[GeoNode-users] GeoNode's default SRS
Stefan Steiniger
sstein at geo.uzh.ch
Fri Nov 6 06:11:29 PST 2015
Yes, Google Maps or Bing or MapQuest tiles don't come in EPSG 4326. Its
simply not possible. If you use for instance QGIS and the OpenLayers
Plugin to display Mapquest in the background you will see in the bottom
left that the CRS is changing to EPSG:3857 (originally this was 900973).
EPSG 4326 is geographic coordinates while 3857 is in "m" = projected.
stefan
Am 06.11.15 um 10:34 schrieb David Alda Fernandez de Lezea:
> I Simone,
> Thanks for your response. I've looked into what is being sent and the parameters are OK:
> SRS: ESPG4326
> BBOX=-3.457379,42.46302,-2.754254,43.166145
> I think the problem is that the Base Layers (Goolge Maps and other layers I added) don't support the EPSG:4326 SRS.
> Anyway, I'll try to find another approach.
> Thanks.
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: viernes, 06 de noviembre de 2015 8:04
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] GeoNode's default SRS
> Hi Davi,
> to investigate further take a look at the http request through the dev tools. To make sure it0s still using the 4326
> 2015-11-06 7:52 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> I'm trying to set GeoNode's default SRS to EPSG:4326. So far I've edited the files views.py under maps and layers folders and everything seemed to work but when I add some layers of another OWS of our organization it places them at other coordinates. Furthermore, the coordinates shown in the mouse position control aren't correct.
> Any ideas what could be happening? Perhaps there's another way to achieve this.
> Thanks in advance.
> Regards,
> Agur bero bat,
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
