[GeoNode-users] Just installed Geonode, one question
Gisli Palsson
gisli.palsson at umu.se
Tue Oct 20 12:19:10 PDT 2015
Hey Charles,
I did make a simple omeka.conf earlier:
<VirtualHost *:80>
Servername omeka.localhost
ServerAdmin webmaster at localhost
<Directory /var/www/omeka/>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
</VirtualHost>
The Geonode.conf file looks like this:
WSGIDaemonProcess geonode user=www-data threads=15 processes=2
<VirtualHost *:80>
Servername geonode.localhost
ErrorLog /var/log/apache2/error.log
LogLevel warn
CustomLog /var/log/apache2/access.log combined
WSGIProcessGroup geonode
WSGIPassAuthorization On
WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
<Directory "/var/www/geonode/">
Order allow,deny
Allow from all
IndexOptions FancyIndexing
</Directory>
Alias /static/ /var/www/geonode/static/
Alias /uploaded/ /var/www/geonode/uploaded/
Alias /robots.txt /var/www/geonode/robots.txt
<Directory "/var/www/geonode/uploaded/documents/">
Order allow,deny
Deny from all
</Directory>
000-default.conf looks unchanged.
Thanks again for any help.
Sent: 20 October 2015 21:15
To: Gisli Palsson <gisli.palsson at umu.se>
Cc: Simone Dalmasso <simone.dalmasso at gmail.com>; geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Just installed Geonode, one question
In /etc/apache2/sites-enabled you need 1) geonode.conf and 2) omeka.conf.
-Charles
On Tue, Oct 20, 2015 at 3:09 PM, Gisli Palsson <gisli.palsson at umu.se<mailto:gisli.palsson at umu.se>> wrote:
Thanks for the response Simone. I have been trying to change the server name to get around this.
Tried going from ‘servername localhost’ to ‘servername geonode.localhost’ but that doesn’t do the trick. Anyone know?
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>]
Sent: 20 October 2015 20:59
To: Gisli Palsson <gisli.palsson at umu.se<mailto:gisli.palsson at umu.se>>
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi as stated in the docs geonode installed via apt-get should be installed in a clean environment. Probably it just changed the Apache default site but might not be the only thing. /etc/apache/sites-enabled
Hope this helps
Il martedì 20 ottobre 2015, Gisli Palsson <gisli.palsson at umu.se<mailto:gisli.palsson at umu.se>> ha scritto:
Hey,
I just installed Geonode onto a system that I’m planning on using for two applications. The Geonode works fine, but the other (Omeka) installed at var/www/omeka isn’t being served to the internet. Instead, Geonode takes over the entire site. There isn’t anything obvious in the documentation to solve this.
I’m not sure how to fix this, any help appreciated!
Simone
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151020/2f0f415d/attachment-0001.html>
More information about the geonode-users
