[GeoNode-users] Migration of data from 2.0 to 2.4
Mana Etches
manadotcom at gmail.com
Wed Feb 10 19:14:59 PST 2016
Hi Paolo,
I finally figured it out.
I basically deleted all the workspaces layers directories that was migrated
from 2.0. Ran 'create_auth_group_and_update_res.py' again and now all the
layers are appearing and working on GUI interface.
I wish I can cheers you a beer to express my appreciation and thanks for
your help. Maybe one day.
Take care,
Mana
On Thu, Feb 11, 2016 at 10:53 AM, Mana Etches <manadotcom at gmail.com> wrote:
> Hi Paolo,
> Firstly, thanks for your help on this. We're getting closer and closer to
> resolving the problem.
> I found out what part of the problem was, nearly half of the data from GS
> 2.0 directory (layers and geotiffs) was missing in my GS 2.4 data
> directory. After reuploading and running 'geonode udatelayers', the layers
> updated successfully without any errors in geoserver logs. When logged in
> as admin, I can see the layers in GeoNode and GeoServer 'now all enabled'.
> However, when I executed 'python create_auth_group_and_update_res.py',
> this is within migrate2.sh, I see 2 main errors:
> 1. <class 'geoserver.catalog.FailedRequestError'> for all layers
> *Eg: Geoserver log error shows* - Caused by:
> java.io.FileNotFoundException:
> /usr/share/geoserver/data/workspaces/geonode/tuv_10_500t/tuv_10_500t/coverage.xml.7dee7b3e-b96b-4c26-ae3a-7ea615dbabbb.tmp
> (Permission denied)
> 2. <class 'geonode.layers.models.DoesNotExist'> for all layers.
> Lastly, if I click on a layer in Geonode's GUI, nothing happens it seems
> like the page gets refreshed, and no errors appear in the geoserver log.
> It looks like the first error is caused by a permissions issue relative to
> an xml files within my workspaces directory. Would you have some idea how
> to remedy this?
> Many thanks again Paolo
> On Thu, Feb 11, 2016 at 4:54 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> Yes, it looks like a configuration problem with GeoServer.
>> After GeoServer data migration, and even before running migrate2.sh,
>> you should already see all the layers in GeoNode and GeoServer admin if
>> logged as superuser.
>> migrate2.sh just takes care of permissions, tags and regions if I
>> remember correctly.
>> Does GeoServer log say anything when updatelayers raises <class
>> 'geoserver.catalog.FailedRequestError'> ?
>> p
>> On Tue, Feb 9, 2016 at 4:46 PM, Mana Etches <manadotcom at gmail.com> wrote:
>> > Hi Paolo,
>> > We are getting somewhere,
>> > I set 'settings_path = geonode.settings, then ran the
>> > create_auth_group_and_update_res.py, I got the following results:
>> > Creating the authenticated group...
>> > Now adding all users to the group...
>> > Adding geonode to the group
>> > Adding admin to the group
>> > Adding joyp to the group
>> > Adding liteab to the group
>> > Adding amritr to the group
>> > Adding susanv to the group
>> > Adding mereonik to the group
>> > Adding sachin to the group
>> > Adding Brookey to the group
>> > Adding Faatasim to the group
>> > Adding digitaki to the group
>> > Adding david to the group
>> > Adding norense to the group
>> > Adding zarin to the group
>> > Adding sereima to the group
>> > Adding fane to the group
>> > Adding keleni to the group
>> > Adding philb to the group
>> > Adding Keikos to the group
>> > Adding keikos to the group
>> > Adding Lawrence to the group
>> > Adding seelan to the group
>> > Adding test to the group
>> > Adding Lowry to the group
>> > Adding mana to the group
>> > Updating resources...
