[GeoNode-users] GeoExplorer customization
Francesco Marigliano
f.marigliano.it at ieee.org
Fri Oct 16 00:15:24 PDT 2015
Thank you Jeffrey.
I decided only to change the interface and not the logic, as you can see
here: http://www.geourba.it/maps/7/view
If someone needs the "Orange theme" it can be found here:
https://github.com/helios2/GeoExplorerOrangeTheme
Il 15/10/2015 18:34, Jeffrey Johnson ha scritto:
> On Thu, Oct 15, 2015 at 2:53 AM, Francesco Marigliano
> <f.marigliano.it at ieee.org> wrote:
>> Hi all,
>> I've two questions.
>> I'm going to customize GeoExplorer (styles, buttons, etc) and I need to know
>> if someone has already did that.
>> 1 - Change the GeoExplorer default style: how can I set it to "gray"
>> (folder: /var/www/geonode/static/geoexplorer/externals/ext/resources/images)
> that’s a general Ext question, just change the css style tag
> <link rel="stylesheet" type="text/css"
> href="../externals/ext/resources/css/xtheme-gray.css">
>> 2 - It is possible to change the "Query" field with a more "user-friendly"
>> interface? I assure that most users doesn't know how to query, so I need a
>> more simply "search box" field
> This would take some development effort on your end to change things.
> The 2 relevant classes are here
> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js
> https://github.com/boundlessgeo/gxp/blob/master/src/script/plugins/GeoNodeCatalogueSource.js
>> Cheers,
>> Francesco
>> Questa e-mail è stata controllata per individuare virus con Avast antivirus.
>> https://www.avast.com/antivirus
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users
