[GeoNode-users] Uploading Shapefile from QGIS
Giovani Fronza giovanifronza at gmail.com
Wed Aug 3 07:11:15 PDT 2016
Thank you Amadeo and Simone.
For the question of .prj, seems that just changing the extension .qpj to
.prj is doing the trick (tested on just one file...).
I've studied the .sld question and figured that QGis are using 1.1 version,
writing <se:> tags, while Geoserver works with 1.0 version, reading <sld:>
tags. I'll try the suggested plugins.
Just for spread, we are adapting geonode for academic purpose at Federal
University of ParanĂ¡, Brasil. We are interested in sharing methodologies
besides the documents resulting from academic research.
Have a look at www.idea.ufpr.br.
Could you indicate someone who is dealing with the WPS on GeoNode?
Thanks again!
2016-08-02 17:26 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi, the changes you want to do are very challenging. I can't address you
> to specific chunks of ode but at least to three geonode apps, "geoserver",
> "layers" and "upload". They do that work.
> good luck.
> 2016-08-02 10:22 GMT+02:00 Amedeo Fadini <fame at libero.it>:
>> Hello
>> 2016-07-28 19:08 GMT+02:00 Giovani Fronza <giovanifronza at gmail.com>:
>> > I would like to do some improvements on my GeoNode code, intending to
>> > minimise problems uploading data produced by QGis users.
>> > 1- The .prj file dont have EPSG key. Instead, it should be possible
>> upload a
>> > .qpj file.
>> > 2- The .sld file loses their cofiguration almost every time.
>> > 3- All users should be allowed to upload .sld files.
>> > Is there any work around to any of these questions?
>> > Which source code files should change to achieve these goals?
>> AFAIK the sld stuff is  mostly managed by Geoserver. It will be very
>> difficult change the code to meet your expectations.
>> I think that is more efficient to use (and maybe contribute) to
>> geoserver explorer  plugin [0] and Opengeo explorer plugin [1] to
>> integrate Qgis and geonode.. have already tried them?
>> Amedeo Fadini
>> [0] https://plugins.qgis.org/plugins/geoserverexplorer/
>> [1] https://github.com/boundlessgeo/qgis-suite-plugin
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160803/8f5a4468/attachment.html>
More information about the geonode-users mailing list