>> > Updating layer NU_Surface_Soil
>> > Updating layer WS_TC_HazardMap Wind 100 MRP
>> > Updating layer PW_Point_Building_Exposure_Verified
>> > Updating layer NR_EQ_HazardMap_10_2500 MRP
>> > Updating layer PW_EQ_HazardMap_10_2500 MRP
>> > Updating layer NU_TC_HazardMap Wind 100 MRP
>> > Updating layer VU_Area_Council
>> > Updating layer
>> VU_Average_Annual_Loss_for_Tropical_Cyclone_and_Earthquake
>> > Updating layer PG_lae2_sub2.tif
>> > Updating layer TO_EQ_HazardMap_PGA_100 MRP
>> > Updating layer PW_Landuse Landcover
>> > Updating layer PG_lae2_sub1.tif
>> > Updating layer WS_EQ_HazardMap_PGA_2500 MRP
>> > Updating layer FJ_Roads
>> > Updating layer SB_munda_gsd05_o_sub2.tif
>> > Updating layer TL_EQ_HazardMap_PGA_100 MRP
>> > Updating layer TO_Roads
>> > Updating layer MH_Landuse Landcover
>> > Updating layer SB_EQ_HazardMap_10_100_MRP
>> > Updating layer CK_Point_Building_Exposure_Modelled
>> > Updating layer WS_Roads
>> > Updating layer PW_EQ_HazardMap_03_2500 MRP
>> > Updating layer SB_EQ_HazardMap_PGA_500_MRP
>> > Updating layer TL_EQ_HazardMap_PGA_2500_MRP
>> > Updating map Fiji
>> > Updating layer TL_EQ_HazardMap_10_2500 MRP
>> > Updating layer VU_EQ_HazardMap_10_500 MRP
>> > Updating layer TL_EQ_HazardMap_10_500 MRP
>> > Updating layer NR_TC_HazardMap Wind 500 MRP
>> > Updating layer VU_TC_HazardMap Wind 250 MRP
>> > Updating layer SB_westguale_sub6.tif
>> > Updating layer NU_EQ_HazardMap_10_100 MRP
>> > Updating layer PG_EQ_HazardMap_03_500 MRP
>> > Updating layer TL_Landuse Landcover
>> > Updating layer MH_Atoll
>> > Updating layer SB_EQ_HazardMap_10_500_MRP
>> > Updating layer CK_Point_Building_Exposure_Verified
>> > Updating layer KI_EQ_HazardMap_10_100 MRP
>> > Updating map
>> > Updating layer KI_Island
>> > Updating layer VU_ambae.tif
>> > Updating layer TO_Building_Aggregate_Exposure
>> > Updating layer FJ_Buildings
>> > Updating layer VU_tanna2.tif
>> > Updating layer TO_Average_Annual_Loss
>> > Updating layer KI_Surface_Soil_Pt14
>> > Updating layer CK_Enumeration_Area
>> > Updating layer TV_Roads
>> > Updating layer NR_District
>> > Updating layer VU_Point_Building_Exposure_Verified
>> > Updating layer TO_Surface_Soil
>> > Updating layer VU_Landuse Landcover
>> > Updating layer PG_lae1.tif
>> > Updating layer FM_Point_Building_Exposure_Modelled
>> > Updating layer CK_Rarotonga_Satellite_Image_2009
>> > Updating layer TO_EQ_HazardMap_03_100 MRP
>> > Updating layer FJ_EQ_HazardMap_PGA_500_MRP
>> > Updating layer PW_Hamlet
>> > Updating layer TV_EQ_HazardMap_03_100 MRP
>> > Updating layer KI_TC_HazardMap Wind 100 MRP_West
>> > Updating layer CK_Island
>> > Updating layer TV_EQ_HazardMap_PGA_2500_MRP
>> > Updating layer SB_Roads
>> > Updating layer
>> FJ_Average_Annual_Loss_For_Tropical_Cyclone_and_Earthquakes
>> > Updating layer PG_madang_s.tif
>> > Updating layer TV_TC_HazardMap Wind 250 MRP
>> > Updating layer PW_EQ_HazardMap_03_100 MRP
>> > Updating layer TV_TC_HazardMap Wind 500 MRP
