[GeoNode-users] geonode point symbols
John Jediny
john.jediny at gmail.com
Sun Nov 29 21:08:56 PST 2015
Note too that you can also use svg by replacing
xlink:href="./img/marae16.png" />
<Format>image/png</Format>
...with...
xlink:href="./img/marae16.svg" />
<Format>image/svg</Format>
while supported by Geoserver in editting the .sld directly - this is not
supported via geoexplorer's sld editor
On Sun, Nov 29, 2015 at 9:14 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> The key would be to put the icon somewhere in /var/www/geonode/static/.
> That way you can reference it with a fully qualified url of http://
> <yourgeonode>/static/icon.png
> On Sun, Nov 29, 2015 at 9:02 PM, <tom at maptec.org> wrote:
>> Hello list members,
>> I have installed Geonode 2.4 using the ppa:geonode/stable, and now
>> getting some data into it. Having problem styling point data. For polygons
>> I simply create the .sld file in QGIS and it works fine. But points seem to
>> image in the .sld.
>> I located the directory at /usr/share/geoserver/data/styles and added an
>> /img directory to put images in. (Is this the correct location?)
>> I also tried creating point symbol from the Geoserver Style Manager,
>> still no luck. Any help or examples of using a .png to symbolize points
>> much appreciated. I am using this in style manager, but only returns a grey
>> square not the .png image;
>> <?xml version="1.0" encoding="ISO-8859-1"?>
>> <StyledLayerDescriptor version="1.0.0"
>> xsi:schemaLocation="http://www.opengis.net/sld
>> StyledLayerDescriptor.xsd"
>> xmlns="http://www.opengis.net/sld"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <NamedLayer>
>> <Name>marae</Name>
>> <UserStyle>
>> <Title>Marae</Title>
>> <Abstract>Marae location</Abstract>
>> <FeatureTypeStyle>
>> <Rule>
>> <PointSymbolizer>
>> <Graphic>
>> <ExternalGraphic>
>> <OnlineResource
>> xlink:type="simple"
>> </ExternalGraphic>
>> <Size>16</Size>
>> </Graphic>
>> </PointSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> </StyledLayerDescriptor>
>> Thanks,
>> Tom
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151130/9f40740c/attachment-0001.html>
More information about the geonode-users
