>>             'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>')]}
>>>> DOWNLOAD_FORMATS_VECTOR
>>>> ['JPEG',
>>>>  'PDF',
>>>>  'PNG',
>>>>  'Zipped Shapefile',
>>>>  'GML 2.0',
>>>>  'GML 3.1.1',
>>>>  'CSV',
>>>>  'Excel',
>>>>  'GeoJSON',
>>>>  'KML',
>>>>  'Tiles']
>>>> PREPEND_WWW
>>>> False
>>>> SECURE_PROXY_SSL_HEADER
>>>> None
>>>> SOCIAL_ORIGINS
>>>> [{'css_class': 'email',
>>>>   'label': 'Email',
>>>>   'url': 'mailto:?subject={name}&body={url}'},
>>>>  {'css_class': 'fb',
>>>>   'label': 'Facebook',
>>>>   'url': 'http://www.facebook.com/sharer.php?u={url}'},
>>>>  {'css_class': 'tw',
>>>>   'label': 'Twitter',
>>>>   'url': 'https://twitter.com/share?url={url}'},
>>>>  {'css_class': 'gp',
>>>>   'label': 'Google +',
>>>>   'url': 'https://plus.google.com/share?url={url}'}]
>>>> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
>>>> SESSION_COOKIE_HTTPONLY
>>>> True
>>>> DATABASE_PORT
>>>> '5432'
>>>> DEBUG_PROPAGATE_EXCEPTIONS
>>>> False
>>>> DEFAULT_ANONYMOUS_VIEW_PERMISSION
>>>> True
>>>> MEDIA_URL
>>>> '/uploaded/'
>>>> MONTH_DAY_FORMAT
>>>> 'F j'
>>>> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
>>>> u'account_login'
>>>> LOGIN_URL
>>>> '/account/login/'
>>>> SESSION_EXPIRE_AT_BROWSER_CLOSE
>>>> False
>>>> OGP_URL
>>>> 'http://geodata.tufts.edu/solr/select'
>>>> CELERY_EAGER_PROPAGATES_EXCEPTIONS
>>>> True
>>>> TIME_FORMAT
>>>> 'P'
>>>> CELERY_IGNORE_RESULT
>>>> True
>>>> SERVICE_UPDATE_INTERVAL
>>>> 0
>>>> AUTH_USER_MODEL
>>>> 'people.Profile'
>>>> DATE_INPUT_FORMATS
>>>> ('%Y-%m-%d',
>>>>  '%m/%d/%Y',
>>>>  '%m/%d/%y',
>>>>  '%b %d %Y',
>>>>  '%b %d, %Y',
>>>>  '%d %b %Y',
>>>>  '%d %b, %Y',
>>>>  '%B %d %Y',
>>>>  '%B %d, %Y',
>>>>  '%d %B %Y',
>>>>  '%d %B, %Y')
>>>> ACCOUNT_LOGOUT_REDIRECT_URL
>>>> u'/'
>>>> HAYSTACK_SEARCH
>>>> False
>>>> AUTHENTICATION_BACKENDS
>>>> ('django.contrib.auth.backends.ModelBackend',
>>>>  'guardian.backends.ObjectPermissionBackend')
>>>> EMAIL_HOST_PASSWORD
>>>> CELERY_DISABLE_RATE_LIMITS
>>>> True
>>>> PASSWORD_RESET_TIMEOUT_DAYS
>>>> CACHE_MIDDLEWARE_ALIAS
>>>> 'default'
>>>> SESSION_SAVE_EVERY_REQUEST
>>>> False
>>>> NUMBER_GROUPING
>>>> 0
>>>> SHORT_DATETIME_FORMAT
>>>> 'm/d/Y P'
>>>> SESSION_ENGINE
>>>> 'django.contrib.sessions.backends.db'
>>>> CELERY_RESULT_BACKEND
>>>> None
>>>> ACCOUNT_DELETION_MARK_CALLBACK
>>>> CSRF_COOKIE_PATH
>>>> LOGIN_REDIRECT_URL
>>>> '/accounts/profile/'
>>>> SITEURL
>>>> 'http://muchita.cnpm.embrapa.br/'
>>>> PROJECT_ROOT
>>>> '/usr/local/lib/python2.7/dist-packages/geonode'
>>>> ACCOUNT_DELETION_EXPUNGE_HOURS
>>>> 48
>>>> GEONODE_ROOT
>>>> DECIMAL_SEPARATOR
>>>> CSRF_FAILURE_VIEW
>>>> 'django.views.csrf.csrf_failure'
>>>> CELERY_SEND_EVENTS
>>>> False
>>>> NOSE_ARGS
>>>> ['--nocapture', '--detailed-errors']
>>>> LOCALE_PATHS
>>>> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
