[GeoNode-users] import SHP
Paolo Corti
pcorti at gmail.com
Wed Sep 30 08:32:39 PDT 2015
sorry, you need to make sure that also the user running the
updatelayers command has write permission on that directory.
p
On Wed, Sep 30, 2015 at 5:14 PM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Hi,
> /uploaded/ directory is owned by www-data (same group), and has 755 grants.
> I checked inside and I saw the shp file uploaded before.
> MEDIA_ROOT in settings.py is:
> MEDIA_ROOT = os.path.join(PROJECT_ROOT, "uploaded")
> whereas
> MEDIA_URL = "uploaded"
> Even geonode directory has the same credentials.
> E.
>> From: pcorti at gmail.com
>> Date: Wed, 30 Sep 2015 16:55:25 +0200
>> Subject: Re: [GeoNode-users] import SHP
>> To: frippe12573 at hotmail.com
>> CC: geonode-users at lists.osgeo.org
>> On Wed, Sep 30, 2015 at 4:05 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
>> wrote:
>> > Hi Paolo,
>> > I did what you suggest.
>> > The shp file has been uploaded correctly in the geoserver,
>> > however I got errors on updatelayers, as follow:
>> > $ python manage.py updatelayers
>> > Stopping process because --ignore-errors was not set and an error was
>> > found.
>> > Traceback (most recent call last):
>> > File "manage.py", line 28, in <module>
>> > execute_from_command_line(sys.argv)
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
>> > line 399, in execute_from_command_line
>> > utility.execute()
>> > File
>> > line 392, in execute
>> > self.fetch_command(subcommand).run_from_argv(self.argv)
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
>> > line 242, in run_from_argv
>> > self.execute(*args, **options.__dict__)
>> > File
>> > line 285, in execute
>> > output = self.handle(*args, **options)
>> > File
>> > "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py",
>> > line
>> > 108, in handle
>> > remove_deleted=remove_deleted)
>> > File "/dati/geonode/geonode/geoserver/helpers.py", line 445, in gs_slurp
>> > "bbox_y1": Decimal(resource.latlon_bbox[3])
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py",
>> > line 154, in get_or_create
>> > return self.get_queryset().get_or_create(**kwargs)
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py",
>> > line 341, in get_or_create
>> > return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>> > File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
>> > line 383, in get_or_create
>> > obj.save(force_insert=True, using=self.db)
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
>> > line 90, in save
>> > return super(PolymorphicModel, self).save(*args, **kwargs)
>> > File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
>> > line 545, in save
>> > force_update=force_update, update_fields=update_fields)
>> > line 582, in save_base
>> > update_fields=update_fields, raw=raw, using=using)
>> > File
>> > "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
>> > line
>> > 185, in send
>> > response = receiver(signal=self, sender=sender, **named)
>> > File "/dati/geonode/geonode/geoserver/signals.py", line 394, in
>> > geoserver_post_save
>> > create_thumbnail(instance, thumbnail_remote_url, thumbnail_create_url,
>> > ogc_client=http_client)
>> > File "/dati/geonode/geonode/layers/utils.py", line 676, in
>> > create_thumbnail
>> > instance.save_thumbnail(filename, image=image)
>> > File "/dati/geonode/geonode/base/models.py", line 564, in save_thumbnail
>> > with open(os.path.join(upload_path, filename), 'wb') as f:
>> > Exception: ('Failed to process reg2001_s_wgs84utm33', IOError(13,
>> > 'Permission denied'))
>> > From the last line, I guess, my problem is on permissions.
>> > Mybey something is missing on my config files....
>> > Where in particular?
>> > E.
>> make sure your web server has permission to write to the media
>> directory where the thumbnails are generated (set in MEDIA_ROOT in the
>> GeoNode settings file)
>> p
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users