>> > Updating layer MH_EQ_HazardMap_10_500 MRP
>> > Updating layer PG_Bridges
>> > Updating layer NR_EQ_HazardMap_10_500 MRP
>> > Updating layer TV_Building_Aggregate_Exposure
>> > Updating layer PW_EQ_HazardMap_10_100 MRP
>> > Updating layer FJ_EQ_HazardMap_10_2500 MRP
>> > Updating layer PG_EQ_HazardMap_10_100 MRP
>> > Updating layer PG_EQ_HazardMap_03_2500 MRP
>> > Updating layer TV_EQ_HazardMap_PGA_500 MRP
>> > Updating layer TL_TC_HazardMap Wind 500 MRP
>> > Updating layer PW_Point_Building_Exposure_Modelled
>> > Updating layer TV_EQ_HazardMap_PGA_100 MRP
>> > Updating layer PG_TC_HazardMap Wind 100 MRP
>> > Updating layer NU_EQ_HazardMap_10_2500 MRP
>> > Updating layer TO_EQ_HazardMap_10_2500 MRP
>> > Updating layer TV_Point_Building_Exposure_Modelled
>> > Updating layer FM_TC_HazardMap Wind 50 MRP
>> > Updating layer TO_b4.tif
>> > Updating layer TV_Point_Building_Exposure_Verified
>> > Updating layer FJ_8C
>> > Updating layer TO_d2.tif
>> > Updating layer WS_Point_Building_Exposure_Verified
>> > Updating layer SB_Kolombangara_sub2
>> > Updating layer VU_Surface_Soil
>> > Updating layer WS_Surface_Soil
>> > Updating layer SB_Auki_Satellite_Imagery_2005_s2
>> > Updating layer SB_Honiara_Satellite_Imagery_2005_s1
>> > Updating layer SB_EQ_HazardMap_03_500 MRP
>> > Updating layer PG_Census_Unit
>> > Updating layer WS_Building_Aggregate_Exposure
>> > Updating layer TO_Landuse Landcover
>> > Updating layer FM_EQ_HazardMap_03_100 MRP
>> > Updating layer VU_Point_Building_Exposure_Modelled
>> > Updating layer FM_EQ_HazardMap_10_500 MRP
>> > Updating layer SB_Gizo_Satellite_Imagery_2005_s1
>> > Updating layer NR_EQ_HazardMap_10_100 MRP
>> > Updating layer SB_Honiara_Satellite_Imagery_2005_s2
>> > Updating layer FJ_nadi_s1.tif
>> > Updating layer TV_EQ_HazardMap_03_2500 MRP
>> > Updating layer TV_Island
>> > Updating layer NU_EQ_HazardMap_03_2500 MRP
>> > Updating layer KI_Surface_Soil_Pt13
>> > Updating layer FJ_Coastline
>> > Updating layer PG_TC_HazardMap Wind 500 MRP
>> > Updating layer SB_rannogga_2.tif
>> > Updating layer VU_EQ_HazardMap_PGA_100 MRP
>> > Updating layer PW_Surface_Soil
>> > Updating layer TO_a2.tif
>> > Updating layer TO_b3.tif
>> > Updating layer FJ_Special_Infrastructure
>> > Updating layer FM_EQ_HazardMap_10_2500 MRP
>> > Updating layer KI_Surface_Soil_Pt11
>> > Updating layer FJ_Specials
>> > Updating layer WS_EQ_HazardMap_03_500 MRP
>> > Updating layer KI_Surface_Soil_Pt12
>> > Updating map Yasawa Group
>> > Updating map Vanuatu
>> > Updating document NU_Country_Profile
>> > Updating document
>> > Advancing_Disaster_Risk_Financing&Insurance_In_The_Pacific.pdf
>> > Updating document VU_Country_Profile
>> > Updating document Country Note THE COOK ISLANDS
>> > Updating document Country Note Fiji
>> > Updating document PG_Country_Profile
>> > Updating document FM_Country_Profile
>> > Updating document CATASTROPHE RISK ASSESSMENT METHODOLOGY
