[GeoNode-users] Cant upload and register remote services after update
Christian Willmes christian.willmes at googlemail.com
Fri Oct 30 06:00:29 PDT 2015
I run a GeoNode /version 2.4c2 /from the ubuntu packages./
/After an "apt-get update / upgrade" yesterday, I can't upload new
layers or register remote services on GeoNode anymore.
/On registering remote services the logs say:
[Fri Oct 30 13:24:41.857736 2015] [core:error] [pid 24951:tid
140094098888448] [client 134.95.126.26:38719] End of script output
before headers: geonode.wsgi
[Fri Oct 30 13:24:41.857932 2015] [core:error] [pid 25013:tid
140094014961408] [client 134.95.126.26:38714] End of script output
[Fri Oct 30 13:24:41.858108 2015] [core:error] [pid 24951:tid
140094090495744] [client 127.0.0.1:36688] End of script output before
[Fri Oct 30 13:24:41.858290 2015] [core:error] [pid 24951:tid
140094073710336] [client 134.95.126.26:38467] End of script output
[Fri Oct 30 13:24:41.858455 2015] [core:error] [pid 24951:tid
140094006568704] [client 134.95.126.26:38447] End of script output
[Fri Oct 30 13:24:41.858625 2015] [core:error] [pid 25013:tid
140094115673856] [client 134.95.126.26:38399] End of script output
[Fri Oct 30 13:24:41.858788 2015] [core:error] [pid 25013:tid
140093914248960] [client 134.95.126.26:38411] End of script output
[Fri Oct 30 13:24:41.858963 2015] [core:error] [pid 25013:tid
140093939427072] [client 134.95.126.26:38433] End of script output
[Fri Oct 30 13:24:41.859267 2015] [core:error] [pid 25013:tid
140093964605184] [client 134.95.126.26:38350] End of script output
[Fri Oct 30 13:24:41.859403 2015] [core:error] [pid 24951:tid
140093922641664] [client 134.95.150.136:37065] End of script output
before headers: geonode.wsgi, referer:
http://geonode.crc806db.uni-koeln.de/services/register/
On upload via the web gui, the logs say:
[Fri Oct 30 07:50:58.506998 2015] [:error] [pid 1277:tid
139701666780928] "'category'"
[Fri Oct 30 07:50:58.507085 2015] [:error] [pid 1277:tid
139701666780928] Traceback (most recent call last):
[Fri Oct 30 07:50:58.507097 2015] [:error] [pid 1277:tid
139701666780928]   File
"/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line
154, in layer_upload
[Fri Oct 30 07:50:58.507106 2015] [:error] [pid 1277:tid
139701666780928]     topic_id = request.POST['category']
[Fri Oct 30 07:50:58.507115 2015] [:error] [pid 1277:tid
"/usr/lib/python2.7/dist-packages/django/utils/datastructures.py", line
301, in __getitem__
[Fri Oct 30 07:50:58.507126 2015] [:error] [pid 1277:tid
139701666780928]     raise MultiValueDictKeyError(repr(key))
[Fri Oct 30 07:50:58.507139 2015] [:error] [pid 1277:tid
139701666780928] MultiValueDictKeyError: "'category'"
Is there any step I need to do manually after an package upgrade? I
remember similar problems after the last update, then it was a problem
with "uploadsession" not "category" during upload layers.
Thanks and regards,
Christian
More information about the geonode-users mailing list
