[GeoNode-users] Customize GeoNode from the ubuntu package downloaded with sudo apt-get
Kevin Côté Kevin.Cote2 at USherbrooke.ca
Wed Aug 24 07:49:00 PDT 2016
Hi Simone,
I used 2.4 instead of master but I get the same error when doing the
collectstatic command...
Le 2016-08-24 10:34, Simone Dalmasso a écrit :
> Hi Kevin,
> try using the 2.4 branch of the project
> 3. Enter the created directory and performed "django-admin.py startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/2.4.zip [1] -epy,rst"
> 2016-08-24 16:21 GMT+02:00 Kevin Côté <Kevin.Cote2 at usherbrooke.ca>:
> Hi Francesco,
> I run into an error when I try to do "python manage.py collectstatic". I get:
> "OSError: [Errno 2] No such file or directory: '/usr/local/lib/python2.7/dist-packages/geonode/static'".
> I have proceeded this way:
> 1. Install Geonode from "sudo apt-get"
> 2. Create a directory in my /home folder to host the customized project.
> 3. Enter the created directory and performed "django-admin.py startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/master.zip [2] -epy,rst"
> 4. "pip install -e ." in the project directory
> 5. "python manage.py syncdb"
> 6. changed the WSGIScriptAlias in the geonode.conf file to point to the wsgi.py in the project folder.
> 7. In the geonode.conf file, added a "DocumentRoot" line that points to my project folder and modified the <Directory> tag to point to the project folder as specified in the customize documentation.
> 8. Proceeded with "python manage.py collectatic" in the project folder. This gets me the error specified above.
> Do you know what I could have done wrong ?
> Thanks !
> Le 2016-08-23 17:23, Francesco Bartoli a écrit : Hi Kevin,
> absolutely, following the approach of geonode-project [1] you can customize even the systemwide geonode. Make sure to take the right branch corresponding to your version (I'm assuming you are on 2.4)
> Francesco
> [1] https://github.com/GeoNode/geonode-project/tree/master [3]
> Il giorno 23/ago/2016, alle ore 21:43, Kevin Côté <Kevin.Cote2 at USherbrooke.ca> ha scritto:
> Hi,
> Just wanted to know if it is possible to customize the GeoNode plateform when it has been automatically installed using the "sudo apt-get" method. If so, is the procedure similar to the one explained in the docs ?
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users [4]
Simone
Links:
[1] https://github.com/GeoNode/geonode-project/archive/2.4.zip
[2] https://github.com/GeoNode/geonode-project/archive/master.zip
[3] https://github.com/GeoNode/geonode-project/tree/master
[4] http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160824/e77cd3db/attachment.html>
More information about the geonode-users mailing list