>> > Updating document PW_Country_Profile
>> > Updating document KI_Country_Profile
>> > Updating document Country Note Solomon Islands
>> > Updating document Country Note Marshall Islands
>> > Updating document Country_Note_Vanuatu
>> > Updating document TO_Country_Profile
>> > Updating document Solomon Islands Country Profile
>> > Updating document PCRAFI_Risk_Assessment_Methodology
>> > Updating document Country_Note_Tonga
>> > Updating document MH_Country_Profile
>> > Updating document WS_Country_Profile
>> > Updating document Country-Note-Samoa
>> > Updating document TL_Country_Profile
>> > Updating document NR_Country_Profile
>> > Updating document FJ_Country_Profile
>> > Updating document CK_Country_Profile
>> > Updating document TV_Country_Profile
>> > Updating document Country Note: Samoa; Disaster risk financing and
>> > insurance, February 2015
>> > Updating document Country Note: Tonga; Disaster risk financing and
>> > Updating document Country Note: Cook Islands; Disaster risk financing
>> and
>> > Updating document Country Note: Vanuatu; Disaster risk financing and
>> > Updating layer ck_evacuation_centers
>> > GDAL_ERROR 4: Unable to open
>> > /var/www/geonode/uploaded/layers/ck_evacuation_centers.shp or
>> > /var/www/geonode/uploaded/layers/ck_evacuation_centers.SHP.
>> > Could not open
>> > <type 'exceptions.AssertionError'>
>> > Updating layer rarotonga_electoral_boundaries
>> > /var/www/geonode/uploaded/layers/rarotonga_electoral_boundaries.shp or
>> > /var/www/geonode/uploaded/layers/rarotonga_electoral_boundaries.SHP.
>> > Could not open
>> > Updating layer mangaia_electoral_boundaries
>> > /var/www/geonode/uploaded/layers/mangaia_electoral_boundaries.shp or
>> > /var/www/geonode/uploaded/layers/mangaia_electoral_boundaries.SHP.
>> > Could not open
>> > Updating layer aitutaki_electoral_boundaries
>> > /var/www/geonode/uploaded/layers/aitutaki_electoral_boundaries.shp or
>> > /var/www/geonode/uploaded/layers/aitutaki_electoral_boundaries.SHP.
>> > Could not open
>> > I checked the layers in GUI of geonode and none of my migrate layers
>> appear.
>> > I checked the documents link, I see the meta data and links but I get an
>> > internal error 500 when I try to download.
>> > It looks like the clue we've got is <class
>> > 'geoserver.catalog.FailedRequestError'>. This looks like a geoserver
>> > configuration issue then, would you have some idea which configuration
>> file
>> > specifically. Is it contained within my Geoserver Directory? or
>> elsewhere.
>> > Mana
>> > On Wed, Feb 10, 2016 at 10:14 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> >> Yes, I think that you need to fix the first error to have the
>> >> migration working properly.
>> >> Don't worry about the second error: you are getting IntegrityError as
>> >> the records were already added to the database when you ran the script
>> >> first time.
>> >> The third error is caused by the first one.
