[GeoNode-users] Simplest way to get Geogig working with Geonode?
Dave Kennewell davekennewell at gmail.com
Mon Sep 21 17:17:31 PDT 2015
Hi Geonoders,
I am exploring the potential to use Geogig as a version control system for
our hydrologic/hydraulic models stored in geonode. These models are
essentially a collection of shape and csv files (the computational engine
sits outside, and connects directly to PostGIS to run).
Is it easier to
1) spin up a geonode 2.4beta instance, and then manually install geogig
(and geoserver extensions?) on that server.
OR
2) spin up a GeoShape instance with the maploom backend that appears to
have a Geogig GUI, but i'm not sure if I still have to configure geoserver
etc if I follow this path?
At this stage, I don't need the long-term or most robust solution, but I
need the easiest solution so we can explore what is possible with a
geogig/geonode combination in our workflow.
Thanks for any guidance you can share
cheers
Dave
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150922/aa5eed35/attachment.html>
More information about the geonode-users mailing list
