[GeoNode-users] problem to install geonode on a remote vm
Charles Cossé
ccosse at gmail.com
Wed Sep 23 08:12:35 PDT 2015
Hi, we have an issue running the latest GeoNode on a virtual server. From
our LAN we access via a 192.168 ip address. Externally we access via
another, real ip address. But when we access externally the image
thumbnails and layers fail to show because they are referencing the 192.168
address. Looking through the database ("maps_mapsnapshot" table) I found
that GeoNode had ingested the 192.168 address and was generating links from
there. I concluded that having 2 ips (one internal, one external) must
not be possible given what was happening. I don't see any way around it
and we're re-configuring our systems to use a single IP as a result.
Thanks,
Charles Cossé
Guyana Forestry Commission
Georgetown, Guyana
On Wed, Sep 23, 2015 at 10:02 AM, Giuseppe Ricci <peppepegasus at gmail.com>
wrote:
> Hi guys,
> I'm trying to install geonode on a virtual machine installed on Micrsoft
> Azure server.
> I followed this tutorial:
> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
> but when i give this command:
> sudo geonode-updateip localhost:4567
> I receive this errors:
> $ sudo geonode-updateip localhost:4567
> Replacing SITEURL value with 'localhost:4567' in
> /etc/geonode/local_settings.py ... done.
> Adding entry for 'localhost:4567' in
> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
> found to the printing whitelist.
> Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py
> ... 'localhost:4567' already found in ALLOWED_HOSTS list.
> * Restarting web server
> apache2
> AH00558: apache2: Could not reliably determine the server's fully qualified
> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
> suppress this message
> [ OK ]
> Finished processing 0 layers in 0.0 seconds.
> 0 Created layers
> 0 Updated layers
> 0 Failed layers
> 0.000000 seconds per layer
> At the adress localhost:4567 I receive the message:
> web page doesn't exist. ERR_CONNECTION_REFUSED.
> Can some one to help me?
> Thanks.
> Dott. Giuseppe Ricci
> Via B. Spaventa 6, Terlizzi
> Cel. 340 3059772
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/c86b59e9/attachment-0001.html>
More information about the geonode-users