>> >> Let me know if you get more issues
>> >> p
>> >> On Tue, Feb 9, 2016 at 3:38 PM, Mana Etches <manadotcom at gmail.com>
>> wrote:
>> >> > Hi Paolo,
>> >> > Firstly, I should have ran the python scripts individually within
>> >> > migrate2.sh, I noticed some errors as follows:
>> >> > 'create_auth_group_and_update_res.py', reveals error:
>> >> > Traceback (most recent call last):
>> >> > File "create_auth_group_and_update_res.py", line 10, in <module>
>> >> > from geonode.groups.models import GroupProfile
>> >> > File
>> >> > "/usr/local/lib/python2.7/dist-packages/geonode/groups/models.py",
>> >> > line 5, in <module>
>> >> > from django.contrib.auth.models import Group
>> >> > File
>> >> > "/usr/lib/python2.7/dist-packages/django/contrib/auth/__init__.py",
>> >> > line 6, in <module>
>> >> > from django.middleware.csrf import rotate_token
>> >> > File "/usr/lib/python2.7/dist-packages/django/middleware/csrf.py",
>> >> > line
>> >> > 14, in <module>
>> >> > from django.utils.cache import patch_vary_headers
>> >> > File "/usr/lib/python2.7/dist-packages/django/utils/cache.py", line
>> >> > 26, in
>> >> > <module>
>> >> > from django.core.cache import get_cache
>> >> > File
>> "/usr/lib/python2.7/dist-packages/django/core/cache/__init__.py",
>> >> > line 69, in <module>
>> >> > if DEFAULT_CACHE_ALIAS not in settings.CACHES:
>> >> > File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py",
>> line
>> >> > 54,
>> >> > in __getattr__
>> >> > self._setup(name)
>> line
>> >> > 49,
>> >> > in _setup
>> >> > self._wrapped = Settings(settings_module)
>> line
>> >> > 132,
>> >> > in __init__
>> >> > % (self.SETTINGS_MODULE, e)
>> >> > ImportError: Could not import settings
>> '/etc/genode/local_settings.py'
>> >> > (Is
>> >> > it on sys.path? Is there an import error in the settings file?):
>> Import
>> >> > by
>> >> > filename is not supported.
>> >> > The second script, 'migrate_tags.py', ran errors for the first part
>> >> > relative
>> >> > to psycopg2.IntegrityError on my layers, eg:
>> >> > ('Municipality', 'municipality')
>> >> > <class 'psycopg2.IntegrityError'>
>> >> > duplicate key value violates unique constraint "taggit_tag_name_key"
>> >> > DETAIL: Key (name)=(Island) already exists.
>> >> > ('Island', 'island')
>> >> > DETAIL: Key (name)=(Atoll) already exists.
>> >> > ('Atoll', 'atoll')
>> >> > DETAIL: Key (name)=(nr) already exists.
>> >> > ('nr', 'nr')
>> >> > DETAIL: Key (name)=(District) already exists.
>> >> > ('District', 'district')
>> >> > DETAIL: Key (name)=(Village) already exists.
>> >> > ('Village', 'village')
>> >> > DETAIL: Key (name)=(Local Level Government) already exists.
>> >> > ('Local Level Government', 'local-level-government')
>> >> > DETAIL: Key (name)=(Building Replacement Cost) already exists.
>> >> > ('Building Replacement Cost', 'building-replacement-cost')
>> >> > DETAIL: Key (name)=(State) already exists.
>> >> > ('State', 'state')
>> >> > DETAIL: Key (name)=(Ward) already exists.
>> >> > ('Ward', 'ward')
>> >> > DETAIL: Key (name)=(Sub District) already exists.
>> >> > ('Sub District', 'sub-district')
>> >> > DETAIL: Key (name)=(Area Council) already exists.
>> >> > ('Area Council', 'area-council')
>> >> > DETAIL: Key (name)=(hazards) already exists.
>> >> > ('hazards', 'hazards')
>> >> > DETAIL: Key (name)=(Building Exposure Aggregates) already exists.
>> >> > ('Building Exposure Aggregates', 'building-exposure-aggregates')
>> >> > DETAIL: Key (name)=(nrj) already exists.
>> >> > ('nrj', 'nrj')
>> >> > DETAIL: Key (name)=(Land cover) already exists.
>> >> > ('Land cover', 'land-cover')
>> >> > DETAIL: Key (name)=(Land use) already exists.
>> >> > ('Land use', 'land-use')
>> >> > DETAIL: Key (name)=(Land Cover) already exists.
>> >> > ('Land Cover', 'land-cover_1')
>> >> > DETAIL: Key (name)=(Land Use) already exists.
