[GeoNode-users] Geonode SRS 3857
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Feb 11 01:11:01 PST 2016
the two srs should be exactly the same. I've loaded many 3857 layers
without any issue or need to change the geonode code. Also, geonode
preserves the native projection so in geoserver they are published as 3857
and geoexplorer just directly load them.
Not sure why you get deformed labels.
2016-02-10 12:54 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> I need to change the default CRS to EPSG:3857. In theory it's the same to
> EPSG:900913 but when I get a layer in a native 3857 CRS if I load the layer
> into the GeoExplorer the labels and vector contours appear slightly
> deformed.
> I've changed views.py and layers.py but I still get in the map
> SRS=EPSG:900913 requests..
> Where do I have to change the default srs?
> Is there a plan to move from 900913 to 3857?? 900913 seems to be obsolete
> and the official is 3857?
> Thanks,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL
> ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160211/6f58ca16/attachment.html>
More information about the geonode-users
