[GeoNode-users] [geonode] Errors were encountered while processing: geoserver-geonode geonode (#2371)
Jessel, Tanner Monroe tjessel at utk.edu
Mon Nov 30 05:36:51 PST 2015
Good morning,
Thanks.
It's a new and fresh ubuntu;
I actually just set up a new one this morning and had the same problem.
I'm attaching the CLI session as text...
The errors are below:
Creating config file /etc/logrotate.d/tomcat7 with new version
 * Starting Tomcat servlet engine tomcat7                                                [ OK ]
Processing triggers for ureadahead (0.100.0-16) ...
Setting up geoserver-geonode (2.7.4-2) ...
 * Stopping Tomcat servlet engine tomcat7                                                [ OK ]
 * Starting Tomcat servlet engine tomcat7                                                [fail]
dpkg: error processing package geoserver-geonode (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of geonode:
 geonode depends on geoserver-geonode | geoserver; however:
  Package geoserver-geonode is not configured yet.
  Package geoserver is not installed.
dpkg: error processing package geonode (--configure):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
No apport report written because the error message indicates its a followup error from a previous failure.
          Processing triggers for ufw (0.34~rc-0ubuntu2) ...
Processing triggers for python-support (1.0.15) ...
Processing triggers for ca-certificates (20141019ubuntu0.14.04.1) ...
Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d....
done.
done.
 geoserver-geonode
 geonode
E: Sub-process /usr/bin/dpkg returned an error code (1)
ubuntu at ip-172-31-59-87:~$
-Tanner
From: Simone Dalmasso <notifications at github.com>
Sent: Monday, November 30, 2015 4:23 AM
To: GeoNode/geonode
Cc: Jessel, Tanner Monroe
Subject: Re: [geonode] Errors were encountered while processing: geoserver-geonode geonode (#2371)
Hi GeoNode should install smoothly on ubuntu server 14.04. Is the same Os we use for demo.geonode.org.
Did you install it on a new and fresh ubuntu?
ps, please use the mailing lists geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org> rather than tickets to ask for support
Reply to this email directly or view it on GitHub<https://github.com/GeoNode/geonode/issues/2371#issuecomment-160568535>.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151130/b69a33f3/attachment-0001.html>
Type: application/octet-stream
Desc: GeoNode-Install-Saved-Output
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151130/b69a33f3/attachment-0001.obj>
More information about the geonode-users mailing list
