[GeoNode-users] geonode customization
tom.kralidis at gmail.com tom.kralidis at gmail.com
Tue Nov 10 03:25:38 PST 2015
Can you try running updatelayers to see if the GeoNetwork records are added?
An alternative approach is to not have GeoNetwork as a backend, but instead harvest it as a remote service in GeoNode.
Sent from my iPhone
> On Nov 10, 2015, at 04:42, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Thank you for your answer, I'm going to text this solution.
> However I wonder what's happens when I set my geonetwork
> as backhand for metadata, am I able to see the already loaded metadata from my geonetwork?
> Or the back hand is needed only for the new layers/maps entries?
> Regarding the problem on the URL I sort it out, thanks!
> best
> Eugenio
> > From: tomkralidis at gmail.com
> > Date: Mon, 9 Nov 2015 16:27:04 -0500
> > To: ortelius at gmail.com
> > CC: frippe12573 at hotmail.com; geonode-users at lists.osgeo.org
> > Subject: Re: [GeoNode-users] geonode customization
> > GeoNode supports numerous CSW backends. In the non-pycsw case it
> > connects to GeoNetwork or deegree3 via HTTP (see [1] for more information
> > on configuration).
> > For the 'server not found' issue you need to set the SITEURL value
> > accordingly in geonode.settings.
> > Hope this helps.
> > ..Tom
> > [1] http://docs.geonode.org/en/dev/deploy/csw.html
> > On Mon, 9 Nov 2015, Jeffrey Johnson wrote:
> > > Date: Mon, 9 Nov 2015 07:00:41 -0800
> > > From: Jeffrey Johnson <ortelius at gmail.com>
> > > To: Eugenio Trumpy <frippe12573 at hotmail.com>
> > > Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
> > > Hi Eugenio,
> > > Im going to let Tom or one of the other Metadata Gurus answer all the
> > > metadata questions, but I can say that the best way to customize the
> > > front end of your geonode is to use template project here
> > > https://github.com/GeoNode/geonode-project and then edit the base
> > > templates and css in your project using bootstrap. If you want to add
> > > new categories or topics to your data, it is better to use something
> > > like keywords to manage that rather than changing the standard
> > > metadata models. You can then leverage the search engine / api to
> > > change how these are presented in the UI.
> > > Hope that helps,
> > > Jeff
> > > On Mon, Nov 9, 2015 at 6:11 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> > >> Hi to everybody,
> > >> thanks to everybody, in particular with who follow me during geonode my
> > >> installation for production.
> > >> Now I can say that the most important functionalities are working (including
> > >> save map who gave me a lot of troubles).
> > >> Currently I'm going to work to customize my geonode installation exploiting
> > >> some already running services
> > >> managed by my organization.
> > >> Firstly I read the guide:
> > >> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
> > >> but I wonder if somebody can suggest me other reference, for instance on
> > >> bootstrap usage in geonode or a guide to customize the portal.
> > >> After that I would like to know if I can manage another group of categories,
> > >> let's call them 'topics', which details better the layers/maps/documents I'm
> > >> going to upload/use.
> > >> Eventually I wonder I does the metadata management in geonode work. I
> > >> understand that all layers loaded and maps created are related to metadata
> > >> saved in pycsw default system. I have an already running geonetwork
> > >> containing about 50 metadata, I saw I can use my metadata engine as
> > >> catalogue by configuring it in the local_setting.py, but I guess geonode
> > >> will use the catalogue set to store new metadata, what happens to those
> > >> already loaded in my external engine? Is it possible to have them listed? If
> > >> not can I connect my metadata engine as CSW service by using external
> > >> service setup? In that way am I able to list the metadata (and the
> > >> attributes) somewhere in geonode?
> > >> Last thing is a little issue on downloading the metadata in different
> > >> format: two quwstions: 1) I got an error 'server not found', that's why I
> > >> guess there is something wrong on the URL call for the catalogue since the
> > >> URL is:
> > >> http://my_server_namecatalogue/csw?outputschema=http%3A%2F%2Fwww.isotc211.org%2F2005%2Fgmd&service=CSW&request=GetRecordById&version=2.0.2&elementsetname=full&id=15305b80-86d5-11e5-8e7f-5254002700a7
> > >> As you can see after http:// I have my_server_namecatalogue I think it could
> > >> be an error having my server name attached to catalogue, isn't it?
> > >> Then I wonder if it is possible to download the metadata in INSPIRE format
> > >> or other specific.
> > >> Thanks for now,
> > >> best
> > >> Eugenio
> > >> _______________________________________________
> > >> geonode-users mailing list
> > >> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151110/92abd6c0/attachment-0001.html>
More information about the geonode-users mailing list
