[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso simone.dalmasso at gmail.com
Mon Dec 19 06:03:21 PST 2016
Exactly, one virtualhost for each site.
2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Ok,
> I will proceed this way.
> Then I have to create a new virtualhost pointing to the wsgi.py within the
> new site dir, right?
> In the same virtual host have I to set new aliases for uploaded dir and
> static_root as I did for the normal installation?
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 19 dicembre 2016 14.21
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> I suggest you to go manually and create a site folder copying the
> site_template, rename and add the Site object into the database.
> geosites has not been revised for a while and geonode improved. It works
> but the shortcut command addsite may be broken.
> 2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone,
>> I did what you suggested, actually now I have the addsite command, but as
>> you announced I have also this error:
>> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
>> then I added SITE_ROOT in local_setting.py inserting the path
>> "geonode/contrib/geosites"
>> afterwords I had this error:
>> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
>> so that I added SERVE_PATH in local_setting.py inserting the path "
>> geonode/contrib/geosites/static"
>> but I'm not sure I did the right thing, since now I have this error:
>> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib/site2'
>> Where I'm wrong?
>> Thanks
>> Eugenio
>> *Inviato:* lunedì 19 dicembre 2016 11.04
>> *A:* Eugenio Trumpy
>> you have to add it in INSTALLED_APPS, currently it is only listed in the
>> contrib apps.
>> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Simone,
>>> and thank you for your answer.
>>> Sorry for my trivial question:
>>> in my setting.py I have already geonode.contrib.geosites
>>> in GEONODE_CONTRIB_APPS, see below:
>>> GEONODE_CONTRIB_APPS = (
>>>     # GeoNode Contrib Apps
>>>     'geonode.contrib.dynamic',
>>>     'geonode.contrib.exif',
>>>     'geonode.contrib.favorite',
>>>     'geonode.contrib.geogig',
>>>     'geonode.contrib.geosites',
>>>     'geonode.contrib.nlp',
>>>     'geonode.contrib.slack'
>>> in INSTALLED_APPS I have:
>>> INSTALLED_APPS = (
>>>     # Boostrap admin theme
>>>     # 'django_admin_bootstrapped.bootstrap3',
>>>     # 'django_admin_bootstrapped',
>>>     # Apps bundled with Django
>>>     'django.contrib.auth',
>>>     'django.contrib.contenttypes',
>>>     'django.contrib.sessions',
>>>     'django.contrib.sites',
>>>     'django.contrib.admin',
>>>     'django.contrib.sitemaps',
>>>     'django.contrib.staticfiles',
>>>     'django.contrib.messages',
>>>     'django.contrib.humanize',
>>>     'django.contrib.gis',
>>>     # Third party apps
>>>     # Utility
>>>     'pagination',
>>>     'taggit',
>>>     'friendlytagloader',
>>>     'geoexplorer',
>>>     'leaflet',
>>>     'django_extensions',
>>>     # 'haystack',
>>> ....and others...
>>> Should I insert geonode.contrib.geosites somewhere in local_setting? or
>>> it's already ok as it? or copy geonode.contrib.geosites in settings.py
>>> under INSTALLED_APPS?
>>> Sorry again for this banal question...
>>> E.
>>> *Inviato:* lunedì 19 dicembre 2016 09.04
>>> *A:* Eugenio Trumpy
>>> Ciao Eugenio,
>>> sorry for being so late in the response.
>>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS in
>>> order to get the command.
>>> In case you get errors in running that command, you can always 'make' a
>>> geosite by yourself by copying the folder 'site_template' and changing it's
>>> name and internal parameters and then register the new Site in the admin
>>> panel. You can follow the utils.py add_site function and replicate the
>>> needed steps (some of them are only for production).
>>> Take also some time to see how the pre and post settings work.
>>> Hope this helps
>>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi everyone,
>>>> regarding the multi-tenancy setting up and in particular the
>>>> installation of new site since the command:
>>>> python manage.py addsite sitename sitedomain
>>>> return me:
>>>> Unknown command: 'addsite'
>>>> Type 'manage.py help' for usage.
>>>> Do you know way? Have I 'activate' in some way the multi-tenancy
>>>> before? or it is ready to use?
>>>> If it is ready to use, why 'addsite' is an unknown command?
>>>> I launched the command from the main geonode directory, am I right?
>>>> As I wrote in the previous email in my installation I have only
>>>> manage.py file in
>>>> /geonode directory.
>>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>>> 2.4.dev20151029170512.
>>>> I installed geonode as custom installation (not by apt-get).
>>>> Thanks
>>>> Eugenio
>>>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>>> *A:* geonode-users at lists.osgeo.org
>>>> *Oggetto:* Multi-Tenancy: how to start
>>>> Hi all,
>>>> as pointed in the email object I want to try the geonode multi-tenancy
>>>> capabilities.
>>>> I started of course from the documentation [1] and [2], but a need some
>>>> hints to start.
>>>> I have already a running geonode instance. Do you think I should start
>>>> from
>>>> a clean geonode installation or I can arrange the running one?
>>>> Is there somewhere a set of commands to setup the geosite 1, geosite 2,
>>>> I was looking into geosites folder, as suggested in [2], but I don't
>>>> see neither manage.py nor manage_all.py files.
>>>> I tried python manage.py addsite geosite1 geosite1domain
>>>> but I got Unknown command: 'addsite'
>>>> Am I missing something?
>>>> After that: How can I sort out the already stored layers?
>>>> Thank you very much for hints and for the patience of this
>>>> stupid questions,
>>>> Eugenio
>>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>>> lti-tenancy.html
>>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>>> ontrib/geosites
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161219/05ea57d3/attachment-0001.html>
More information about the geonode-users mailing list
