[GeoNode-users] geonode customization
Tom Kralidis
tomkralidis at gmail.com
Mon Nov 9 13:27:04 PST 2015
GeoNode supports numerous CSW backends. In the non-pycsw case it
connects to GeoNetwork or deegree3 via HTTP (see [1] for more information
on configuration).
For the 'server not found' issue you need to set the SITEURL value
accordingly in geonode.settings.
Hope this helps.
..Tom
[1] http://docs.geonode.org/en/dev/deploy/csw.html
On Mon, 9 Nov 2015, Jeffrey Johnson wrote:
> Date: Mon, 9 Nov 2015 07:00:41 -0800
> From: Jeffrey Johnson <ortelius at gmail.com>
> To: Eugenio Trumpy <frippe12573 at hotmail.com>
> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] geonode customization
> Hi Eugenio,
> Im going to let Tom or one of the other Metadata Gurus answer all the
> metadata questions, but I can say that the best way to customize the
> front end of your geonode is to use template project here
> https://github.com/GeoNode/geonode-project and then edit the base
> templates and css in your project using bootstrap. If you want to add
> new categories or topics to your data, it is better to use something
> like keywords to manage that rather than changing the standard
> metadata models. You can then leverage the search engine / api to
> change how these are presented in the UI.
> Hope that helps,
> Jeff
> On Mon, Nov 9, 2015 at 6:11 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
>> Hi to everybody,
>> thanks to everybody, in particular with who follow me during geonode my
>> installation for production.
>> Now I can say that the most important functionalities are working (including
>> save map who gave me a lot of troubles).
>> Currently I'm going to work to customize my geonode installation exploiting
>> some already running services
>> managed by my organization.
>> Firstly I read the guide:
>> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
>> but I wonder if somebody can suggest me other reference, for instance on
>> bootstrap usage in geonode or a guide to customize the portal.
>> After that I would like to know if I can manage another group of categories,
>> let's call them 'topics', which details better the layers/maps/documents I'm
>> going to upload/use.
>> Eventually I wonder I does the metadata management in geonode work. I
>> understand that all layers loaded and maps created are related to metadata
>> saved in pycsw default system. I have an already running geonetwork
>> containing about 50 metadata, I saw I can use my metadata engine as
>> catalogue by configuring it in the local_setting.py, but I guess geonode
>> will use the catalogue set to store new metadata, what happens to those
>> already loaded in my external engine? Is it possible to have them listed? If
>> not can I connect my metadata engine as CSW service by using external
>> service setup? In that way am I able to list the metadata (and the
>> attributes) somewhere in geonode?
>> Last thing is a little issue on downloading the metadata in different
>> format: two quwstions: 1) I got an error 'server not found', that's why I
>> guess there is something wrong on the URL call for the catalogue since the
>> URL is:
>> http://my_server_namecatalogue/csw?outputschema=http%3A%2F%2Fwww.isotc211.org%2F2005%2Fgmd&service=CSW&request=GetRecordById&version=2.0.2&elementsetname=full&id=15305b80-86d5-11e5-8e7f-5254002700a7
>> As you can see after http:// I have my_server_namecatalogue I think it could
>> be an error having my server name attached to catalogue, isn't it?
>> Then I wonder if it is possible to download the metadata in INSPIRE format
>> or other specific.
>> Thanks for now,
>> best
>> Eugenio
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
