[GeoNode-users] Layer upload and enabling django-notification
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Sep 7 03:11:53 PDT 2015
Ok, tested on a Virtual machine. I had to make sure that www-data has the
rights to write in the /var/www folder. Tested changing the ownership and
works.
2015-09-07 11:59 GMT+02:00 Seno Adiwicaksono <senoadiw at gmail.com>:
> Hi Simone,
> I did the complete install from
> https://geonode.readthedocs.org/en/2.0/tutorials/admin/install/complete_install.html.
> I have the main geonode installation in /var/www/geonode/ and a geonode
> project in /var/www/my_geonode/. GeoNode is running under Apache www-data
> user. I can see the layer files written in the uploaded dir but then the
> lockfile error happens.
> Regards,
> SN
> On Mon, Sep 7, 2015 at 4:39 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Hi,
>> what installation did you do?
>> 2015-09-07 11:05 GMT+02:00 Seno Adiwicaksono <senoadiw at gmail.com>:
>>> Dear GeoNode users,
>>> I'm trying to enable notifications on my GeoNode install however met
>>> with the same lockfile error as pointed out by Hugo in this thread
>>> http://osgeo-org.1560.x6.nabble.com/uploading-layer-and-enable-notifications-td5214225.html.
>>> I also tried setting the NOTIFICATION_LOCK_LOCATION variable as well as
>>> chown the /var/www/geonode folder to www-data and create a notification
>>> folder in it with 777 permissions which did not work in my case. I also
>>> tried setting NOTIFICATION_QUEUE_ALL = True so the notifications are sent
>>> later but the error just came up faster.
>>> As for now I commented out notification in INSTALLED_APPS to allow layer
>>> uploads to complete. Is anyone else having the same issue and are there any
>>> other workarounds? I would greatly appreciate any input provided.
>>> Regards,
>>> SN
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150907/9f5a4184/attachment-0001.html>
More information about the geonode-users
