[GeoNode-users] Updatelayers duplicate entries on geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Sep 29 04:15:36 PDT 2015
Also you can add --remove-deleted to updatelayers to remove layers not
available anymore on geoserver
2015-09-29 13:13 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Eduardo, that happened because you renamed the layer on geoserver and
> geonode couldn't recognize it. You should use geonode to rename layers.
> 2015-09-29 13:07 GMT+02:00 Eduardo Pascoal <pascoal.egeo at gmail.com>:
>> Dear all,
>> *version*:
>> my geonode is the latest v*ersion 2.4.dev20150924162756*
>> *Scenario*:
>> I loaded one layer via geoserver and then update layers using 'python
>> manage.py updatelayers', Later on geoserver, i decide to rename that layer
>> and then i did updatelayers.
>> *Problem*:
>> After that, i went in my geonode and i found a duplicated entrie about
>> the same layer.
>> This is a issue that was open on
>> https://github.com/GeoNode/geonode/issues/540
>> and it already closed. Am i missing something?
>> Any suggestion would be great.
>> Thanks,
>> Regards,
>> Eduardo Pascoal
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/6695d0e9/attachment.html>
More information about the geonode-users
