[GeoNode-users] Just installed Geonode, one question
Gisli Palsson
gisli.palsson at umu.se
Tue Oct 20 12:09:35 PDT 2015
Thanks for the response Simone. I have been trying to change the server name to get around this.
Tried going from ‘servername localhost’ to ‘servername geonode.localhost’ but that doesn’t do the trick. Anyone know?
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Sent: 20 October 2015 20:59
To: Gisli Palsson <gisli.palsson at umu.se>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Just installed Geonode, one question
Hi as stated in the docs geonode installed via apt-get should be installed in a clean environment. Probably it just changed the Apache default site but might not be the only thing. /etc/apache/sites-enabled
Hope this helps
Il martedì 20 ottobre 2015, Gisli Palsson <gisli.palsson at umu.se<mailto:gisli.palsson at umu.se>> ha scritto:
Hey,
I just installed Geonode onto a system that I’m planning on using for two applications. The Geonode works fine, but the other (Omeka) installed at var/www/omeka isn’t being served to the internet. Instead, Geonode takes over the entire site. There isn’t anything obvious in the documentation to solve this.
I’m not sure how to fix this, any help appreciated!
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151020/491bb23c/attachment.html>
More information about the geonode-users
