[GeoNode-users] Use of Existing registered users in Geonode
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Dec 13 07:12:53 PST 2016
You will be able to assign permissions to the migrated users, yes.
For loading the users, just copy the table or from and existing table, for
the password encryption see the django docs
https://docs.djangoproject.com/en/1.8/topics/auth/passwords/#how-django-stores-passwords
I did not understand our last question.. Do you want GeoNode to use a
different authentication database? I that case it might be possible but
you'll have to dig more into the django docs.
Hope this helps
2016-12-13 11:59 GMT+01:00 Naresh N <naresh919 at gmail.com>:
> Hi Simone,
> Thanks a lot for quick response. Please help in following
> 1. If we insert our existing user database using some code to
> people_profile, will all the functionalities like sharing,permissions and
> other activities will work as expected ( like if the user registered with
> GeoNode Register page).
> 2. Inserted one row into People_profile for testing by using following
> syntax.
> INSERT INTO people_profile(
> id, password, is_superuser, last_login,username,first_name,last_name,
> email, is_active,is_staff,date_joined)
> VALUES (5,md5('bhuvan'),FALSE,now(),'NARESHtest','nagammalle','
> naresh','nareshkgp at yahoo.com',TRUE,FALSE,now());
> Password field filled with md5 option. Is it correct? . After this I have
> tried to logging with the details given in above query it is showing wrong
> usename/password. what algorithm is used for while storing passwords in
> the database?
> 3. Is it possible to link our existing Sign-in, Sign-up pages in GeoNode
> environment. When ever user will sign -in/Sign -up authentication will be
> happen separately and some authorized code can be passed to GeoNode setup
> for further functionality mean for registered user list can be saved in
> other existing our database(not the default database which will come with
> GeoNode).
> Thanks,
> Naresh
> On Tue, Dec 13, 2016 at 1:27 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi,
>> you could copy the people_profile table from one database to the other.
>> 2016-12-13 7:53 GMT+01:00 Naresh N <naresh919 at gmail.com>:
>>> Dear GeoNode Users,
>>> We have multiple web gis applications and using single-sign on method
>>> for logins.We have around 5 lakh registered users for our portal. We have
>>> deployed Geonode in our Environment.How do we make all existing our earlier
>>> registered users should able login GeoNode without registering again.
>>> Please guide me to do the task. Please let me know more information
>>> required to understand the task.
>>> Thanks&Regards,
>>> Naresh
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161213/271a16d3/attachment-0001.html>
More information about the geonode-users
