[GeoNode-users] Permissions on GeoNode deployment
Melvin Ramos
melvin.ramos1991 at gmail.com
Tue Oct 6 16:04:37 PDT 2015
Hi Simone,
I already did everything written in that webpage. Nothing so far. I've
spending several days trying to find out what is wrong but nothing so far.
So I propose the following if it's possible of course. I'm thinking on
creating a new deployment. Since there is no documentation regarding
deployment on live servers (
http://geonode.readthedocs.org/en/master/tutorials/admin/deploy/index.html#deploy
is empty), according to your experience (anyone is invited to contribute),
which are the steps to follow, regarding permissions, in order to deploy
GeoNode correctly?
Thanks in advance,
Melvin
Enviado con MailTrack
<https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
2015-09-30 1:40 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Melvin, there may be more than one errors here:
> - first seems that you did not set the SITE_URL properly in the settings
> as the client is requesting the static content over localhost:8000 so maybe
> you have also to turn odd DEBUG and do a collectstatic (check also the
> settings for static_root and apache ownership there).
> - second geoserver may be unable to access GeoNode for authentication
> purposes because is looking for it on port 8000, for this you should refer
> to the docs here
> http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install
> hope this helps
> 2015-09-29 23:51 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
>> Hello community,
>> I made a deployment of GeoNode (using the GitHub way, meaning the version
>> is 2.4bSomething) in a VPS server, and at first I had trouble because I
>> couldn't upload files. I changed the ownership of the uploaded folder from
>> root to www-data to fix this.
>> Although everything works fine regarding the uploading, once uploaded the
>> file, the system can't show the layers in the map viewer (both the layer
>> detail and the viewer alone), and also if you set up the thumbnail, it
>> creates the thumb file, but it doesn't show it. It gives this error:
>> Failed to load resource: net::ERR_NETWORK_ACCESS_DENIED
>> http://localhost:8000/uploaded/thumbs/layer-1886cbce-4162-11e5-92a1-f23c91e4f95f-thumb.png
>> Any ideas what I am missing?
>> Thanks in advance
>> Melvin David Ramos Macías
>> 07-41408
>> Ingeniería de Computación
>> Universidad Simón Bolívar
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
07-41408
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151006/93fa8e10/attachment.html>
More information about the geonode-users
