[GeoNode-users] Cannot access GeoNode 2.4 RC1 after istalling and updating IP (500 internal server error)
Shah Md. Rajibul Islam
rajibul.islam at cdmp.org.bd
Mon Nov 9 02:03:17 PST 2015
Thank a lot. I can now access geonode using browser, but it gives error “An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table” while uploading shapefiles.
Regards
GIS Analyst
CDMP – II, UNDP
Disaster Management & Relief Bhaban
92-93, Mohakhali C/A, Dhaka - 1212
Tel # 989 0937; 882 1255; 882 1459, Ext - 303
Mobile: +88 01716 027389, E-mail: <mailto:rajibul.islam at cdmp.org.bd> rajibul.islam at cdmp.org.bd
Web: <http://www.cdmp.org.bd/> www.cdmp.org.bd
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Sent: 09 November 2015 15:06
To: Shah Md. Rajibul Islam
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Cannot access GeoNode 2.4 RC1 after istalling and updating IP (500 internal server error)
There's no operations.py file in GeoNode, it is a django file and should not be modified.
you can add it to /etc/geonode/local_settings.py then restart your server
regards
2015-11-09 9:47 GMT+01:00 Shah Md. Rajibul Islam <rajibul.islam at cdmp.org.bd>:
Do you mean to add it into operations.py or where? I am using putty to connect to the server, if possible could you please check my geonode using team viewer?
GIS Analyst
CDMP – II, UNDP
Sent: 09 November 2015 13:53
ok, you can add
POSTGIS_VERSION = (2,1,0)
to your geonode settings.
Regards
2015-11-09 8:49 GMT+01:00 Shah Md. Rajibul Islam <rajibul.islam at cdmp.org.bd>:
Dear Ciao,
Thank you for your reply. I found the followings-
geonode at geonode:~$ tail -f /etc/apache2/logs/error.log
tail: cannot open ‘/etc/apache2/logs/error.log’ for reading: No such file or directory
geonode at geonode:~$ tail -f /var/log/apache2/error.log
[Mon Nov 09 00:48:14.620992 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] conn = backend.DatabaseWrapper(db, alias)
[Mon Nov 09 00:48:14.621022 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] File "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/base.py", line 11, in __init__
[Mon Nov 09 00:48:14.621065 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] self.ops = PostGISOperations(self)
[Mon Nov 09 00:48:14.621095 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] File "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/operations.py", line 158, in __init__
[Mon Nov 09 00:48:14.621136 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] if self.spatial_version < (1, 3, 4):
[Mon Nov 09 00:48:14.621190 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] File "/usr/lib/python2.7/dist-packages/django/utils/functional.py", line 49, in __get__
[Mon Nov 09 00:48:14.621232 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] res = instance.__dict__[self.func.__name__] = self.func(instance)
[Mon Nov 09 00:48:14.621263 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] File "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/operations.py", line 258, in spatial_version
[Mon Nov 09 00:48:14.621306 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] 'template?' % self.connection.settings_dict['NAME']
[Mon Nov 09 00:48:14.621354 2015] [:error] [pid 2175] [remote 192.168.0.42:27831] ImproperlyConfigured: Cannot determine PostGIS version for database "geonode_data". GeoDjango requires at least PostGIS version 1.3. Was the database created from a spatial database template?
Regards
Rajib
GIS Analyst
CDMP – II, UNDP
Sent: 09 November 2015 13:19
you can see what specific error is by reading the apache logs
let us know so that we can better help you.
Ciao
2015-11-08 7:05 GMT+01:00 Shah Md. Rajibul Islam <rajibul.islam at cdmp.org.bd>:
Dear Geonode users,
I have installed GeoNode 2.4 RC1/GeoNode version 2.4c2 on ubuntu-14.04-server-i386. First I have installed it in a virtual machine using VMware workstation and successfully installed and accessed it with the configured local IP. Later on, I have installed the same version of Geonode on the same version of Ubuntu server 14.04. I don’t have a real IP and hence I have configured the geonode with the local IP of the server. But I cannot access it through the web browser. It gives 500 internal server error:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at webmaster at localhost to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
_____
Apache/2.4.7 (Ubuntu) Server at 192.168.0.101 Port 80
Could you please suggest if it is related with the Local IP or I need a real IP to access it through web browser.
Best regards
Rajib
GIS Analyst
CDMP – II, UNDP
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151109/1f2ee2fa/attachment-0001.html>
More information about the geonode-users