>>>> THEME_ACCOUNT_CONTACT_EMAIL
>>>> 'admin at example.com'
>>>> PASSWORD_HASHERS
>>>> PROXY_ALLOWED_HOSTS
>>>> MESSAGE_STORAGE
>>>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>>>> USE_QUEUE
>>>> False
>>>> COMMENTS_ALLOW_PROFANITIES
>>>> False
>>>> LOGOUT_URL
>>>> '/account/logout/'
>>>> MAP_BASELAYERS
>>>> [{'source': {'ptype': 'gxp_wmscsource',
>>>>              'restUrl': '/gs/rest',
>>>>              'url': 'http://muchita.cnpm.embrapa.br/geoserver/wms'}},
>>>>  {'args': ['No background'],
>>>>   'fixed': True,
>>>>   'group': 'background',
>>>>   'source': {'ptype': 'gxp_olsource'},
>>>>   'type': 'OpenLayers.Layer',
>>>>   'visibility': False},
>>>>  {'args': ['OpenStreetMap'],
>>>>   'fixed': True,
>>>>   'type': 'OpenLayers.Layer.OSM',
>>>>  {'group': 'background',
>>>>   'name': 'osm',
>>>>   'source': {'ptype': 'gxp_mapquestsource'},
>>>>   'visibility': True},
>>>>   'name': 'naip',
>>>>  {'fixed': True,
>>>>   'name': 'AerialWithLabels',
>>>>   'source': {'ptype': 'gxp_bingsource'},
>>>>  {'source': {'ptype': 'gxp_mapboxsource'}}]
>>>> EMAIL_USE_TLS
>>>> False
>>>> ACCOUNT_LANGUAGES
>>>> [('en', u'English'),
>>>>  ('es', u'espa\xf1ol'),
>>>>  ('it', u'italiano'),
>>>>  ('fr', u'fran\xe7ais'),
>>>>  ('de', u'Deutsch'),
>>>>  ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>>>>  ('id', u'Bahasa Indonesia'),
>>>>  ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
>>>>  ('ja', u'\u65e5\u672c\u8a9e'),
>>>>  ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
>>>>  ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
>>>>  ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
>>>>  ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
>>>>  ('sq', u'shqip'),
>>>>  ('af', u'Afrikaans'),
>>>>  ('sw', u'Kiswahili'),
>>>>  ('pt', u'Portugu\xeas'),
>>>>  ('pt-br', u'Portugu\xeas Brasileiro'),
>>>>  ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
>>>>  ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
>>>>  ('ko', u'\ud55c\uad6d\uc5b4'),
>>>>  ('am', 'Amharic'),
>>>>  ('km', u'Khmer'),
>>>>  ('pl', u'polski'),
>>>>  ('sv', u'svenska'),
>>>>  ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
>>>>  ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
>>>>  ('si', 'sinhala'),
>>>>  ('ta', u'tamil'),
>>>>  ('tl', 'tagalog')]
>>>> FIXTURE_DIRS
>>>> ABSOLUTE_URL_OVERRIDES
>>>> DATE_FORMAT
>>>> 'N j, Y'
>>>> OGC_SERVER
>>>> {'default': {'BACKEND': 'geonode.geoserver',
>>>>              'BACKEND_WRITE_ENABLED': True,
>>>>              'DATASTORE': 'datastore',
>>>>              'GEOGIG_DATASTORE_DIR': '',
>>>>              'GEONODE_SECURITY_ENABLED': True,
>>>>              'LOCATION': 'http://localhost:8080/geoserver/',
>>>>              'LOG_FILE': '/usr/share/geoserver/data/logs/geoserver.log',
