[GeoNode-users] google api policy
Paolo Corti
pcorti at gmail.com
Fri Aug 5 14:12:33 PDT 2016
Thanks Giovani
could you send a PR, including some documentation (must be added here:
https://github.com/GeoNode/geonode/blob/master/docs/reference/developers/settings.txt)?
thanks a lot
p
On Fri, Aug 5, 2016 at 9:41 PM, Giovani Fronza <giovanifronza at gmail.com> wrote:
> I did it today, motivated by these toppics in the list.
> I've put these code on my settings.py:
> # A Google Maps API key is needed for the 3D Google Earth view of maps
> # See http://code.google.com/apis/maps/signup.html
> GOOGLE_API_KEY = '<your key rehe>'
> try:
> GOOGLE_LAYER_SAT = {
> "source": {
> "ptype": "gxp_googlesource",
> "apiKey": GOOGLE_API_KEY
> "name": "SATELLITE",
> "fixed": True,
> "visibility": False,
> "group": "background"
> MAP_BASELAYERS.append(GOOGLE_LAYER_SAT)
> except GoogleAPIError:
> print "Not enabling Google Maps base layer as a GOOGLE_API_KEY is not
> defined in settings.py file."
> You could even change name "SATELLITE" by ROADMAP, HYBRID, or TERRAIN.
> After changes, restart your apache to make efect.
> 2016-08-05 15:14 GMT-03:00 Charles Cossé <ccosse at gmail.com>:
>> Shouldn't it go in site_base.html? as a Javascript include?
>> -Charles
>> On Aug 5, 2016 5:47 AM, "István Szőcs" <borohoro at gmail.com> wrote:
>>> Hello !
>>> Thank you for clearing that out. I have put the key in the file.
>>> Do you know if there's a time frame until a new key becomes active ?
>>> Because it's still not loading the google layers.
>>> And I know that this is a geonode forum, please forgive me, but perhaps
>>> somebody knows the same thing for an Opengeo Suite install (on Windows) ?
>>> I couldn't find the file where to insert the key, of course
>>> local_settings.py is not present over there.
>>> So what would be the equivalent file in which to insert the key on an
>>> Opengeo Suite installation ?
>>> kind regards,
>>> István
>>> On Thu, Aug 4, 2016 at 12:48 PM, Amedeo Fadini <amefad at gmail.com> wrote:
>>>> Hello,
>>>> Il 04/ago/2016 10:08 AM, "István Szőcs" <borohoro at gmail.com> ha scritto:
>>>> > Hello !
>>>> > Can somebody please tell me where to insert this key, in which file
>>>> > on the server ?
>>>> Quite simple: in /etc/geonode/local_settings.py
>>>> see also
>>>> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html
>>>> amedeo
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