>> >> > ('Land Use', 'land-use_1')
>> >> > DETAIL: Key (name)=(Average Annual Loss For TC & EQ) already exists.
>> >> > ('Average Annual Loss For TC & EQ', 'average-annual-loss-for-tc-eq')
>> >> > DETAIL: Key (name)=(Average Annual Loss) already exists.
>> >> > ('Average Annual Loss', 'average-annual-loss')
>> >> > DETAIL: Key (name)=(Building Replacement Costs) already exists.
>> >> > ('Building Replacement Costs', 'building-replacement-costs')
>> >> > DETAIL: Key (name)=(Exposure Cash Crops) already exists.
>> >> > ('Exposure Cash Crops', 'exposure-cash-crops')
>> >> > DETAIL: Key (name)=(imagery) already exists.
>> >> > ('imagery', 'imagery')
>> >> > DETAIL: Key (name)=(REQUIRED: Common-use word or phrase used to
>> >> > describe
>> >> > the subject of the data set.) already exists.
>> >> > ('REQUIRED: Common-use word or phrase used to describe the subject of
>> >> > the
>> >> > data set.',
>> 'required-common-use-word-or-phrase-used-to-describe-the-subject-of-the-data-set')
>> >> > DETAIL: Key (name)=(Average Annual Loss TC & EQ) already exists.
>> >> > ('Average Annual Loss TC & EQ', 'average-annual-loss-tc-eq')
>> >> > DETAIL: Key (name)=(Average Annual Loss for TC & EQ) already exists.
>> >> > ('Average Annual Loss for TC & EQ',
>> 'average-annual-loss-for-tc-eq_1')
>> >> > DETAIL: Key (name)=(Population) already exists.
>> >> > ('Population', 'population')
>> >> > DETAIL: Key (name)=(Average Annual Loss tc and eq) already exists.
>> >> > ('Average Annual Loss tc and eq', 'average-annual-loss-tc-and-eq')
>> >> > DETAIL: Key (name)=(Average Annual Loss for Tropical Cyclone and
>> >> > Earthquake) already exists.
>> >> > ('Average Annual Loss for Tropical Cyclone and Earthquake',
>> >> > 'average-annual-loss-for-tropical-cyclone-and-earthquake')
>> >> > DETAIL: Key (name)=(Probabilistic) already exists.
>> >> > ('Probabilistic', 'probabilistic')
>> >> > DETAIL: Key (name)=(Earthquake) already exists.
>> >> > ('Earthquake', 'earthquake')
>> >> > DETAIL: Key (name)=(Hazard) already exists.
>> >> > ('Hazard', 'hazard')
>> >> > DETAIL: Key (name)=(cyclone) already exists.
>> >> > ('cyclone', 'cyclone')
>> >> > DETAIL: Key (name)=(solomons) already exists.
>> >> > ('solomons', 'solomons')
>> >> > DETAIL: Key (name)=(risk) already exists.
>> >> > ('risk', 'risk')
>> >> > DETAIL: Key (name)=(Summary Report) already exists.
>> >> > ('Summary Report', 'summary-report')
>> >> > DETAIL: Key (name)=(Risk Assessment) already exists.
>> >> > ('Risk Assessment', 'risk-assessment')
>> >> > DETAIL: Key (name)=(Loss) already exists.
>> >> > ('Loss', 'loss')
>> >> > DETAIL: Key (name)=(Topography) already exists.
>> >> > ('Topography', 'topography')
>> >> > DETAIL: Key (name)=(Document) already exists.
>> >> > ('Document', 'document')
>> >> > DETAIL: Key (name)=(Imagery) already exists.
>> >> > ('Imagery', 'imagery_1')
>> >> > DETAIL: Key (name)=(Soil) already exists.
>> >> > ('Soil', 'soil')
>> >> > DETAIL: Key (name)=(SOILS) already exists.
>> >> > ('SOILS', 'soils')
>> >> > DETAIL: Key (name)=(SOIL) already exists.