>>>>              'MAPFISH_PRINT_ENABLED': True,
>>>>              'PRINT_NG_ENABLED': True,
>>>>              'PUBLIC_LOCATION': 'http://muchita.cnpm.embrapa.br/geoserver/',
>>>>              'USER': 'admin',
>>>>              'WMST_ENABLED': False,
>>>>              'WPS_ENABLED': True}}
>>>> SKIP_PERMS_FILTER
>>>> False
>>>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
>>>> MEDIA_ROOT
>>>> '/var/www/geonode/uploaded'
>>>> AGON_RATINGS_CATEGORY_CHOICES
>>>> {'documents.Document': {'document': 'How good is this document?'},
>>>>  'layers.Layer': {'layer': 'How good is this layer?'},
>>>>  'maps.Map': {'map': 'How good is this map?'}}
>>>> DATABASE_HOST
>>>> DEFAULT_EXCEPTION_REPORTER_FILTER
>>>> 'django.views.debug.SafeExceptionReporterFilter'
>>>> ADMINS
>>>> FORMAT_MODULE_PATH
>>>> None
>>>> DEFAULT_FROM_EMAIL
>>>> GEONODE_APPS
>>>> ('geonode.people',
>>>>  'geonode.base',
>>>>  'geonode.layers',
>>>>  'geonode.maps',
>>>>  'geonode.proxy',
>>>>  'geonode.security',
>>>>  'geonode.social',
>>>>  'geonode.api',
>>>>  'geonode.groups',
>>>>  'geonode.services',
>>>>  'geonode.upload',
>>>>  'geonode.tasks')
>>>> GEOSERVER_URL
>>>> DATETIME_FORMAT
>>>> 'N j, Y, P'
>>>> TEMPLATE_DIRS
>>>> ('/etc/geonode/templates',
>>>>  '/usr/local/lib/python2.7/dist-packages/geonode/templates')
>>>> ALLOWED_DOCUMENT_TYPES
>>>> ['doc',
>>>>  'docx',
>>>>  'gif',
>>>>  'jpg',
>>>>  'jpeg',
>>>>  'ods',
>>>>  'odt',
>>>>  'odp',
>>>>  'pdf',
>>>>  'png',
>>>>  'ppt',
>>>>  'pptx',
>>>>  'rar',
>>>>  'tif',
>>>>  'tiff',
>>>>  'txt',
>>>>  'xls',
>>>>  'xlsx',
>>>>  'xml',
>>>>  'zip',
>>>>  'gz']
>>>> NOTIFICATION_LANGUAGE_MODULE
>>>> 'account.Account'
>>>> ACCOUNT_DELETION_EXPUNGE_CALLBACK
>>>> RESOURCE_PUBLISHING
>>>> False
>>>> ACCOUNT_HOOKSET
>>>> <account.hooks.AccountDefaultHookSet object at 0x7fe06f67d210>
>>>> PROXY_URL
>>>> '/proxy/?url='
>>>> SITE_ID
>>>> 1
>>>> DISALLOWED_USER_AGENTS
>>>> ALLOWED_INCLUDE_ROOTS
>>>> API_LIMIT_PER_PAGE
>>>> ACCOUNT_SETTINGS_REDIRECT_URL
>>>> u'account_settings'
>>>> EXTRA_LANG_INFO
>>>> {'am': {'bidi': False,
>>>>         'code': 'am',
>>>>         'name': 'Amharic',
>>>>         'name_local': 'Amharic'},
>>>>  'si': {'bidi': False,
>>>>         'code': 'si',
>>>>         'name': 'Sinhala',
>>>>         'name_local': 'sinhala'},
>>>>  'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
>>>>  'tl': {'bidi': False,
>>>>         'code': 'tl',
>>>>         'name': 'Tagalog',
>>>>         'name_local': 'tagalog'}}
>>>> LOGGING
>>>> {'disable_existing_loggers': True,
>>>>  'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>>>>  'formatters': {'simple': {'format': '%(message)s'},
>>>>                 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>>>>  'handlers': {'console': {'class': 'logging.StreamHandler',
>>>>                           'formatter': 'simple',
