[GeoNode-users] [GeoNode-devel] bing api request denied
Paolo Corti
pcorti at gmail.com
Wed Oct 7 06:57:01 PDT 2015
Thanks to both
for system in productions containing existing maps I think the only way is
to follow Bart's suggestion or running a script able to remove the Bing map
baselayer from any existing map.
cheers
p
On Wed, Oct 7, 2015 at 3:51 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Thanks Bart,
> then is good to keep it disabled by default and add instructions on how to
> properly add it.
> 2015-10-07 15:50 GMT+02:00 Bart van den Eijnden <bartvde at boundlessgeo.com>
>> Ideally you would have requested your own API key for your site on
>> https://www.bingmapsportal.com
>> And then configure the gxp Bing source with the apiKey property / config.
>> Best regards,
>> Bart
>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>> 1-877-673-6436 <917-460-7207>
>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>> <http://boundlessgeo.com>
>> On 07 Oct 2015, at 15:41, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>> Dears,
>> from yesterday the bing maps api that are used by default in every
>> GeoNode map are not working anymore due to a request denied. The effect is
>> that every map in GeoNode cannot be zoomed properly anymore.
>> While we try to figure out what is the cause of this we suggest a quick
>> fix,
>> open your GeoNode settings (/etc/geonode/local_settings.py for a
>> standard apt-get installation) and comment the following lines like we
>> already did on master
>> https://github.com/GeoNode/geonode/commit/f2707e64e78931b31a06016a3e04f1ba76021b66 then
>> restart the web server.
>> We appreciate any comment and feedback.
>> Simone
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151007/4a10e4ad/attachment.html>
More information about the geonode-users