>> >> > And the last python script, 'migrate_group_permissions.py', revealed:
>> >> > File "migrate_group_permissions.py", line 16, in <module>
>> >> > authenticated_group_id = dst_cur.next()[0]
>> >> > StopIteration
>> >> > Correct me if I'm wrong, it looks like the error in the first script
>> is
>> >> > related to my settings_path within gn_migration.cfg file. I saw
>> within
>> >> > the
>> >> > forums that this should be set to 'settings_path = geonode.settings'.
>> >> > As for errors in scripts migrate_tags.py and
>> >> > migrate_group_permissions.py,
>> >> > I'm hoping to get your advice on this part.
>> >> > Thank you immensely,
>> >> > Mana
>> >> > On Wed, Feb 10, 2016 at 5:09 AM, Paolo Corti <pcorti at gmail.com>
>> wrote:
>> >> >> Hi Mana
>> >> >> did you run migrate2.sh after migrating the GeoServer data
>> directory?
>> >> >> did you see any error running that script?
>> >> >> p
>> >> >> On Tue, Feb 9, 2016 at 2:00 AM, Mana Etches <manadotcom at gmail.com>
>> >> >> wrote:
>> >> >> > Hello geonode gurus,
>> >> >> > I've installed geonode 2.4 following instructions at
>> >> >> > http://geonode.org/blog/2015/11/19/geonode-2.4-released/
>> >> >> > I've followed Capooti's migration steps at guidelines at
>> https://github.com/capooti/geonode/blob/migration_from20_to_24/scripts/migrations/migrate20to24/index.rst
>> >> >> > I'm at a point where I can see the number of layers, maps and
>> users
>> >> >> > on
>> >> >> > geonode GUI (but only as a registered user). I can log into
>> geoserver
>> >> >> > admin,
>> >> >> > however I don't see my layers, stores, on the admin panel.
>> >> >> > I uploaded 2.0 GS data directory to geoserver 2.4 data directory
>> as
>> >> >> > follows:
>> >> >> > data/default to data/default
>> >> >> > gwc-layers to gwc/layers
>> >> >> > workspaces/geonode to workspaces/geonode/datastore
>> >> >> > Note, I can upload layers just fine but I can only see the the
>> layers
>> >> >> > that I
>> >> >> > uploaded in the geonode_data in postgres. I can't see the layers
>> from
>> >> >> > 2.0
>> >> >> > database.
>> >> >> > Lastly I ran a 'geonode updatelayers' and got the following
>> results:
>> >> >> > Finished processing 4 layers in 2.0 seconds.
>> >> >> > 0 Created layers
>> >> >> > 4 Updated layers
>> >> >> > 0 Failed layers
>> >> >> > 0.500000 seconds per layer
>> >> >> > Updating only the layers that I uploaded.
>> >> >> > For referencing purposes see my 'gn_migration.cfg' configurations
>> >> >> > below:
>> >> >> > [db20]
>> >> >> > dbname = old_db
>> >> >> > host = 192.168.137.12
>> >> >> > user = geonode
>> >> >> > password = secret (replaced)
>> >> >> > [db24]
>> >> >> > dbname = geonode
>> >> >> > user = geonode
>> >> >> > [path]
>> >> >> > geonode_path = /usr/local/lib/python2.7/dist-packages/geonode
>> >> >> > settings_path = /etc/genode/local_settings.py
>> >> >> > My gut feeling is its a configuration issue.
>> >> >> > Any help or point in the right direction would be very much
>> >> >> > appreciated
>> >> >> > Mana
>> >> >> > _______________________________________________
>> >> >> > geonode-users mailing list
>> >> >> > geonode-users at lists.osgeo.org
>> >> >> > http://lists.osgeo.org/mailman/listinfo/geonode-users
>> >> >> Paolo Corti
>> >> >> Geospatial software developer
>> >> >> web: http://www.paolocorti.net
>> >> >> twitter: @capooti
>> >> >> skype: capooti
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160211/976d87bf/attachment-0001.html>
More information about the geonode-users
