[GeoNode-users] Add values to "Add Layers ComboBox"
Ariel Nunez ingenieroariel at gmail.com
Tue Nov 3 03:43:54 PST 2015
If it is an entire OWS, you could try replicating the entry for your local
geoserver but using the remote ip.
If you installed via packages, just open /etc/geonode/local_settings.py and
start from there looking at MAP_BASELAYERS.
On Nov 3, 2015 3:20 AM, "David Alda Fernandez de Lezea" <dalda at hazi.eus>
wrote:
> Hi Ariel,
> Thanks for your response. I want to add some other organization's ows to
> the combobox so I suppose I'll have to go to GeoExplorer customization. Can
> you point me to the right file? I'm really confused about all the
> directories and javascript files.
> Thanks in advance.
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Ariel Nunez [mailto:ingenieroariel at gmail.com]
> Enviado el: lunes, 02 de noviembre de 2015 14:26
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Add values to "Add Layers ComboBox"
> This will point you in the right direction:
> http://docs.geonode.org/en/master/tutorials/admin/production.html#adding-layers-from-google-bing-and-other-providers
> For other sources you may have to read about GeoExt sources to be able to
> customize that file.
> -a
> 2015-11-02 8:15 GMT-05:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> How can I add some other url's to the combo in the map composer-> add
> Layers panel?
> There appear "My GeoServer WMS", "MapQuest Layers", "Google Layers"...
> Thanks in advance,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151103/96be2ab5/attachment.html>
More information about the geonode-users mailing list