>>>>                           'level': 'ERROR'},
>>>>               'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>>>>                               'filters': ['require_debug_false'],
>>>>                               'level': 'ERROR'},
>>>>               'null': {'class': 'django.utils.log.NullHandler',
>>>>                        'level': 'ERROR'}},
>>>>  'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>>>>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>>>>              'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>>>>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>>>>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
>>>>  'version': 1}
>>>> SHORT_DATE_FORMAT
>>>> 'm/d/Y'
>>>> DATABASE_USER
>>>> 'geonode'
>>>> TEST_RUNNER
>>>> 'django_nose.NoseTestSuiteRunner'
>>>> ACTSTREAM_SETTINGS
>>>> {'FETCH_RELATIONS': True,
>>>>  'GFK_FETCH_DEPTH': 1,
>>>>  'MODELS': ('people.Profile',
>>>>             'layers.layer',
>>>>             'maps.map',
>>>>             'dialogos.comment',
>>>>             'documents.document',
>>>>             'services.service'),
>>>>  'USE_JSONFIELD': True,
>>>>  'USE_PREFETCH': False}
>>>> MODELTRANSLATION_LANGUAGES
>>>> ['en']
>>>> HAYSTACK_FACET_COUNTS
>>>> False
>>>> CACHE_MIDDLEWARE_KEY_PREFIX
>>>> DEFAULT_WORKSPACE
>>>> 'geonode'
>>>> TIME_ZONE
>>>> 'America/Chicago'
>>>> FILE_UPLOAD_MAX_MEMORY_SIZE
>>>> 2621440
>>>> LOCAL_GEOSERVER
>>>> EMAIL_BACKEND
>>>> 'django.core.mail.backends.smtp.EmailBackend'
>>>> ANONYMOUS_USER_ID
>>>> -1
>>>> POSTGIS_VERSION
>>>> (2, 1, 0)
>>>> DEFAULT_MAP_ZOOM
>>>> 0
>>>> TEMPLATE_CONTEXT_PROCESSORS
>>>> ('django.contrib.auth.context_processors.auth',
>>>>  'django.core.context_processors.debug',
>>>>  'django.core.context_processors.i18n',
>>>>  'django.core.context_processors.tz',
>>>>  'django.core.context_processors.media',
>>>>  'django.core.context_processors.static',
>>>>  'django.core.context_processors.request',
>>>>  'django.contrib.messages.context_processors.messages',
>>>>  'account.context_processors.account',
>>>>  'geonode.context_processors.resource_urls',
>>>>  'geonode.geoserver.context_processors.geoserver_urls')
>>>> CELERY_QUEUES
>>>> [<unbound Queue 'default' -> <unbound Exchange ''(direct)> -> default>,
>>>>  <unbound Queue 'cleanup' -> <unbound Exchange ''(direct)> -> cleanup>,
>>>>  <unbound Queue 'update' -> <unbound Exchange ''(direct)> -> update>,
>>>>  <unbound Queue 'email' -> <unbound Exchange ''(direct)> -> email>]
>>>> LOCKDOWN_GEONODE
>>>> False
>>>> SESSION_COOKIE_AGE
>>>> 1209600
>>>> SETTINGS_MODULE
>>>> 'geonode.settings'
>>>> GUARDIAN_GET_INIT_ANONYMOUS_USER
>>>> 'geonode.people.models.get_anonymous_user_instance'
>>>> USE_ETAGS
>>>> False
>>>> SOCIAL_BUTTONS
>>>> True
>>>> LANGUAGES
>>>> (('en', 'English'),
