[GeoNode-users] Using GeoNode users to connect to Geoserver by Opengeo Suite QGIS Plugin
Simone Dalmasso
simone.dalmasso at gmail.com
Thu May 28 06:55:29 PDT 2015
The geoserver user is working because is the only geoserver internal user
while the others are in the geonode db and are passed to geoserver through
the session.
Not sure if modifying the stored procedure could work as probably geoserver
won't look into that table by himself. For sure other devs can tell you
much more than me, Anyway the stored procedure is not updated with the
geonode security system changes we made for the 2.4 so at the moment would
just break.
2015-05-28 15:29 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
> I would like to allow users GeoNode could interact and change styles of
> the layers using the plugin Opengeo Suite Explorer for QGIS.
> I can make the plugin to connect to the Geoserver GeoNode using the admin
> user (the geoserver), but using a common user GeoNode, you can not.
> Is there any solution for this, perhaps changing the stored procedure
> "geonode_authorize_layer"?
> Thank you.
> Davi de O. Custódio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/20fee509/attachment-0001.html>
More information about the geonode-users
