[GeoNode-users] GeoNode's default SRS
Simone Dalmasso simone.dalmasso at gmail.com
Fri Nov 6 06:12:44 PST 2015
Ah yes, you can't use OSM, bing or google in 4326.
2015-11-06 14:34 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> I Simone,
> Thanks for your response. I've looked into what is being sent and the
> parameters are OK:
> SRS: ESPG4326
> BBOX=-3.457379,42.46302,-2.754254,43.166145
> I think the problem is that the Base Layers (Goolge Maps and other layers
> I added) don't support the EPSG:4326 SRS.
> Anyway, I'll try to find another approach.
> Thanks.
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: viernes, 06 de noviembre de 2015 8:04
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] GeoNode's default SRS
> Hi Davi,
> to investigate further take a look at the http request through the dev
> tools. To make sure it0s still using the 4326
> 2015-11-06 7:52 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> I'm trying to set GeoNode's default SRS to EPSG:4326. So far I've edited
> the files views.py under maps and layers folders and everything seemed to
> work but when I add some layers of another OWS of our organization it
> places them at other coordinates. Furthermore, the coordinates shown in the
> mouse position control aren't correct.
> Any ideas what could be happening? Perhaps there's another way to achieve
> this.
> Thanks in advance.
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151106/e6c9ef1b/attachment-0001.html>
More information about the geonode-users mailing list
