[GeoNode-users] Problem to set new list of scale map in geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Nov 23 04:25:24 PST 2015
Hi what do you mean by geonode list of scales? the ones in the map composer?
2015-11-23 12:38 GMT+01:00 Albano Giovanni <albano.giovanni at tiscali.it>:
> Good morning,
> I have a problem with the list of map scales.
> I'm trying to change the list of map scales.
> I would use those in gridset: GlobalCRS84Scale
> I modified the default gridset in geoserver and i reloaded the gridset
> using command of geoserver Seed / Truncate of the layer.
> But when I open geonode list of scales refers to the old gridset. What's
> wrong?
> Thanks for the help.
> *Giovanni Albano*
> Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
> *Please consider the environment – Do you really need to print this email?*
> Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le
> informazioni contenute in questo messaggio sono riservate e ad uso
> esclusivo del destinatario. Qualora il messaggio in parola Le fosse
> pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
> inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
> *This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain
> confidential and/or privileged information. If you are not the addressee or
> authorized to receive this for the addressee, you must not use, copy,
> disclose or take any action based on this message or any information
> herein. If you have received this message in error, please advise the
> sender immediately by reply e-mail and delete this message. **Thank you
> for your cooperation*
> *Da:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *Per
> conto di *Simone Dalmasso
> *Inviato:* lunedì 23 novembre 2015 10:59
> *A:* Florian Hoedt
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] How to migrate from ppa testing to ppa
> stable?
> Hi Florian,
> you are right, from testing to stable is pretty straightforward. Just add
> ppa:geonode/stable sudo apt-get update and sudo apt-get install geonode.
> A collectstatic might also be needed. For the downstream project, we added
> the mapping cart (see demo http://demo.geonode.org/layers/), just check
> whether it fits with your templates.
> 2015-11-23 10:52 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
> Hi,
> I am happy to read that geonode 2.4 reached a stable state. I currently
> use Version 2.4c2 from the testing branch. How to migrate to the stable
> branch?
> I have created some styles via:
> sudo -E django-admin startproject my_geonode --template=
> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
> In theory I should update the master branch and my_geonode would just work
> as before, since it is a template which gets loaded in addition to the main
> geonode.
> yours
> Florian
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/871cfa33/attachment.html>
More information about the geonode-users
