[GeoNode-users] I can't pubishing map: internal error server
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Feb 12 08:07:31 PST 2016
very good Enzo!!!, I just tried on my production server and I can confirm that!
However in the last months I tried geonode in a server setup from scratch with the same package versions, where the maps were created and published correctly. In this machine I checked now and I see the apache mphp5 module installed and running. So the story unfortunately is not completely clear.
Moreover I want use geonode on my production server which needs php5 module for other applications.
Do you have any idea on how I can configure apache for running both php5 and wsgi module?
Eugenio
Date: Fri, 12 Feb 2016 11:45:31 +0100
Subject: Re: [GeoNode-users] I can't pubishing map: internal error server
To: frippe12573 at hotmail.com; geonode-users at lists.osgeo.org
Hi
I have resolved this problem by disabling php5 module of apache. I think it is incompatible
E
2016-02-10 16:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi all,
just to update all of you, yesterday I restarted the installation from scratch. I follow the administrator installation guide,
of course taking into consideration my system.
I installed again geonode from git, deleted and re-installed the DBs in my already running postgresql-postgis and deploy again geoserver
obtained after paver server start action.
This time I also deleted all the packages already downloaded in /usr/local/lib/python2.7/site-packages in order to let pip install -e . to get
packages required again.
Everything went well, and almost the functionalities works fine, again excluding saving a new map.
Here below the error I got on apache error.log:
Wed Feb 10 09:22:25.197172 2016] [:error] [pid 25962] Internal Server Error: /maps/new/data
[Wed Feb 10 09:22:25.197247 2016] [:error] [pid 25962] Traceback (most recent call last):
[Wed Feb 10 09:22:25.197256 2016] [:error] [pid 25962] File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
[Wed Feb 10 09:22:25.197261 2016] [:error] [pid 25962] response = wrapped_callback(request, *callback_args, **callback_kwargs)
[Wed Feb 10 09:22:25.197266 2016] [:error] [pid 25962] File "/dati/geonode/geonode/maps/views.py", line 428, in new_map_json
[Wed Feb 10 09:22:25.197270 2016] [:error] [pid 25962] map_obj.update_from_viewer(body)
[Wed Feb 10 09:22:25.197274 2016] [:error] [pid 25962] File "/dati/geonode/geonode/maps/models.py", line 173, in update_from_viewer
[Wed Feb 10 09:22:25.197279 2016] [:error] [pid 25962] conf['map']['zoom'])
[Wed Feb 10 09:22:25.197283 2016] [:error] [pid 25962] File "/dati/geonode/geonode/base/models.py", line 437, in set_bounds_from_center_and_zoom
[Wed Feb 10 09:22:25.197287 2016] [:error] [pid 25962] lon, lat = get_lon_lat()
[Wed Feb 10 09:22:25.197292 2016] [:error] [pid 25962] File "/dati/geonode/geonode/base/models.py", line 429, in get_lon_lat
[Wed Feb 10 09:22:25.197296 2016] [:error] [pid 25962] lon, lat = transform(mercator, wgs84, center_x, center_y)
[Wed Feb 10 09:22:25.197300 2016] [:error] [pid 25962] File "/usr/local/lib/python2.7/dist-packages/pyproj/__init__.py", line 504, in transform
[Wed Feb 10 09:22:25.197305 2016] [:error] [pid 25962] _proj._transform(p1,p2,inx,iny,inz,radians)
[Wed Feb 10 09:22:25.197309 2016] [:error] [pid 25962] File "_proj.pyx", line 361, in _proj._transform (_proj.c:3762)
[Wed Feb 10 09:22:25.197314 2016] [:error] [pid 25962] RuntimeError: geocentric transformation missing z or ellps
[Wed Feb 10 16:22:26.082801 2016] [core:notice] [pid 25957] AH00051: child pid 25962 exit signal Segmentation fault (11), possible coredump in /tmp/core-dump
Last line stated that a possible coredump, due to the segmentation fault, maybe has been created (actually not).
In this case a new map is listed, however it is empty, which means that the layer I used has not been saved.
The action create a row in the db (geonode) but almost all field are empty. It seems the application doesn't pass values
in the db. I guess this fault raise the seg fault.
I hope this can help to find a solution or a sort of workaround.
E.
Date: Tue, 9 Feb 2016 21:35:18 +0000
To: simone.dalmasso at gmail.com; enzo.ccc at gmail.com; geonode-users at lists.osgeo.org; ingenieroariel at gmail.com; frippe12573 at hotmail.com
Hi everyone,
Eugenio is right, it appear's that it could be exactly the same error. I haven't found the solution either.If there's something I can do to help to find out, please let me know.
Best regards,Ivo
2016-02-09 18:13 GMT+00:00 Enzo Cocca <enzo.ccc at gmail.com>:
Hi,I haven't resolved the problem and I can not find the solution. Someone have same idea?
E
2016-02-09 10:39 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
Hi Simone,I have configurated geonode like instruction Geonode is installed on ubuntuserver 14.04 with a ip public adress.
Every thinks work very well but just the publishing map dasn't work.
So today I will review the apache configuration and I will let you know.
If you have any idea about this error, please let me know
Thanks
E
2016-02-08 21:00 GMT+01:00 <geonode-users-request at lists.osgeo.org>:
Send geonode-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/geonode-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geonode-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of geonode-users digest..."
Today's Topics:
1. Re: I can't pubishing map: internal error server (Eugenio Trumpy)
Message: 1
Date: Mon, 8 Feb 2016 15:21:00 +0100
To: Simone Dalmasso <simone.dalmasso at gmail.com>, Enzo Cocca
<enzo.ccc at gmail.com>, "ivojfs at gmail.com" <ivojfs at gmail.com>
Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
server
Message-ID: <DUB123-W4169565D16F21E8DBC0876E5D50 at phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"
Hi Enzo and Simone,
this is more or less what happened to me [1] recently and, if I remember well, to Ivo Santos [2] in january.
I would propose to put together the forces to solve this issue, to find out what is produce wsgi mod crash on apache.
Best regards
Eugenio
[1] https://lists.osgeo.org/pipermail/geonode-users/2016-January/001281.html
[2] https://lists.osgeo.org/pipermail/geonode-users/2016-January/001366.html
Date: Mon, 8 Feb 2016 14:50:02 +0100
To: enzo.ccc at gmail.com
CC: geonode-users at lists.osgeo.org
how did you install Geonode? What is your platform? You are not the first that gets this error and we need as much information as possible to understand what configuration is causing it. The error should come from apache configuration see http://stackoverflow.com/questions/4331310/apache-with-mod-wsgi-segfaults
2016-02-08 12:33 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
I can't publishing map. I have the internal error server. So in apache error log I have founf this problem:
[Mon Feb 08 12:30:01.758476 2016] [core:error] [pid 59907] [client 90.147.101.142:38620] End of script output before headers: wsgi.py, referer: http://myipaddress/maps/new
[Mon Feb 08 12:30:02.353489 2016] [core:notice] [pid 59412] AH00051: child pid 59416 exit signal Segmentation fault (11), possible coredump in /etc/apache2
How can I resolve it?
Thanks
E
Enzo Cocca PhDin "Science and Technology for Archaeology and Cultural Heritage"
mail: enzo.ccc at gmail.comcell: +393495087014
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160208/8eaf4d48/attachment-0001.html>
Subject: Digest Footer
End of geonode-users Digest, Vol 13, Issue 15
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160212/3f2bfd04/attachment-0001.html>
More information about the geonode-users
