[GeoNode-users] Error accesing geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Nov 17 23:34:57 PST 2015
ok then create the symlink:
$ sudo ln -sf /etc/geonode/local_settings.py /usr/local/lib/python2.7/dist-
packages/geonode/local_settings.py that points to
restart the web server and you should be ok
2015-11-18 8:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> In the mentioned directory there's no "local_setttings.py" but there is a
> settings.py which has another GeoNode set up as I can see. Here's the
> content of the directory:
> u0899dal at Geonode:/usr/local/lib/python2.7/dist-packages/geonode$ ls -al
> total 264
> drwxr-sr-x 23 root staff 4096 nov 13 14:23 .
> drwxrwsr-x 107 root staff 4096 nov 13 14:20 ..
> drwxr-sr-x 2 root staff 4096 nov 13 14:19 api
> drwxr-sr-x 6 root staff 4096 nov 13 14:19 base
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 catalogue
> -rw-r--r-- 1 root staff 314 nov 13 14:17 celery_app.py
> -rw-r--r-- 1 root staff 477 nov 13 14:19 celery_app.pyc
> -rw-r--r-- 1 root staff 3018 nov 13 14:17 context_processors.py
> -rw-r--r-- 1 root staff 1874 nov 13 14:19 context_processors.pyc
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 contrib
> drwxr-sr-x 5 root staff 4096 nov 13 14:19 documents
> drwxr-sr-x 3 root staff 4096 nov 13 14:19 geoserver
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 groups
> -rw-r--r-- 1 root staff 1291 nov 13 14:17 __init__.py
> -rw-r--r-- 1 root staff 1195 nov 13 14:19 __init__.pyc
> drwxr-sr-x 5 root staff 4096 nov 13 14:19 layers
> drwxr-sr-x 38 root staff 4096 nov 13 14:19 locale
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 maps
> -rw-r--r-- 1 root staff 1192 nov 13 14:17 middleware.py
> -rw-r--r-- 1 root staff 1832 nov 13 14:19 middleware.pyc
> drwxr-sr-x 5 root staff 4096 nov 13 14:19 people
> drwxr-sr-x 2 root staff 4096 nov 13 14:19 proxy
> drwxr-sr-x 3 root staff 4096 nov 13 14:19 security
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 services
> -rw-r--r-- 1 root staff 26032 nov 13 14:17 settings.py
> -rw-r--r-- 1 root staff 18850 nov 13 14:19 settings.pyc
> -rw-r--r-- 1 root staff 1218 nov 13 14:17 sitemap.py
> -rw-r--r-- 1 root staff 1336 nov 13 14:19 sitemap.pyc
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 social
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 static
> drwxr-sr-x 21 root staff 4096 nov 13 14:23 static_root
> drwxr-sr-x 2 root staff 4096 nov 13 14:19 tasks
> drwxr-sr-x 13 root staff 4096 nov 13 14:19 templates
> drwxr-sr-x 2 root staff 4096 nov 13 14:19 tests
> drwxr-sr-x 4 root staff 4096 nov 13 14:19 upload
> -rw-r--r-- 1 root staff 5638 nov 13 14:17 urls.py
> -rw-r--r-- 1 root staff 3999 nov 13 14:19 urls.pyc
> -rw-r--r-- 1 root staff 21450 nov 13 14:17 utils.py
> -rw-r--r-- 1 root staff 21371 nov 13 14:19 utils.pyc
> -rw-r--r-- 1 root staff 2623 nov 13 14:17 version.py
> -rw-r--r-- 1 root staff 2268 nov 13 14:19 version.pyc
> -rw-r--r-- 1 root staff 3927 nov 13 14:17 views.py
> -rw-r--r-- 1 root staff 3385 nov 13 14:19 views.pyc
> -rw-r--r-- 1 root staff 1105 nov 13 14:17 wsgi.py
> -rw-r--r-- 1 root staff 362 nov 13 14:19 wsgi.pyc
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL
> ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: martes, 17 de noviembre de 2015 18:05
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Error accesing geonode
> Hi,
> there is a symlink in
> /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py that
> points to /etc/geonode/local_settings.py.
> 2015-11-17 9:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi again,
> In theory, the local_settigns.py does not have errors as it was working
> before the change.. Where is referenced from python the file
> /etc/geonode/local_settings.py??
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 16 de noviembre de 2015 10:47
> Ok then the /etc/geonode/local_settings.py file is not read correctly.
> The customization process that you used does not modify at all the geonode
> installation and to revert to a vanilla geonode it's enough to just point
> apache to the correct wsgi. So it must be something with the settings. Also
> a syntax erro in the local_settings could be the cause.
> 2015-11-16 10:40 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> I think I'm pointing to the right one:
> /etc/apache2/sites-available/geonode
> WSGIProcessGroup geonode
> WSGIPassAuthorization On
> WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
> <Directory "/var/www/geonode/">
> Order allow,deny
> Options Indexes FollowSymLinks
> Allow from all
> IndexOptions FancyIndexing
> </Directory>
> Still getting the same error.
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 16 de noviembre de 2015 10:00
> Maybe apache is still pointing to the wrong wsgi file, not the original
> geonode. Also try to turn on debug in your settings, you will discover if
> they are actually used and in case yes where the error is.
> 2015-11-16 9:44 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi Simone,
> I had it working normally before I started modifying all the look and feel
> part. Indeed, I haven't changed anything to pint to sqllite.
> I also have my local_settigns.py customized and it was working fine. How
> can I point the app to my settings file ?
> By the way I forgot to put the link with the instructions I followed:
> https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 16 de noviembre de 2015 9:37
> Hi David,
> it seems that your settings file is not configured with the correct
> database. Is trying to access a file so it's likely that is configured to
> use sqllite.
> Regards
> 2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> I've been trying to customize the look and feel of my geonode following
> the instructions in . After configuring several options and not achieving
> to get anything working y decide to rollback, but now while accessing my
> geonode app y get the following error:
> OperationalError at /
> unable to open database file
> Request Method: GET
> Request URL: http://192.168.1.190/
> Django Version: 1.6.10
> Exception Type: OperationalError
> Exception Value:
> Exception Location:
> /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py
> in get_new_connection, line 347
> Python Executable: /usr/bin/python
> Python Version: 2.7.3
> Python Path:
> ['/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/var/www']
> Server time: Mon, 16 Nov 2015 02:16:42 -0600
> I can access GeoServer though.
> Any ideas? Thanks in advance.
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151118/008686ca/attachment-0001.html>
More information about the geonode-users
