[GeoNode-users] Severe layer permissions problem
Benjamin Ducke benducke at fastmail.fm
Fri Aug 26 04:01:38 PDT 2016
On 26/08/16 11:51, Benjamin Ducke wrote:
> Hi Dan --
> On 26/08/16 11:52, Daniel Berry wrote:
>> Ben,
>> It appears that your GeoServer is not seeing the  GeoNode (Django)
>> sessionid. Did you configure the GeoNode Auth provider
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration.
Ok, so I followed the instructions in the
URL above, but unfortunately the problem
remains. Note that:
- On a stock Ubuntu install, the "web.xml"
config file is located in "/usr/share/geoserver/WEB-INF".
- GeoNode and Geoserver are running on the same host
  (so I set GEONODE_BASE_URL to localhost).
- The problem affects all layers (raster & vector).
Still, I think that this narrows it down.
There is definitely something going wrong
with the handshaking between GeoNode and
Geoserver. Within GeoNode, permissions
and user IDs are working, because I can
e.g. set metadata editing permissions and
they work as expected.
Cheers,
Ben
>> Geoserver uses the sessionid to initiate a request to GeoNode to verify
>> that the user is authorized to view the layer. If the layer is not
>> granted anonymous access GeoServer will not expose the layer to the
>> user, which is why you are seeing pink tiles.
> Thanks for the pointer!
> I will check this. Most likely it is not
> configured (correctly).
> If there is still a problem then I will
> file a proper bug report.
> Cheers!
> Ben
>> Dan
>> On Aug 26, 2016 08:39, "Jeffrey Johnson" <ortelius at gmail.com
>> <mailto:ortelius at gmail.com>> wrote:
>>     Benjamin, Can you file an issue for this in the issue tracker. One of
>>     us will try to replicate on a fresh instance.
>>     On Fri, Aug 26, 2016 at 12:17 AM, Benjamin Ducke
>>     <benducke at fastmail.fm <mailto:benducke at fastmail.fm>> wrote:
>>     > Dear All --
>>     > I have a layer permissions problem that
>>     > I cannot solve. The problem is that any
>>     > vector layer which is not set to visible to
>>     > "Anyone" cannot be viewed, not even by
>>     > the layer's owner. It will be shown
>>     > in the list of Layers if the user has
>>     > viewing permissions, but clicking on it
>>     > will produce just a pink box. The Geoserver
>>     > log contains error messages complaining
>>     > about a missing layer:
>>     > Caused by: org.geoserver.platform.ServiceException: geonode:gisws_orte
>>     > layer does not exist
>>     > However, the layer does definitely exist
>>     > and will be displayed if switched visible
>>     > for "Anyone".
>>     > This problem occurs with PostGIS-stored
>>     > layers on a fresh installation of
>>     > GeoNode 2.4.1 (official Ubuntu packages),
>>     > with data migrated from a 2.0 install
>>     > following these instructions:
>>     https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24
>>     <https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24>
>>     > Any hints would be very much appreciated.
>>     > Cheers,
>>     > Ben
>>     > _______________________________________________
>>     > geonode-users mailing list
>>     > geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>     > http://lists.osgeo.org/mailman/listinfo/geonode-users
>>     <http://lists.osgeo.org/mailman/listinfo/geonode-users>
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
More information about the geonode-users mailing list
