[GeoNode-users] geonode GetFeatureInfo custom Templates
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Sun Apr 24 01:32:09 PDT 2016
In geoexplorer map composer it is possible to set layer properties
display in html (that i want and it works) but in the layer app of
geonode i will continue to see only text. But the simple solution it is
good for my purpose.
Thanks
Carmine
Il 22/04/2016 20:50, Paolo Corti ha scritto:
> No, but GeoExplorer is not able to parse customized things in
> GeoServer templates such as an HTML <img> I believe.
> Therefore you would need to customize GeoExplorer in order to make it
> working, as you says at the end of your email.
> p
> On Fri, Apr 22, 2016 at 12:56 PM, Carmine Massarelli
> <carmine.massarelli at ba.irsa.cnr.it> wrote:
>> Dear all,
>> I use a GetFeatureInfo Templates
>> (http://docs.geoserver.org/latest/en/user/tutorials/GetFeatureInfo/index.html)
>> in my geonode because of I would like to show a picture and a hyperlink
>> after the click and the opening of the popup info window.
>> The templates works well in geoserver-openlayer preview
>> (http://localhost:8080/geoserver/geonode/wms?service=...=application/openlayers),
>> but not in geoexplorer (http://localhost/layers/geonode...).
>> Am I doing something wrong?
>> Is it possible to customize the Geoexplorer GetFeatureInfo Popup window
>> including the display of the content.ftl file?
>> Thanks
>> Carmine
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160424/8229410f/attachment.html>
More information about the geonode-users
