[GeoNode-users] Cant upload and register remote services after update
Charles Cossé
ccosse at gmail.com
Fri Oct 30 08:36:21 PDT 2015
Hi, I may be somewhat implicated in this. This is what I have in my
layers/views.py around the Line#154 in your error message. It is different
than what's in git at the moment, and I'm not sure why. The below is a
hack, for sure, which was awaiting more insight into getting the
category_form returned from layers_upload.html ... nonetheless, if you
replace the topic_id retrieval section in your views.py I suspect it will
work. Meanwhile the views.py on github appears that it cannot work as-is
... will look into it more later. (what might have happened was a revert
b/c multiple categories not handled, but reverted to previous broken
version, ie. not far enough back).
try:
# Moved this inside the try/except block because it can
raise
# exceptions when unicode characters are present.
# This should be followed up in upstream Django.
tempdir, base_file = form.write_files()
logging.debug(request)
topic_id = request.META.get("HTTP_COOKIE")
topic_id = string.split(topic_id, " ")[0]
topic_id = string.split(topic_id, ":")[1]
topic_id = string.split(topic_id, ";")[0]
logging.debug(topic_id)
topic_category = TopicCategory.objects.get(
id=topic_id
saved_layer = file_upload(
base_file,
name=name,
user=request.user,
overwrite=False,
charset=form.cleaned_data["charset"],
abstract=form.cleaned_data["abstract"],
title=form.cleaned_data["layer_title"],
Layer.objects.filter(name=name).update(
category=topic_category
except Exception as e:
exception_type, error, tb = sys.exc_info()
On Fri, Oct 30, 2015 at 10:59 AM, Christian Willmes <
christian.willmes at googlemail.com> wrote:
> just to clarify, I tried the upload and register of remote service again
> after running "geonode collectstatic".
> I also made sure to select a category from the GUI, but for testing also
> tryed to upload without selecting a category, both resulting in the exact
> same errors in the logs.
> Any Ideas?
> Thanks,
> Christian
> Am 30.10.2015 um 15:02 schrieb Christian Willmes:
>> Hi,
>> thanks, but it did not help. I did:
>> ~$ geonode collectstatic
>> You have requested to collect static files at the destination
>> location as specified in your settings.
>> This will overwrite existing files!
>> Are you sure you want to do this?
>> Type 'yes' to continue, or 'no' to cancel: yes
>> 0 static files copied, 880 unmodified.
>> Errors in logs look exactly same, as posted in the mail before.
>> Regards,
>> Christian
>> Am 30.10.2015 um 14:57 schrieb Simone Dalmasso:
>>> Christian. A geonode collectstatic may fix. Let us know
>>> Il venerdì 30 ottobre 2015, Christian Willmes <
>>> christian.willmes at googlemail.com <mailto:
>>> christian.willmes at googlemail.com>> ha scritto:
>>> Hi,
>>> I run a GeoNode /version 2.4c2 /from the ubuntu packages./
>>> /After an "apt-get update / upgrade" yesterday, I can't upload new
>>> layers or register remote services on GeoNode anymore.
>>> /On registering remote services the logs say:
>>> [Fri Oct 30 13:24:41.857736 2015] [core:error] [pid 24951:tid
>>> 140094098888448] [client 134.95.126.26:38719
>>> <http://134.95.126.26:38719>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.857932 2015] [core:error] [pid 25013:tid
>>> 140094014961408] [client 134.95.126.26:38714
>>> <http://134.95.126.26:38714>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.858108 2015] [core:error] [pid 24951:tid
>>> 140094090495744] [client 127.0.0.1:36688 <http://127.0.0.1:36688>]
>>> End of script output before headers: geonode.wsgi
>>> [Fri Oct 30 13:24:41.858290 2015] [core:error] [pid 24951:tid
>>> 140094073710336] [client 134.95.126.26:38467
>>> <http://134.95.126.26:38467>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.858455 2015] [core:error] [pid 24951:tid
>>> 140094006568704] [client 134.95.126.26:38447
>>> <http://134.95.126.26:38447>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.858625 2015] [core:error] [pid 25013:tid
>>> 140094115673856] [client 134.95.126.26:38399
>>> <http://134.95.126.26:38399>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.858788 2015] [core:error] [pid 25013:tid
>>> 140093914248960] [client 134.95.126.26:38411
>>> <http://134.95.126.26:38411>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.858963 2015] [core:error] [pid 25013:tid
>>> 140093939427072] [client 134.95.126.26:38433
>>> <http://134.95.126.26:38433>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.859267 2015] [core:error] [pid 25013:tid
>>> 140093964605184] [client 134.95.126.26:38350
>>> <http://134.95.126.26:38350>] End of script output before headers:
>>> geonode.wsgi
>>> [Fri Oct 30 13:24:41.859403 2015] [core:error] [pid 24951:tid
>>> 140093922641664] [client 134.95.150.136:37065
>>> <http://134.95.150.136:37065>] End of script output before
>>> headers: geonode.wsgi, referer:
>>> http://geonode.crc806db.uni-koeln.de/services/register/
>>> On upload via the web gui, the logs say:
>>> [Fri Oct 30 07:50:58.506998 2015] [:error] [pid 1277:tid
>>> 139701666780928] "'category'"
>>> [Fri Oct 30 07:50:58.507085 2015] [:error] [pid 1277:tid
>>> 139701666780928] Traceback (most recent call last):
>>> [Fri Oct 30 07:50:58.507097 2015] [:error] [pid 1277:tid
>>> 139701666780928] File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py",
>>> line 154, in layer_upload
>>> [Fri Oct 30 07:50:58.507106 2015] [:error] [pid 1277:tid
>>> 139701666780928] topic_id = request.POST['category']
>>> [Fri Oct 30 07:50:58.507115 2015] [:error] [pid 1277:tid
>>> "/usr/lib/python2.7/dist-packages/django/utils/datastructures.py",
>>> line 301, in __getitem__
>>> [Fri Oct 30 07:50:58.507126 2015] [:error] [pid 1277:tid
>>> 139701666780928] raise MultiValueDictKeyError(repr(key))
>>> [Fri Oct 30 07:50:58.507139 2015] [:error] [pid 1277:tid
>>> 139701666780928] MultiValueDictKeyError: "'category'"
>>> Is there any step I need to do manually after an package upgrade?
>>> I remember similar problems after the last update, then it was a
>>> problem with "uploadsession" not "category" during upload layers.
>>> Thanks and regards,
>>> Christian
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151030/eea67630/attachment.html>
More information about the geonode-users
