[GeoNode-users] Geoserver can't see changes
Rosario Peña roelpeag at gmail.com
Mon Feb 1 06:40:59 PST 2016
Hi, the error.log don't give me error when I delete a layer or when add a
new remote service, but if I make a change in the geonode, the geoserver
don´t update the changes
2016-01-28 15:49 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> This log is too big, maybe take a look at the apache log with
> $ tail -f  /var/log/apache2/error.log
> do a delete and see only the part that is generated with that operation.
> 2016-01-28 19:42 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>> This is the log that was generate in the moment of delete a layer, but
>> that layer yet is in geoserver.
>> 2016-01-28 12:00 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Sorry but 10 MB is too heavy for me and my connection is not very strong
>>> where I am now. Try to catch only the relevant part. PS please keep posting
>>> to the list.
>>> 2016-01-28 16:23 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>> I saw the log but isn't very clear for me. Anyway , I attached the log.
>>>> 2016-01-28 9:19 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> If you delete in geonode, which has been uploaded via geonode, then it
>>>>> should be removed from geoserver as well. I case check the geoserver logs
>>>>> when this error occurs.
>>>>> 2016-01-28 15:07 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>> Great, it's work :D
>>>>>> Another error is that Geoserver not take the changes made in the
>>>>>> Geonode. Any idea why???
>>>>>> 2016-01-28 8:36 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> Ok that is an issue of the old releases, but is not the issue we are
>>>>>>> looking for.
>>>>>>> You can solve this with:
>>>>>>> $ sudo chown -R www-data /var/www/geonode/
>>>>>>> 2016-01-28 14:31 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>>>> I mean editing metada of layers WMS. I started Django in debug mode
>>>>>>>> and verbose logging in Geoserver and I get a error: "Permission denied save
>>>>>>>> thumbnail"
>>>>>>>> 2016-01-28 8:05 GMT-05:00 Simone Dalmasso <
>>>>>>>>> I see,
>>>>>>>>> we released the stable version last November, which is available
>>>>>>>>> on ppa:geonode/stable.
>>>>>>>>> Anyway, in order to understand your issue we need more
>>>>>>>>> information, what do you mean by editing wms cascade?
>>>>>>>>> Also in geoserver you can find the log page, it would be good if
>>>>>>>>> you could check for errors there.
>>>>>>>>> 2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>>>>>> Hi
>>>>>>>>>> Geonode I not installed, but with these steps was installed:
>>>>>>>>>> *Install from PPA in Ubuntu 14.04*
>>>>>>>>>> $ sudo add-apt-repository ppa:geonode/testing
>>>>>>>>>> $ sudo apt-get update
>>>>>>>>>> $ sudo apt-get install geonode
>>>>>>>>>> Set the IP address and create a superuser
>>>>>>>>>> $ sudo geonode-updateip 127.0.0.1
>>>>>>>>>> $ geonode createsuperuser
>>>>>>>>>> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <
>>>>>>>>>>> Hi. How did you install geonode? Take look at the geoserver and
>>>>>>>>>>> Apache logs they will give you more info.
>>>>>>>>>>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com>
>>>>>>>>>>> ha scritto:
>>>>>>>>>>>> The geoserver can't see the changes did in the geonode, if I
>>>>>>>>>>>> delete a layer, this layer remains in the geoserver and I can't  edit the
>>>>>>>>>>>> layers WMS cascade because I get a Internal Server Error.
>>>>>>>>>>> Simone
>>>>>>>>>> Ing. Rosario Peña
>>>>>>>>> Simone
>>>>>>>> Ing. Rosario Peña
>>>>>>> Simone
>>>>>> Ing. Rosario Peña
>>>>> Simone
>>>> Ing. Rosario Peña
>>> Simone
>> Ing. Rosario Peña
> Simone
Ing. Rosario Peña
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160201/8b1cdaed/attachment.html>
More information about the geonode-users mailing list
