[GeoNode-users] Error adding remote service
David Alda Fernandez de Lezea dalda at hazi.eus
Wed Oct 14 00:28:58 PDT 2015
Hi Simone,
Thanks for your help. I changed what you said And now I'm getting
DEBUG is set to False but the host of the path provided to the proxy service is not in the PROXY_ALLOWED_HOSTS setting.
After a lot of changes here's what I have in my local_settings.py
ALLOWED_HOSTS=["192.168.1.190", "localhost","127.0.0.1",]
PROXY_ALLOWED_HOSTS=("192.168.1.190", "localhost", "127.0.0.1",)
Where 192.168.1.190 is the IP of my geonode instance
By the way, I've been searching on the web about this subject and I've found some confusing comments... From my point of view I got some thoughts/questions..
In my case what I want to achieve is that any user can add an external/remote WMS from any source in the world. Taking into account this premise, do I have to add in the PROXY_ALLOWED_HOSTS every WMS that exists in the world?
I was expecting a dynamic functionality..
I hope I explained myself clear enough.
Thanks in advance.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: martes, 13 de octubre de 2015 14:40
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Error adding remote service
Hi, seems that you have set a PROXY_ALLOWED_HOSTS = ['ip1', 'ip2',] using square brackets, you should use normal parenthesis PROXY_ALLOWED_HOSTS = ('ip1','ip2',)
2015-10-13 14:29 GMT+02:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
From the user interface, while creating a Map, I'm trying to add a remote WMS, from another organization but without success, indeed I'm getting the following error:
[Tue Oct 13 07:24:33 2015] [error] Internal Server Error: /proxy/
[Tue Oct 13 07:24:33 2015] [error] Traceback (most recent call last):
[Tue Oct 13 07:24:33 2015] [error]   File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 115, in get_response
[Tue Oct 13 07:24:33 2015] [error]     response = callback(request, *callback_args, **callback_kwargs)
[Tue Oct 13 07:24:33 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/geonode/proxy/views.py", line 31, in proxy
[Tue Oct 13 07:24:33 2015] [error]     PROXY_ALLOWED_HOSTS = (ogc_server_settings.hostname,) + getattr(settings, 'PROXY_ALLOWED_HOSTS', ())
[Tue Oct 13 07:24:33 2015] [error] TypeError: can only concatenate tuple (not "list") to tuple
Do I have to configure anything related with grants or something like that?
Thanks in advance,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
More information about the geonode-users mailing list
