[GeoNode-users] unable to save maps
Simone Dalmasso simone.dalmasso at gmail.com
Mon Sep 21 11:31:22 PDT 2015
Hi Eugenio,
everything you said is right :)
Not sure if tomcat7 is a requirement instead of tomcat6 but shouldn't. Take
a look at the tomcat logs.
2015-09-21 18:11 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I'm testing GeoNode <http://geonode.org>
> *version 2.4.dev20150908094256.*I installed this version by following the
> steps described here:
> http://docs.geonode.org/en/latest/tutorials/admin/install/custom_install.html#custom-install
> The application seems to work fine. I added 4 different wed map services
> (both geoservers and mapserver),
> and I have several layers.
> I tried to compose a map, and I was able to, but I got an error on saving
> the prepared maps as well as when
> I click on create maps I had:
> The server returned an error: 503 SERVICE UNAVAILABLE
> I think this error is due to a geoserver that I'm using for geonode.
> Is that right?
> Actually the geoserver that I got from the geonode installation runs (or
> should run) in a second container of tomcat6
> since I already have another geoserver instance on the first tomcat6
> container. And I have to use them separate.
> Am I right?
> I would even use a running Geonetwork for metadata, if I understand well
> there are two ways:
> one is to use my geonetwork as metadata repository. for this I should set
> it up in the local_setting.py file
> or second insert it as external CSW service.
> Am I correct?
> Thanks for any kind hints you would give me.
> Best
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150921/959c4387/attachment.html>
More information about the geonode-users mailing list