>>>>  ('es', 'Espa\xc3\xb1ol'),
>>>>  ('it', 'Italiano'),
>>>>  ('fr', 'Fran\xc3\xa7ais'),
>>>>  ('de', 'Deutsch'),
>>>>  ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>>>>  ('id', 'Bahasa Indonesia'),
>>>>  ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
>>>>  ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
>>>>  ('fa', 'Persian'),
>>>>  ('ar', 'Arabic'),
>>>>  ('bn', 'Bengali'),
>>>>  ('ne', 'Nepali'),
>>>>  ('sq', 'Albanian'),
>>>>  ('af', 'Afrikaans'),
>>>>  ('sw', 'Swahili'),
>>>>  ('pt', 'Portuguese'),
>>>>  ('pt-br', 'Portugu\xc3\xaas Brasil'),
>>>>  ('ru', 'Russian'),
>>>>  ('vi', 'Vietnamese'),
>>>>  ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
>>>>  ('am', 'Amharic'),
>>>>  ('km', 'Khmer'),
>>>>  ('pl', 'Polish'),
>>>>  ('sv', 'Swedish'),
>>>>  ('th', 'Thai'),
>>>>  ('uk', 'Ukranian'),
>>>>  ('si', 'Sinhala'),
>>>>  ('ta', 'Tamil'),
>>>>  ('tl', 'Tagalog'))
>>>> CELERY_TASK_RESULT_EXPIRES
>>>> 1
>>>> DEFAULT_INDEX_TABLESPACE
>>>> INTERNAL_IPS
>>>> STATIC_URL
>>>> '/static/'
>>>> EMAIL_PORT
>>>> 25
>>>> LAYER_PREVIEW_LIBRARY
>>>> 'geoext'
>>>> USE_TZ
>>>> False
>>>> DEFAULT_SEARCH_SIZE
>>>> 10
>>>> CLIENT_RESULTS_LIMIT
>>>> 100
>>>> MODELTRANSLATION_DEFAULT_LANGUAGE
>>>> 'en'
>>>> ACCOUNT_SIGNUP_REDIRECT_URL
>>>> u'/'
>>>> DOCUMENT_TYPE_MAP
>>>> {'doc': 'text',
>>>>  'docx': 'text',
>>>>  'gif': 'image',
>>>>  'gz': 'archive',
>>>>  'jpeg': 'image',
>>>>  'jpg': 'image',
>>>>  'log': 'text',
>>>>  'odp': 'presentation',
>>>>  'ods': 'text',
>>>>  'odt': 'text',
>>>>  'pdf': 'presentation',
>>>>  'png': 'image',
>>>>  'ppt': 'presentation',
>>>>  'pptx': 'presentation',
>>>>  'rar': 'archive',
>>>>  'tif': 'image',
>>>>  'tiff': 'image',
>>>>  'txt': 'text',
>>>>  'xls': 'text',
>>>>  'xlsx': 'text',
>>>>  'xml': 'text',
>>>>  'zip': 'archive'}
>>>> CACHE_MIDDLEWARE_SECONDS
>>>> 600
>>>> SITENAME
>>>> 'GeoNode'
>>>> ACCOUNT_CREATE_ON_SAVE
>>>> True
>>>> CSRF_COOKIE_HTTPONLY
>>>> False
>>>> DATETIME_INPUT_FORMATS
>>>> ('%Y-%m-%d %H:%M:%S',
>>>>  '%Y-%m-%d %H:%M:%S.%f',
>>>>  '%Y-%m-%d %H:%M',
>>>>  '%Y-%m-%d',
>>>>  '%m/%d/%Y %H:%M:%S',
>>>>  '%m/%d/%Y %H:%M:%S.%f',
>>>>  '%m/%d/%Y %H:%M',
>>>>  '%m/%d/%Y',
>>>>  '%m/%d/%y %H:%M:%S',
>>>>  '%m/%d/%y %H:%M:%S.%f',
>>>>  '%m/%d/%y %H:%M',
>>>>  '%m/%d/%y')
>>>> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
>>>> False
>>>> DATABASE_PASSWORD
>>>> PROFANITIES_LIST
>>>> EMAIL_HOST_USER
>>>> MAX_DOCUMENT_SIZE
>>>> 2
>>>> You're seeing this error because you have DEBUG = True in your Django
>>>> settings file. Change that to False, and Django will display a
>>>> standard 500 page.
>>>> Davi de O. Custódio
>>> Davi de O. Custódio
>> Davi de O. Custódio
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150527/d0a4c979/attachment-0001.html>
More information about the geonode-users mailing list
