[GeoNode-users] post-installation issues
Simone Dalmasso simone.dalmasso at gmail.com
Tue Sep 29 11:43:36 PDT 2015
ok then you can follow some tutorials like
https://www.safaribooksonline.com/blog/2014/11/18/intro-python-debugger/ to
inspect that state of the variables.
2015-09-29 18:13 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Actually I think I'm not using virtualenv.
> I cloned geonode directly in a directory.
> By the way I think I can debug from my geonode directory, isn't it?
> I think I installed ipdb correctly, maybe I miss the right commands
> to debug my settings.py file.
> Can you drive me into the geonode debug?
> Thank you
> E.
> From: simone.dalmasso at gmail.com
> Date: Tue, 29 Sep 2015 17:57:29 +0200
> Subject: Re: [GeoNode-users] post-installation issues
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Sorry, just use "pip install ipdb" in your virtualenv.
> Ipdb should be put in the code in your development environment so that you
> can test using python manage.py runserver with the same configurations that
> you have in productions.
> 2015-09-29 17:51 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> I have problems on using ipdb. I installed it by using easy_install,
> then I launched the python console: python manage.py shell
> after that I tried to import ipdb and ipdb.set_trace()
> but something went wrong:
> >>> import ipdb; ipdb.set_trace()
> Traceback (most recent call last):
>   File "<console>", line 1, in <module>
>   File
> "/usr/local/lib/python2.7/dist-packages/ipdb-0.8.1-py2.7.egg/ipdb/__init__.py",
> line 16, in <module>
>     from ipdb.__main__ import set_trace, post_mortem, pm, run, runcall,
> runeval, launch_ipdb_on_exception
>   File
> "/usr/local/lib/python2.7/dist-packages/ipdb-0.8.1-py2.7.egg/ipdb/__main__.py",
> line 27, in <module>
>     import IPython
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/__init__.py",
> line 47, in <module>
>     from .core.application import Application
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/core/application.py",
> line 24, in <module>
>     from IPython.core import release, crashhandler
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/core/crashhandler.py",
> line 28, in <module>
>     from IPython.core import ultratb
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/core/ultratb.py",
> line 116, in <module>
>     from IPython.utils import path as util_path
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/utils/path.py",
> line 19, in <module>
>     from IPython.utils.process import system
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/utils/process.py",
>     from ._process_posix import system, getoutput, arg_split, check_pid
>   File
> "/usr/local/lib/python2.7/dist-packages/ipython-4.0.0-py2.7.egg/IPython/utils/_process_posix.py",
>     import pexpect
> ImportError: No module named pexpect
> Something is still missing?
> E.
> Date: Tue, 29 Sep 2015 17:18:44 +0200
> To: frippe12573 at hotmail.com; geonode-users at lists.osgeo.org
> The list seems ok.
> You can try to install ipdb https://pypi.python.org/pypi/ipdb and add
> at line 264. then go one step down with "n" and see what's wrong there.
> You can access the variables and see which lookup fails at line 266. It can
> be either
> keys[-1]
> or
> settings.MAP_BASELAYERS[0]['source']
> For geoserver, it has an admin user that is used by geonode and no others
> should use it. For security reasons it is recommended to change it's
> credentials in settings and the geoserver users page. but normal
> administrators will always use their geonode accounts to access geoserver.
> 2015-09-29 16:55 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi,
> I had these lines:
> >>> from django.conf import settings
> [{'source': {'url': 'http://my_server_name/geoserver2/wms', 'restUrl':
> '/gs/rest', 'ptype': 'gxp_wmscsource'}}, {'group': 'background', 'args':
> ['No background'], 'visibility': False, 'source': {'ptype':
> 'gxp_olsource'}, 'fixed': True, 'type': 'OpenLayers.Layer'}, {'group':
> 'background', 'name': 'mapnik', 'visibility': False, 'source': {'ptype':
> 'gxp_osmsource'}, 'fixed': True, 'type': 'OpenLayers.Layer.OSM'},
> {'source': {'ptype': 'gxp_mapquestsource'}, 'group': 'background', 'name':
> 'osm', 'visibility': True}, {'source': {'ptype': 'gxp_mapquestsource'},
> 'group': 'background', 'name': 'naip', 'visibility': False}, {'source':
> {'ptype': 'gxp_bingsource'}, 'fixed': True, 'group': 'background', 'name':
> 'AerialWithLabels', 'visibility': False}, {'source': {'ptype':
> 'gxp_mapboxsource'}}]
> Is that correct?
> Regarding the second question, I see geoserver keeps the user from django,
> I don't understand if I have to change the user of geoserver in settings.py
> and local_settings.py, inserting the same of django, or I should modify
> something on geoserver, or nothing?
> Best
> E.
> Date: Tue, 29 Sep 2015 16:41:15 +0200
> Eugenio to debug you can open a python in your virtualenv with
> $ python manage.py shell
> then try to import the settings with
> then see how the MAP_BASELAYERS looks like with
> for the second question the answer is yes, geoserver shares the same users
> as geonode although it keeps a default admin password that you change both
> in the settings and the geoserver users page.
> 2015-09-29 16:37 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I completed the installation of geonode
> *vs 2.4.dev20150908094256,*I even solved the problem on geoserver and it
> seems to run well.
> I set a geoserver from my organization as external service and
> I'm able to see the layers available. I can see the map of the layer
> and I can use them to prepare maps.
> I tried also to upload a document, and even this function runs well.
> My main problem is on map saving, this operation gives me the 500 internal
> server error.
> By the way the map appears on the list of maps.
> Checking the db (postgres) I see in the maps table the new record,
> however from the map's list I cannot visualize such map, and a new error
> page
> with yellow narrow appears. This page contains many statements*,* these
> three lines
> give an hint on the possible problem:
> Exception Type: IndexError Exception Value:
> list index out of range
> Exception Location: /dati/geonode/geonode/utils.py in viewer_json, line
> 266
> This is my first issue, I got a suggestion (here in the mailing list) to
> debug by python
> console geonode, but unfortunately I don't know how to start.
> Suggestions?
> Another question, might be related to the previous problem, is on
> geoserver authentication:
> I didn't give any password during the installation, and in
> local_setting.py and setting.py
> I see that geoserver has the classical administrator credentials
> (admin,geoserver).
> However if I use the link to geoserver from the user context menu (in the
> geonode website)
> I see the geoserver home page already logged in, but the user logged is
> not admin,
> but the superuser of django. Is that right? Have I set th geoserver
> credential somewhere?
> Thanks for now,
> best regards
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/bc080ad7/attachment.html>
More information about the geonode-users mailing list
