[GeoNode-users] google api policy
Amedeo Fadini
amefad at gmail.com
Tue Aug 9 03:47:17 PDT 2016
2016-08-09 12:04 GMT+02:00 István Szőcs <borohoro at gmail.com>:
> Hello !
> Thank you for the links. I believe I've done everything that says in the
> documentation, also as Giovani pointed out but I still can't get it working.
> I've tried with more API keys too.
> Please have a look at my settings.py and local_settings.py over here:
I see in lines 86-88
# A Google Maps API key is needed for the 3D Google Earth view of maps
# See http://code.google.com/apis/maps/signup.html
GOOGLE_API_KEY = ''
Altough the assignment in line 103 should overwrite it, please fill
the variable on that line.
Are you able to load the google layers using "Add layer.. " button on
map composer?
Amedeo
More information about the geonode-users
